Old 04-23-2009, 10:48 PM   #26
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Re: 90 burb (( daily dragger))
I might have to ride over and hang out some this weekend...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-24-2009, 11:44 AM   #27
87 dually burb
my short bus
87 dually burb's Avatar
hoping to weld them up saturday after helping friends move should have them back on sunday and finish cutting the inner fender for clearance
pic's sunday after installed/clearanced
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 04-29-2009, 12:30 PM   #28
87 dually burb
my short bus
still waiting on my welder to get them done
Old 04-29-2009, 09:42 PM   #29
87 dually burb
my short bus
took them to local guy
fully welded around
wrapped the end with 3/16 strap
not bad for $150 steel/welded
Old 04-29-2009, 10:39 PM   #30
72 CustomCamper
huh ???
That's cool. Are you going to have it ready for the cruise in Saturday if it doesn't rain?
Chuck
Old 04-29-2009, 10:57 PM   #31
87 dually burb
my short bus
have thur and fri off so if the rain stops I'll have them in
see you sat what time you rolling in ?
Old 04-29-2009, 11:17 PM   #32
72 CustomCamper
huh ???
I should be there around 4:30 to set things up...
Chuck
Old 04-30-2009, 07:56 AM   #33
tvblazer78
Low & Fast!
tvblazer78's Avatar
Good work man. Let us know how it works..
tvblazer78 is offline   Reply With Quote
Old 04-30-2009, 05:48 PM   #34
87 dually burb
my short bus
updated pic's
sits on crossmember with hear box in place
air dam 1" from ground
thanks chuck for stopping by and checking it out
needs 5.5"s to be level has 2"s to frame so a 3" notch should be good for now
makes the flip kit look like a lift kit
Old 04-30-2009, 10:39 PM   #35
72 CustomCamper
huh ???
It was fun watching somebody else work for a change. LOL Here's the shot your son warned you I took...
Old 05-01-2009, 10:02 AM   #36
justpball
justpball's Avatar
nice bro! get that back done!!!! looking sick.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 05-01-2009, 10:44 AM   #37
SBTork
Garage wrench
SBTork's Avatar
damn that burb is low, should look perfect once the rear is down too. Nice work
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 05-01-2009, 04:05 PM   #38
rddiaz
rddiaz's Avatar
grinder and a sawall.... mans best friends............coming out nice...
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 05-04-2009, 11:51 AM   #39
87 dually burb
my short bus
looks like another week of rainy days so may not get the rear done till middle next week the local welder I found does body drops and and custom truck so hopin to work something out to get it all done at 1 time - notch,cover,weld up all rain gutter-sunvisor holes,rollpan,tail lights
will see work is slow so play cash is tight this month
Old 05-22-2009, 10:55 AM   #40
justpball
justpball's Avatar
update?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 05-23-2009, 11:20 PM   #41
87 dually burb
my short bus
all new carpet/vinyl in house done
new french door's done
16' x 28' deck done
had ac duct's cleaned and serviced
will be back at it later in the week
(still have to paint a room or two this month)
update on burb chasing a leak down right now
hoping to have the rear notch in 2 weeks or so
working out all welding with one shop so checking on timing to have all done at once
Old 05-25-2009, 12:06 AM   #42
87 dually burb
my short bus
2 new bathroom vanity/tops/faucets
redid both flower beds out front
planted and seeded lawn twice in 2 weeks
hoping to get working on truck this weekend
honey do list is about done for this year
Old 05-28-2009, 05:03 PM   #43
justpball
justpball's Avatar
make sure and post pics of the rear notch, i am planning mine right now and want to see what you do.
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-01-2009, 10:41 PM   #44
87 dually burb
my short bus
hoping to cut floor out thur or fri
got side track found a cheap crew cab long bed truck
needed a DD/truck while floor is out
found some rust around inner wheel tubs but all will be cut out when the small bridge is put in
will have the plasma cutter thur-sat may cut up more stuff then
wife said dont do any thing to crew cab till the burb is back on the road
Old 06-01-2009, 10:58 PM   #45
72 CustomCamper
huh ???
I guess you won't have the burb back together by the cruise in Saturday then...
Chuck
Old 06-02-2009, 12:16 PM   #46
justpball
justpball's Avatar
why did you wrap the outer a-arms with the metal?
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-02-2009, 03:28 PM   #47
87 dually burb
my short bus
I had to cut th rain gutter off the arms for the 15" rallies to fit so I wrapped it with a metal band and cut it to fit had to trim about a 5/16 off keep it from rubbing
not lookin like it I let the inspection run out so I'm just going to cut the floor do a notch and bags/mount done to inspect for july
Old 06-02-2009, 09:34 PM   #48
87 dually burb
my short bus
got a early start on the weekend work
Old 06-05-2009, 02:52 PM   #49
justpball
justpball's Avatar
nice, i thought you were going to cut it back far enough to raise the thrid seat up...
87 Crew SWB
Build for the crew
90 burb 2wd
Old 06-05-2009, 09:25 PM   #50
87 dually burb
my short bus
I am that is all I got cut before the thunder storms rolled through all this week
it will be cut even across the back of the wheel wells and enough in the front to still fit under seat if you look at the wheel opening I have about 8" in front of the wheel well that will be filled in flat for more leg room and future speakers
