05-02-2009, 11:15 PM | #26 |
Re: 71 Longhorn BBC, AC, PS, PB parting out
i'll like to be next inline for the clutch zbar and engine zbar pivot bracket. even if it doesn't get as far as me, i'll still like to see pics of the setup. thanks, jake
67 short fleet 71 blazer 4x4 72 blazer 2wd 76 gmc sierra 3/4t 4x4 62 bel air 01 blazer extreme member 11,943! |
05-03-2009, 12:35 PM | #27 |
Hi all I took a bunch of parts off yesterday and got rained on a bunch since its outside. But here goes some response
Southern parts- zbar and rod $25 plus need your zip and money toomuchstuff- emblems yours picts posted except one custcamp is broken between the C amper. But could be used and look fine. Seat belts for $10 the pict is posted today and two centers are dark blue/black none of which are in good shape but usable. Let me know on both please Lugnut- AC underdash is yours for $85 all good except #12 the screw holes are broken but otherwise good shape. $75 without. let me know Forever71 -$35 for both door panels good but not perfect. Picts today. and $50 for colum the cancel cam works and is tight no shift lever and signal lever needs new chrome. Let me know 70longhorncst-The uppers are good except someone put screws throught them to mount them, the lower frt pass bed mould I can take better picts of on 5-4 for you it is in pretty good shape definitely usable. $45 for all plus let me know CPNE - $40 plus $4.55 shipped to 03580 snail mail Let me know Musclecarpaul yes you are 2nd. both custom camper but on is broken between the C amper but could be used and look fine. Davidwiebelt- no aux dash switch on this one sorry neo1370 all 4 $165 but the pressure line has a pin hole in the steel line where it crosses the frame. Let me know BigJake97- second on Zbar and rod I also need to know if I can PM picts to people or not please. All will be shipped as soon as you confirm your order with $$ and I get them boxed to go. Thanks all |
05-03-2009, 12:40 PM | #28 |
Moderator
Thanks. I will pass on the upper ones with the screws, but would like pics on the lower one when you can on 5/4. Thanks.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
05-03-2009, 12:41 PM | #29 |
Here are some more picts.
one of the upper trim 4 70longhorncst. Thats the best I have today The CustomC amper break for those wanting that. Still usable. the column 4 forever71 and all of the hubcaps have dent this being the worst one. Please let me know what you have decided so we can move forward. You can always PM me for other info. Thanks Phil |
05-03-2009, 01:37 PM | #30 | |
Middle-aged Curmudgeon
I'll take all of it. P.M. on the way.
Bret Check out the site's Truck Tech FAQ. Be a site supporter. My more-or-less pathetic build thread. Board members I've met: ------------------------------ Longhorn Man Dieselwrencher jholley big mike71 |
05-03-2009, 01:48 PM | #31 |
Moderator
Thank you Phil,
I should have been more clear. I want the passenger lower front of the wheel (near the cab) molding when you are able to get a pic. Thank you. Richard
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 05-03-2009 at 01:48 PM. |
05-03-2009, 01:49 PM | #32 |
I will take the pulleys if Classic Bowties does not. Thank you.
Scott |
05-03-2009, 05:22 PM | #33 |
So lets work on some of these prices since research has shown that some are pushing it a bit I guess.
BBC engine stands 71 $90 BBC fan shroud $35 a deal AC brackets $225 AC control has a broken lever "top one" $25 Exhaust manifold on pass side cracked but drivers side good $30 |
05-03-2009, 05:57 PM | #34 |
Again,how about a price on the hub caps shipped to zip 30016?
05-03-2009, 08:14 PM | #35 |
Resident Curmudgeon
If the kickdown switch and wiring is complete and unmolested I'll take it for $45 shipped. Please confirm and I'll paypal tomorrow
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
05-03-2009, 08:16 PM | #36 |
Resident Curmudgeon
oh, one other thing, the throttle cable from pedal to the carb. How much and can you ship with kickdown switch/harness?
05-03-2009, 10:21 PM | #37 |
ajcan $20 for all the hub caps and +11.60 shipping snail mail when I am paid.
CPNE the throttle cable is no good at all but 45 shipped for the switch and wiring is fine. I have looked at most of it. Looks good will get that shipped in a day or so when I recieve money. Thanks Phil
Phil '70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver '72 short super build 4wd '72 Suburban LT4 coming soon!! |
05-03-2009, 10:48 PM | #38 |
Classic bowties the part #'s for the pulleys are WP 3927789 AG, outer crank 3925525 BR, inner crank double groove 3876844 BU. Let me know and I can send them after money arrives. Thanks Phil
05-03-2009, 11:27 PM | #39 |
What is the condition of the inner fender wells....if good shape how much shipped to 46037
05-04-2009, 12:39 AM | #40 | |
Always on the hunt...
Hey Phil, so long as pulley conidtion is good quality/used, the numbers look good to me, pm sent regarding payment instructions. Thanks |
05-04-2009, 12:40 AM | #41 |
Just making sure C30 = 1 ton ? I have a 70 blazer 4x4 with disc brakes that I would like to do a 1 ton booster upgrade on if this would work for me. I would be interested in the complete booster/mc/prop valve assembly. Also the support bracket that goes to the firewall if possible. My zip is 95610. Thanks, Anthony
05-04-2009, 04:57 AM | #42 |
I'll take the ps set-up, PM me with payment info. Thanks, Vernon
05-04-2009, 09:52 AM | #43 | |
Resident Curmudgeon
PM Sent
05-04-2009, 10:11 AM | #44 |
I will take the a/c brackets and fan shroud. My zip is 57701. Let me know on shipping and I will paypal you. Thanks.
Scott |
05-04-2009, 01:48 PM | #45 |
If you are selling the power brake booster with the bracket to attach it to the fire wall, cant i just use my prop valve and make it work for the drum brakes until i upgrade to disk?
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388 |
05-04-2009, 03:41 PM | #46 |
Phil
Before I commit did these come from a 16 inch or 16.5 inch wheel or is it even relevant? Thanks. AJ |
05-04-2009, 05:09 PM | #47 |
Roadtrip!
Total for the 4 emblems and seat belts? Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-04-2009, 05:21 PM | #48 |
Spotlite?
05-04-2009, 08:08 PM | #49 |
i thought i was going to be seeing a 4 speed column with no shifter lever at all.so im passing, but can i get a pic of the passenger door panel?
05-04-2009, 09:55 PM | #50 |
Some more work done today. Replies as follows
ajcan yes came from 16" don't know about 16.5" compatablitiy. Let me know. IndyRich- pass side rusted through frt near radiator. driver side good $30 Plus ship Not sure how much ship is till boxed. but guessing around 15-20 lbs. Let me know Classic Bowties sending Pm now. Turp Mcspray - AC Brkts and shroud $260 (a Deal) plus shipping can box tomorrow. Pm me shipping info Devil pup - I believe so but you might want to check in normal QA forum. toomuchstuff - $25 for all emblems and $10 for seat belts. Which belts? all? Plus shippig bigdon-70blazer - spotlight is yours it moves and switch clicks have not tested it though. $10 plus shipping Forever71 I do have a 4spd column Black one at my other house if you want it. But it will be a couple weeks till I'm up there again. Its in good shape. Let me know And remember all parts are price Plus Shipping. Please feel free to paypal me at S_nova69@yahoo.com Thanks again
