Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-16-2009, 07:51 AM   #26
djracer
djracer's Avatar
Re: rear suspension help
Here's why you want trailing arms. So you can leave like the ole farm truck.
http://yellowbullet.com/forum/showthread.php?t=143943
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-16-2009, 10:29 AM   #27
Outlaw72
Hay Team!!
Outlaw72's Avatar
Trailing Arms are not his only trick, but he does have them and he has made them work with his setup as a whole. That truck is crazy sick....you should see it in person.
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 06-18-2009, 02:25 PM   #28
Super73
Super73's Avatar
Originally Posted by SCOTI View Post
Basic physics would suggest an airbag acts very much like a spring when compressed to a certain extent: the bag (spring) will want to return to its uncompressed state or size (squish a ballon & it distorts, unsquish it & returns to its original form immediately).
I agree with what you are saying but, and this is a big but...
A bags spring rate is dependant on the weight applied and the PSI in the bag right? So, let's make a hypothetical situation here..
Bag situation
1500lb unsprung weight
Leverage ratio of 1.5
10" bag at full length and 7" at ride height
Effective spring rate would be 375lbs
Spring situation
13" spring at full length and 7" at ride height
Effective spring rate would be 187.5lbs
Most bags I have seen don't allow you to compress them as far as a spring. For istance, my front springs at free height stand 17 3/8" and were at 9" at ride height. That's 8 3/8" of compression and I still had a good 2.5" of travel before coil bind. I believe coil bind was 6 7/8". Talking 10 1/2" of travel the spring has. If there are bags on the market that will allow you to do that, then I could see it being done effectively.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-18-2009, 03:13 PM   #29
SCOTI
SCOTI's Avatar
That's sounds about right. The nature of airbags translates into a progressive spring rate on compression vs. a coil that can possibly be set-up for a linear rate.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
