10-24-2010, 09:28 AM | #26 |
Who Me?
Re: Pics of trucks in Primer Paint
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
10-24-2010, 10:30 AM | #27 |
gorgeous 54 TX, love those old things and I really like suede orange.
as far as suede paint jobs go - I've always been a huge fan of suede dark blue - have seen many 45-55 pickemups painted with suede dark blue and a few old model A's painted suede "washington blue" and it looks pretty darm sweet. |
10-24-2010, 11:01 AM | #28 |
I used a product called "Zero Rust". It's marketed as a primer/paint. I applied it by rattle can. The color is "safety blue" and has a satin finish.
1962 C10 Sidestep Shortbed 350, 700R4 http://picasaweb.google.com/robtinvi...evyC10Project# |
10-24-2010, 11:05 AM | #29 | |
But Found Her 25yrs Later!
Do you have a link to their website? Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-24-2010, 11:15 AM | #30 |
Senior Enthusiast
The nice part is Zero-Rust is really great paint. 10 years ago I used POR-15 for most of my chassis, but IMHO found that Zero-Rust works better.
http://zero-rust.com/?referrer=googl...FQYHbAodHX2x2A And here is where I buy a lot of my paint supplies. They also have an excellent painting forum: http://autobodystore.com/new_page_1.htm |
10-24-2010, 12:22 PM | #31 |
Never Ending Projects
I can play in this one
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-24-2010, 02:29 PM | #32 |
My truck,,,HotRodFlatz
10-24-2010, 03:41 PM | #33 |
[QUOTE=robt_virginia;4257247]I used a product called "Zero Rust". It's marketed as a primer/paint. I applied it by rattle can. The color is "safety blue" and has a satin finish.
How many cans does it take to paint the whole truck, and how many coats. I like that color too. |
10-24-2010, 05:35 PM | #34 | |
[quote=chainsaw;4257646]
Eventually, I plan to get the truck professionally painted, but until then I hope my Zero Rust/Rustoleum job will hold up. (My truck is not garaged)
10-24-2010, 06:07 PM | #35 |
10-24-2010, 07:32 PM | #36 |
Senior Enthusiast
Hi Dan, the wheels are new production Torque Thrust Originals (TTO’s) (not Torque Thrust D’s). The rear wheels are 15x7 and the fronts are 15x5. I don’t care for the appearance of the 15x8 TTO wheels, because of the extra machine cut in the face of the rim right in front of the spokes. It just looks unnatural to me.
Here’s a close up of my 15x7 and a stock photo of a 15x8 for comparison: And here’s a close up of the front wheel/tire: The rear tires are 255/70-15 Firestone Indy 500, and the fronts are 215/70-15 BFG Radial T/A’s. If they don’t change the way they’re made, I’ll be running the Firestone tires from now on. I like the more “squared corner” appearance compared to the T/A’s. They also last longer (the middle of the tread doesn’t wear out like on a T/A), ride smoother, balance easier and corner better than the T/A’s. Note the spokes on the wheels as seen on my truck (and as shown above) have been painted Iron Cast Gray. The Martin Seynour spray paint came from Napa Auto Parts. As purchased, the wheel spokes appear to be bare aluminum and look rather anemic in my opinion. When I originally bought the front wheels I was intending to go for more of a gasser look, with the front end raised higher and white fenderwell headers. Early retirement changed all that, so eventually I got tired of the spindly look of the front wheels. I simply repainted the spokes black and that changed the look. Last edited by markeb01; 10-24-2010 at 07:35 PM. |
10-24-2010, 07:56 PM | #37 |
Project '67 454
Great looking trucks guy's,
67 C-10 SWB Fleetside 454 (current project) 99 Crewcab SWB Dually 454 75 Datsun 280ZZ430 94 Formula 232LS 454 Last edited by mrh33916; 10-25-2010 at 10:46 AM. |
10-24-2010, 10:32 PM | #38 |
The bed is obviously primer.
How about the cab forward? I like the cool blue-green color.
10-25-2010, 12:13 AM | #39 |
Rustoleum glorius Rustoleum 1 Gallon of satin white a pint of gloss green, a pint of gloss blue. I sprayed the white first then mixed the green with what was left of the white. It was all shot through a HVLP gun in a warehouse type shop. Its good from far and far from good! About $80 in this paint job. Last edited by Fudge; 10-25-2010 at 12:15 AM. |
10-25-2010, 10:36 AM | #40 | |
10-25-2010, 01:53 PM | #41 |
Heres mine, I used Rustolim. Still needs extra coats to the body and top.
10-25-2010, 01:56 PM | #42 |
I love the flat black look, when my truck is finished thats the color I want to go with, does it cost as much as a normal paint job?
Get Low |
10-25-2010, 02:05 PM | #43 |
Not at all, a good paint job would cost you a $2-3K. Spray cans, a case of them would cost you maybe $100... its like 5-6 dollars a can.
10-25-2010, 02:12 PM | #44 |
thats just rustolim, it looks great. Did you have to sand after painting or did you just prime it and spray it.
Get Low |
10-25-2010, 02:25 PM | #45 |
I sanded the whole thing, then sprayed 5 cans. wet sanded and painted again.
It need another sand and spray as the weather gets to it. |
10-25-2010, 02:47 PM | #46 | |
Senior Enthusiast
By comparison, the cost of automotive paint materials can easily run into hundreds of dollars a gallon, plus the cost of hardeners and other compatible chemicals. |
10-25-2010, 02:57 PM | #47 |
Another black and red. Its US Army matt black (PB90).
10-25-2010, 02:59 PM | #48 |
I am wondering about your center caps. I am searching these for my 6-lug rims. Where to buy these?
10-25-2010, 04:55 PM | #49 |
Thanks for the paint mfg and name for your spokes. I'm a bit confused thought - you mention in your last paragraph you painted hte spokes black. Did you mean you painted BEHIND the spokes black? I take it the "John Deere Blitz Black" you mention is an over the counter paint for general metals like Rustoleum? Obviously no one in Southern California is painting tractors so the other doesn't exist here as far as I know! P.S. I'm definitely NOT a painter, so which temperature range or "speed" did you use with your Blitz Black and if you remember the mix ratio (I assume you recorded it for later touch ups?) I'd really appreciate the info. Last edited by Dan in Pasadena; 10-25-2010 at 05:09 PM. |
10-25-2010, 05:00 PM | #50 |
guess my truck kinda falls into this category, also just wanna post it haha, no clue what the actual paint color is... ive since painted wheels, roof and grille an off white but no pics
