Old 08-25-2009, 01:10 PM   #26
vegaschevy
Re: Project NOT4SLE
Originally Posted by my67chevytruck View Post
I think i would go with a 1" or 2" phenolic carb spacer and that should get you above the AC bracket. I would go this route before bending the carb fuel line.
what oil filler problem you referring too?
I want to get rid of the stovepipe filler on the truck and go with something low profile since i am changing out the intake. I found a couple plugs and grommets but nothing fits snug
vegaschevy is offline   Reply With Quote
Old 08-26-2009, 09:41 PM   #27
vegaschevy
Re: Project NOT4SLE
I purchased a carb spacer plate today along with a skip white distributor. I figured I see no sense in timing the oem original distributor on this truck to get it running.
If I am going to patch this motor till OI build a new one I figured I might as well try to help it run better till then. I also ordered a set of 90* spark plug wires, a crimping tool and a dress up kit to continue putting lipstick on a pig.
Ill have pics hopefully on friday for you.
Old 08-26-2009, 10:21 PM   #28
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Project NOT4SLE
never had one of the trucks with the stovepipe filler on the valve cover, may be easier to swap out the valve cover if you cant find a grommet to fit well. does a air breather fit there. your making good progress, keep up the work!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-28-2009, 12:46 PM   #29
vegaschevy
Re: Project NOT4SLE
I was thinking about just switching out the valve cover. However I really did not want ot put any money into this motor while I get other stuff done and build my motor for this truck.
However, THe UPS man showed up and it is Christmas in August today.
This should get her on the road and running within the next few days.
I work tonight from midnight till 8am and sunday morning 6am till 2am, YES 20 hours.
so Monday is the day Im shooting for to get her running and parts installed.
Old 08-28-2009, 01:10 PM   #30
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Project NOT4SLE
Just an FYI, those crimpers are wire crimpers and not the ones used for crimping ends on spark plug wires. You might get them to work okay but they are not correct.
These are the correct plug terminal crimpers.
They make a world of difference in the quality of the crimps, for plug wires.
Editted, I guess looking closer at the pic, there is some crimp spot on the handle that should work. Kind of hard to tell.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-29-2009, 08:23 PM   #31
sleepertruck72
sleepertruck72's Avatar
Re: Project NOT4SLE
[QUOTE=vegaschevy;3489609]I was thinking about just switching out the valve cover
Vegaschevy,
I have the same style valve covers laying around. Let me see what kind of plug or breather It has. I wont be in need of it if you want it.
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 08-29-2009, 09:06 PM   #32
vegaschevy
Re: Project NOT4SLE
[quote=sleepertruck72;3491706]
Vegaschevy,
ill be looking at it on Tuesday, thanks for the offer.
tomorrow is my long work day .
Old 09-08-2009, 09:10 PM   #33
vegaschevy
Re: Project NOT4SLE
Cannot wait till Thursday so I can work on the beast again. Worked all weekend a bunch of hours
Old 09-19-2009, 12:54 AM   #34
highperf4x4
Re: Project NOT4SLE
I used a spacer on mine as well but it's because I used a stock GM aluminum intake which is slightly shorter and I installed an HEI distributor so I needed clearance for my breather over the dizzy.
highperf4x4 is offline   Reply With Quote
Old 09-19-2009, 01:29 AM   #35
VA72C10
VA72C10
VA72C10's Avatar
Re: Project NOT4SLE
Any updates?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-19-2009, 01:33 AM   #36
vegaschevy
Re: Project NOT4SLE
tomorrow morning I am hoping to have this beast running. I have been working days, then nights, then both back to back and so being awake during the day to work on this pig has been non existent.
I installed the Dizzy, and ran all my wires the other day. No pics uploaded yet. I also am not using the spacer now as i got the fuel line bent and hopefully it seals up well when tightened.... HAHAHA
Tomorrow morning I am waking up and working on her though. I am hoping to get the radiator back in and fuel hooked up. Then she should be ready to fire up.
Old 09-19-2009, 01:35 AM   #37
vegaschevy
Re: Project NOT4SLE
my buddy picked up a 67-68 cowl hood for this truck in Ca today. So all I need is some small stuff to complete the swap lol
Old 09-19-2009, 02:20 AM   #38
VA72C10
VA72C10
VA72C10's Avatar
Re: Project NOT4SLE
cool...I'll be looking forward to the pictures.
Old 09-19-2009, 03:11 PM   #39
highperf4x4
Re: Project NOT4SLE
You didn't want to use the spacer instead of bending the new fuel line? And are you sure your breather is going to clear the dizzy?
Old 09-22-2009, 02:54 AM   #40
vegaschevy
Re: Project NOT4SLE
It is a very tight fit, but it did fit. 1/8" more clearance would be nice though. I may switch out breathers later. This is all temporary once I get a 383 built. Im trying to get this band aid dine to get her running and drivable. Once thats done it will be on to dropping it and wheels and tries. THen the front clip and rocker repair while building a motor.
I got a few hours work completed and the fuel line ran. I need to reinstall the rad and fire it up. I will probably be putting in the 71 tank I have as this one seems to be in worst shape inside.
Old 09-22-2009, 03:02 AM   #41
highperf4x4
Re: Project NOT4SLE
Actually before I switched carbs and installed the spacer, I picked up one of those black plastic breather spacers from autozone for like 9.00 and put it on top of the carb. My breather is like yours, pretty well balanced so it worked good for a year or so. You could try that for now.
Old 09-23-2009, 12:05 PM   #42
vegaschevy
Re: Project NOT4SLE
Well when I wake up later on Ill hopefully finish the truck and have her running. I just got off work and I got a friendly call from Nate at Porterbuilt who was pretty much tucking me in to bed...... and decided to empty my wallet while rubbing my back
I have a few goodies that will help the truck once she runs.. HAHAHA
She will be 4.5/7 lowered and have some outstanding built parts under her
ECE 2" front drop springs
ECE 5" Rear Drop springs
CPP Bolt in C notch
Shock relocators
KYB Shocks
Mcnaughtys 2.5" Drop Spindles
Porterbuilt Rear Track Bar
Porterbuilt Trailing arms
Porterbuilt Crossmember
Old 09-24-2009, 05:28 PM   #43
vegaschevy
Re: Project NOT4SLE
A few pics of working on it a couple weeks ago since my last pics. Today when I get home I am going ot finish the fuel line and get the rad installed.
Old 09-24-2009, 08:35 PM   #44
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Project NOT4SLE
lookin good
John
1999 Toyota Tacoma 4x4
Old 09-24-2009, 08:38 PM   #45
VA72C10
VA72C10
VA72C10's Avatar
Re: Project NOT4SLE
Good progress...
Old 09-24-2009, 11:10 PM   #46
cheyenne10
cheyenne10's Avatar
Re: Project NOT4SLE
Subscribing. Hoping to watch a few projects this fall/winter.
Amazing how many of these sweet stockers are still driving around.
Bob
cheyenne10 is offline   Reply With Quote
Old 09-25-2009, 12:39 AM   #47
vegaschevy
Re: Project NOT4SLE
got everything back together and she was timed 180 out. That was problem number one. Problem two is she was not getting any fuel at all. I am guessing maybe the fuel pump just so happened to go out on me. Not really sure.
I started it and drover it on to the trailer when I bought it and then although it ran REALLY rough drove it off and into the driveway.
Now on the engine side of the fuel pump no fuel is coming out. Hopefully a new electric fuel pump and she will be good to go.
unless anyone else might have a few ideas.
She did start and run with fuel dumped in to the carb though for about 2 seconds.
Old 09-25-2009, 01:03 AM   #48
VA72C10
VA72C10
VA72C10's Avatar
Re: Project NOT4SLE
Sounds like a bad fuel pump. I did that on my 69 shortbed....only took about 1/2hr and she started up. The other thing to check if you have access to the fuel sending unit is if it somehow got plugged...have you taken the tank line off (into the pump) and seen if the fuel runs out of there?
Old 09-25-2009, 01:03 AM   #49
highperf4x4
Re: Project NOT4SLE
You have an electric fuel pump on it now?
Old 09-25-2009, 01:10 AM   #50
vegaschevy
Re: Project NOT4SLE
no it is the mechanical oem fuel pump.
tomorrow ill pull the lines off and see if fuel runs to the pump. if it does ill pull the pump off and go get a new one.
