Old 10-17-2009, 12:28 AM   #26
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: DP's '66
Thanks man.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 10-28-2009, 10:29 PM   #27
DPowers
DPowers's Avatar
Re: DP's '66
IT RUNS...IT RUNS
Last week got my starter installed after having to switch- the first one I had (3510 MS) for some reason- I could not get it to shim up- took it back and got a new one (3510) and it engaged fine. For a trans xmember- took one from an '81 Camaro. Had to shorten it and re-drill holes in it and the frame. - did that last weekend. Also ran some temporary shorty pipes from the manifolds just to get the exhaust away from the block some. My plan was to get the trans xmember in tonite and then crank it up this weekend. Well I got the trans member in ok and then my buddy says- see if it will at least spark.... Well it did. Fired right up and was sounding good. Ran it for about 10 minutes or so and then went to set the timing. Started to adjust the distributor when zzzzzinggg. In our haste we forgot to secure the cap on the distributor and the metal piece on the rotor went flying... Didn't hurt the cap- so tomorrow will get a new rotor and hopefully finish breaking in the cam. The Edelbrock seemed to be loading up- so I may switch to a Holley. I rebuilt the Edelbrock, but it hasn't been tweaked yet. We will see.
DPowers is offline   Reply With Quote
Old 10-29-2009, 06:12 PM   #28
chris91
Re: DP's '66
Are the frame mounted trans cooler better than the flat ones that you tie strap to the radiator?
chris91 is offline   Reply With Quote
Old 10-29-2009, 09:57 PM   #29
DPowers
DPowers's Avatar
Re: DP's '66
I don't know about better- but I like the looks of it and I am basically using it as an auxillary as the fluid is cooled through the radiator one first.
Replaced the Edelbrock with the Holley tonite and finished breaking in the cam. Had to get a new alternator as my pretty chrome one is bad. I think I bought it on Ebay- so we will see if I can get my $$$ back.
Old 11-01-2009, 11:30 PM   #30
DPowers
DPowers's Avatar
Re: DP's '66
Finished the break-in on the cam and changed the oil. I strained the oil with a paint strainer to check for any dirt, metal etc and it came out real clean. Went with the 2- quart NAPA gold oil filter. Since it is a solid cam, I went ahead and used 30 wt non-detergent oil and added some break-in additive to keep the zinc up. Will change it again at about 500 miles. After the motor got warm, we noticed some water leaking... It ended up being the brand new heater core was defective- I bypassed it and then I pulled it yesterday. It is still under warranty- but a pain to pull. I am going to keep the 600 Holley- it is my buddies so I will just have to replace it sometime. Real happy with the way the motor sounds- you can just barely hear the cam, but you can feel it some as you lean on the fender. Have to finish up my exhaust- still haven't decided about mufflers and also finish hooking up the trans linkage and driveshaft. Going to use some of the leftover braided line to make a fuel line. I also dropped my pretty chrome alternator off to get rebuilt.
Modified cross member from '81 Camaro
A little better view of the trans cooler.
Old 11-01-2009, 11:36 PM   #31
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Re: DP's '66
lookin good
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 11-03-2009, 12:39 AM   #32
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: DP's '66
Congrats on the progress. Lookin' great.
Alan's Classic is offline   Reply With Quote
Old 01-03-2010, 11:41 PM   #33
DPowers
DPowers's Avatar
Re: DP's '66
Haven't updated this thread in awhile.
Old 01-03-2010, 11:47 PM   #34
DPowers
DPowers's Avatar
Re: DP's '66
Drove it for the first time today- up the road and back about a mile. A few bugs, but I am pretty excited.
Old 01-03-2010, 11:49 PM   #35
DPowers
DPowers's Avatar
Re: DP's '66
Some more...
Old 02-21-2010, 04:37 PM   #36
thepartsguy
thepartsguy's Avatar
Re: DP's '66
What is that color you used on the heater box? I like it.
63 C10
65 Chevy Custom Cab w/ Big Back Window
66 C30
72 skylark w/ 454
65 K10
May the bridges I burn light the way....
thepartsguy is offline   Reply With Quote
Old 02-21-2010, 10:03 PM   #37
DPowers
DPowers's Avatar
Re: DP's '66
My sister-in-law works at an auto paint store and they made me up a couple of rattle cans- I will look and see if I can get the paint numbers.
Old 03-01-2010, 07:23 PM   #38
DPowers
DPowers's Avatar
Re: DP's '66
Dark Bronze Metallic #79760
Old 04-14-2010, 11:07 PM   #39
DPowers
DPowers's Avatar
Re: DP's '66
Update- been working on the hood and trying to put the $$ together for exhaust and alignment. The last one is with the guide coat. Going to leave it primer for now and wait to paint the whole truck at a later date- cause I want to drive it!
Old 04-14-2010, 11:15 PM   #40
shortbed70
shortbed70's Avatar
Re: DP's '66
Dang that is some shinny primer...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-14-2010, 11:29 PM   #41
DPowers
DPowers's Avatar
Re: DP's '66
It was still wet when I took the pic with my phone...
Old 04-14-2010, 11:39 PM   #42
Alan's Classic
Re: DP's '66
He cleared it.
Lookin' good. Nice progress.
Old 04-15-2010, 07:56 AM   #43
jason65
Registerd User
jason65's Avatar
Re: DP's '66
Looking good D. Congrats on getting it driveing again.
jason65 is offline   Reply With Quote
Old 04-25-2010, 09:56 PM   #44
DPowers
DPowers's Avatar
Re: DP's '66
Painted the hood over the weekend. We watersanded one of the side cowls with 1500 and buffed it to try and match up the paint.
Old 04-25-2010, 10:36 PM   #45
Alan's Classic
Re: DP's '66
Hood looks really nice. Great work!!
Old 04-25-2010, 11:21 PM   #46
protrash64
Resistance is Futile
protrash64's Avatar
Re: DP's '66
x2
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-26-2010, 01:43 AM   #47
Captainfab
60-66 Nut
Re: DP's '66
X3
Originally Posted by alan's classic View Post
hood looks really nice. Great work!!
Old 05-22-2010, 10:13 PM   #48
DPowers
DPowers's Avatar
Re: DP's '66
Been water sanding and buffing. Set the hood today and washed it.
Old 05-30-2010, 10:35 AM   #49
TennesseeZ
Countdown Survivor
TennesseeZ's Avatar
Re: DP's '66
Lookin' great D, that paint seems to match perfect. I think I'd blend in the places on the door, chunk a grille in, and drive the snot out of her!!
Subscribed, btw my first truck was a red/white '66 Custom Cab longbed just like that. Good memories!
93 Yukon
89 Silverado Z71 SWB Sport
91 K 2500 Silverado "Lobuk-Worktruk"
A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO.
Gettin' old ain't for sissies.
TennesseeZ is offline   Reply With Quote
Old 05-30-2010, 10:44 AM   #50
DPowers
DPowers's Avatar
Re: DP's '66
That's the plan- thanks
