Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 10-05-2009, 05:57 PM   #26
kev2809
low n' slo
kev2809's Avatar
Re: Project 67 DRGNWGN - 67 Burban!!
no inner fenders, and prob dont plan on running any. but if i do i will just custom make some. i do plan on taking both lower and uppers off to blast and paint them
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 10-06-2009, 11:44 AM   #27
Dying2Live
Dying2Live's Avatar
Nice build, I wish I was man enough to deal with the weather... I got my suburban 2 months ago, and it's still parked... I have acquired an engine for it though. Again, nice build!!
Dying2Live is offline   Reply With Quote
Old 10-09-2009, 10:07 AM   #28
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hey Kev, glad to see you got a thread started! I want a burb now.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 10-15-2009, 11:25 PM   #29
Slick67
Sofa King Crazy!!
Slick67's Avatar
Hey Kev! Those black powdercoated emblems look great! The burb looks cool in the weeds! Swing by the shop when ya have some extra time.
Old 10-26-2009, 05:39 PM   #30
kev2809
low n' slo
kev2809's Avatar
damn here goes my build thread, i forgot about it for a little bit lol. ya david, those emblems do look good on there man, thanks for powder coating them for me. im still saving up some more $$ to get my drop spindles and to pay someone to recess some cups in my lca's. i finally got the damn air bag fitting hole drilled, i bought another step bit from lowes ($50, ouch) because i broke the 2 from harbor freight lol. i had to rotate the bag and redrill all my holes because the bolt was to close to the side of the frame and i couldnt tighten it up lol. but i finally got one side done, and when it stops raining i should knock out the other side. this side should only take a day or 2 since i know what im doin now lol. also got my fittings in today except the "t" fittings, so maybe i can start plumbing everything in november..
-_--_--_ _________
Old 10-26-2009, 05:44 PM   #31
kev2809
low n' slo
kev2809's Avatar
heres what my holes ended up lookin like, lol. the top and bottom holes were the 1st 2 i drilled for the bag bolts, and the 1 on the far left was the fitting hole. so i clocked the bag, and the left and right holes are now the bag bolt holes, and the one on top i widened open for my fitting. i switched out the bolts to 1 1/2 " instead of 2" and they still seem to long. maybe get some 1" ones i guess, but that seems too small..
this is why i had to clock the bag...
[IMG][/IMG]
heres the new holes..
[IMG][/IMG]
-_--_--_ _________
Old 10-26-2009, 06:14 PM   #32
wp silverado
nice progress man, i figured id subscribe over here too
1967 c-10-built smallblock, backed by m-21, lowered
2005 silverado-tint, exhaust, lift, 35's
1964 c-10 shortbed project
wp silverado is offline   Reply With Quote
Old 10-26-2009, 08:28 PM   #33
VA72C10
VA72C10
VA72C10's Avatar
I am going to put washers with lock washers on the bolts...maybe that would make up the difference...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 10-26-2009, 08:41 PM   #34
kev2809
low n' slo
kev2809's Avatar
i do have the lock washers in, and 1 huge fender washer for each one, its just not in that picture. when it stops raining over here ill snap a picture and see whats really keeping it from bolting all the way up. i really thought 1 1/2" should be just right...i think i seen 1 1/4" too so maybe ill try those
-_--_--_ _________
Old 10-26-2009, 10:55 PM   #35
VA72C10
VA72C10
VA72C10's Avatar
Let me know because I have 1 1/2"...I am pretty sure I checked with the lower bolt and it went in around 1"...add the thickness of the frame/spring mount/ and the two washers and 1 1/2 should be perfect???
Old 10-28-2009, 11:12 PM   #36
kev2809
low n' slo
kev2809's Avatar
heres a pic i took today of the passenger bag showing the bolts.
[IMG][/IMG]
it was kinda hard getting in there to take a pic because it was wet today, let me know if you need any more.
-_--_--_ _________
Old 10-28-2009, 11:51 PM   #37
VA72C10
VA72C10
VA72C10's Avatar
Weird, did you try it off the truck and see how far they stuck up when completely screwed in? That's what everyone has recommended is the 1 1/2"....I guess 1 1/4 is the way to go???
Old 10-29-2009, 09:34 PM   #38
kev2809
low n' slo
kev2809's Avatar
no i havent but i can. ill try tomorrow after work. i was hoping to get the driver side done today but its still raining down here
-_--_--_ _________
Old 10-30-2009, 12:13 AM   #39
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
When you cup ur LCAs, dont go as deep as my first set, they hung down & drug the ground
They were 3" deep
What I like better is plating the bottom of the LCAs then cut the hole & drop in some 8" pipe then weld it all up
Cant wait to see it down man
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-31-2009, 11:28 AM   #40
kev2809
low n' slo
kev2809's Avatar
you mean plate it up from underneath, drop the pipe in, measure the top to sit flush and cut the rest off then weld it in?
-_--_--_ _________
Old 10-31-2009, 11:49 AM   #41
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
looks sweet!
did it already have disc brakes on it?..
John
1999 Toyota Tacoma 4x4
Old 10-31-2009, 08:24 PM   #42
kev2809
low n' slo
kev2809's Avatar
ya it came like that...
finally got some work done today. pulled apart the driver side and got the 2 top bag bolts holes drilled...hopefully I can get the airbag fitting hole tomorrow before football starts. ill post some pics later tonight
-_--_--_ _________
Old 11-07-2009, 12:21 PM   #43
kev2809
low n' slo
kev2809's Avatar
well, i thought i had it all done untill i started bolting up the u bolt...i didnt tighten the bags yet, but when i jacked up the trailing arm and put in the u bolt, my bag kinda leaned and now doesnt sit flat up against the frame. are my holes off or something?
i guess my little orange template i made wasnt perfect lol..
[IMG][/IMG]
[IMG][/IMG]
-_--_--_ _________
Old 11-07-2009, 01:56 PM   #44
project 67 sub
project 67 sub's Avatar
looks like you need to either tighten the bag bolts down or get some shorter ones
project 67 sub is offline   Reply With Quote
Old 11-07-2009, 04:17 PM   #45
kev2809
low n' slo
kev2809's Avatar
i def need shorter ones, but i just widened one of the bolt holes and sits flush now. before i ran my airline to the t fitting, it looked like bag deflated crooked...but now i ran them and aired it up and down it looks straight. im gonna wash up then snap some pics...
-_--_--_ _________
Old 11-07-2009, 05:52 PM   #46
kev2809
low n' slo
kev2809's Avatar
heres some pics..
driver bag deflated
rear aired up
rear dump
-_--_--_ _________
Old 11-07-2009, 05:56 PM   #47
kev2809
low n' slo
kev2809's Avatar
rear dump, front up
front all up
all up
all down
on the full lift pics, they might go a little higher, but i get nervous on putting more air in. my gauges arent hooked up and i dont wanna blow a bag lol
-_--_--_ _________
Old 11-07-2009, 08:24 PM   #48
project 67 sub
you gonna go lower than that
Old 11-07-2009, 09:04 PM   #49
kev2809
low n' slo
kev2809's Avatar
definitely. I still need drop spindles and recessed cups in my lca's. for the rear I still need drop blocks and to notch the frame...still a lot of work to do!
-_--_--_ _________
Old 11-16-2009, 03:35 PM   #50
brian69longbed
brian69longbed's Avatar
hey you can't cheat like that! letting the air out of the back tire to make it look lower... sheeeesh. ha ha ha. you got a load of work ahead of you. great progress so far!
69' 1/2 ton
LONGBED__
_______ |__\__
|__(O)______(O)]
My build thread:
http://www.67-72chevytrucks.com/vboa...d.php?t=354115
brian69longbed is offline   Reply With Quote
