02-05-2012, 10:53 PM | #26 |
Re: Tri plus oem parts ?
I bought a front bed panel for my 78 that is tri plus key parts and its junk missing two bolt holes the threads are wrong in the square nuts i trimmed the bed and it still didn't fit right good thing this is a work truck
02-05-2012, 11:56 PM | #27 |
I ended up going with tri-plus front fenders for my project. Haven't installed them yet, but feel pretty close in weight as the oem stuff. Stange thing was that they have small Goodmark stickers on the boxes, hmmmm.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
07-28-2013, 09:35 PM | #28 |
Can anyone give me an idea of what companies sell and/or use Tri-Plus parts, etc....???
07-28-2013, 11:36 PM | #29 |
Hey crew, i think they changed their name to top banana. Theyre located in the va. area....ill see if i can get any more info.
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-29-2013, 12:52 AM | #30 |
Found them thank you....
Posted via Mobile Device |
11-06-2013, 01:44 PM | #31 |
reviving a very old chain of posts here because I am debating buying a replacement metal floor for my bed, and wonder if any of you have done this and would suggest one brand over any other for thickness, fit etc? I was already leaning toward tri-plus or Dynacorn....thoughts?
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
11-13-2013, 12:27 AM | #32 |
I just recently finished up some posts in my build thread, on the floor and rocker replacment of my blazer. I haven't finished with the drivers side yet and the outer rocker for it is a tri-plus. So far with that rocker I have a bunch of mods to do to it, to get it to work. However the passenger side one looks like it would fit alot better. I don't know why they would vary so much. And I don't know how good a dynacorn would be, but I don't think it would be worse than the tri-plus. Providing they are the same guage of material. But these are just my thoughts.
71 2wd Blazer My build, Restarted 05 Buell firebolt 94 1500 Z71 No rice for me,,, I'm full |
11-13-2013, 05:55 PM | #33 |
Active Member
This is there new website for parts. They are also on Facebook.
http://www.topbananaparts.com/ |
05-02-2014, 05:55 PM | #34 | |
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
05-04-2014, 08:22 AM | #35 |
The triplus doors I bought for my jimmy wouldn't fit. Couldn't get a gap on the rear. Here is the reason why, the area at the hinge mounting point is formed different, I kept the square set the same on both doors but there is at least an 1/8" difference between the two. Luckily I found a set of nice truck doors and cut them down.
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
05-04-2014, 08:23 AM | #36 |
And the repro
07-29-2017, 12:42 AM | #37 |
Any updates on the Tri Plus sheet metal? Does KeyParts make sheet metal for Tri Plus?
Thanks |
