Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-25-2009, 06:32 PM   #26
chevybuldr
chevybuldr's Avatar
Re: BBC Build and Questions.
Wow if it didnt touch that cylinder wall you got lucky. Mag for sure and if you are going to use the rods over again make sure they check that one to make sure its not bent.
chevybuldr is offline   Reply With Quote
Old 10-25-2009, 07:00 PM   #27
70stroker
70stroker's Avatar
im gonna order forged rods and pistons, but ya i figured i would send the blok to the shop get in magged bored and line honed. It touched the cyclinder by just those scuffs pictured, which i think could be cleaned up after its a std bore now.
Would these heads do ok for my application with the blower and mostly street driven.
http://www.summitracing.com/parts/WR...1/?image=large
70stroker is offline   Reply With Quote
Old 10-25-2009, 09:05 PM   #28
ripdog28
ripdog28's Avatar
They would do fine but are a little small, those are similar to stock size. If you spend that much on them get the DART 308. I spent $1250 a pair.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 10-25-2009, 09:49 PM   #29
70stroker
70stroker's Avatar
were did you get them? part number? I looked on summit, all darts stuff is 1000 each head..
Old 10-25-2009, 10:57 PM   #30
chevybuldr
chevybuldr's Avatar
yea look at aluminum. Think you will be more happy with them.
Old 10-25-2009, 11:58 PM   #31
drag_72
Ready to go fast!!
drag_72's Avatar
Originally Posted by ripdog28 View Post
OK, didnt know you were doing it your self. Your correct on the Forged rods and slugs and proper rings. Green 72 has a good cam just gotta have your valve springs set up for it. Stay away from Alum roller rockers, get some chrome molly ones. Some Super Comp headers should work fine. ALSO, I have heard some bad horror stories about plastic, see thru fuel filters, plastic melts when it gets hot and yours is pretty close to the engine. Get an alum or someother type of filter, i would hate to see that truck burned up.
there is nothing wrong with aluminum roller rockers? who the hell did you hear that from?
454 block .30 forged aluminum pistons
steel crank
valve job
Holley Strip Dominator intake
1030cfm holley carb, 250 plate shot
roller rockers Erson Solid cam split duration 307/310.
.575/.595 lift
milodon oil pan
fab. aluminum valve covers
4 bolt main splayed anodized caps
all studded
drag_72 is offline   Reply With Quote
Old 10-26-2009, 01:25 PM   #32
ripdog28
ripdog28's Avatar
I have seen a 383 with a 8/71 on it pushing 15lbs of boost when it siezed up. the alum rockers had stress fractures in it. Would not happen to Chrome Molly and i know this is extreme.
69 c-10 BBC
Old 10-26-2009, 02:19 PM   #33
ulakovic22
Yes, that is extreme and in the right conditions can probably be said about any part when put in a high stress environment like that. I also agree that a decent set of aluminum heads will be money well spent. With a blown setup you won't need a great set of heads because the air is going to be crammed in there.
ulakovic22 is offline   Reply With Quote
Old 10-26-2009, 07:31 PM   #34
70stroker
70stroker's Avatar
ok back on topic of advice for mybuild
Old 11-15-2009, 02:26 PM   #35
ripdog28
ripdog28's Avatar
what did you end up doing?
69 c-10 BBC
Old 11-24-2009, 05:13 PM   #36
70stroker
70stroker's Avatar
Im still looking for a good bottom end kit for my app. I know my heads are gone i got them magnafluxed and one is cracked so i am looking for new heads. any ideas?
Old 11-24-2009, 07:43 PM   #37
ripdog28
ripdog28's Avatar
Aftermarket Dart/world if you want to stay under $2k, for a blower you dont need alum.
69 c-10 BBC
Old 11-30-2009, 03:36 PM   #38
70stroker
70stroker's Avatar
are 336781 head castings good for my app?
Old 11-30-2009, 04:09 PM   #39
Alex1
Alex1's Avatar
Yes, those are excellent for your application - they're large ovals and can make serious power.
Alex1 is offline   Reply With Quote
Old 12-02-2009, 07:52 PM   #40
70stroker
70stroker's Avatar
Does anyone know what size stock valves were in the 336781 heads? Are they good with stock valve size or shine with larger valves? thanks
Old 12-02-2009, 08:56 PM   #41
Alex1
Alex1's Avatar
They are something like 2.06 or something. It pays to have 2.25 intake valves put in.
Old 12-02-2009, 09:34 PM   #42
70stroker
70stroker's Avatar
Ok guys i went and got the heads. they are 2 different castings but i talked the guy down to 80 bucks for the set so i took them. he said they both came off the same running motor. I dont really want to mismatch but what do you guys think? Or which heads are better so i can find another one of that kind?
first head
336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
second head
353049.....73-84...oval...OPEN...454, 122cc chamber, 255/119cc ports
Old 12-03-2009, 12:40 AM   #43
ProStreet71
I disagree with all do respect. Aluminum heads will help with heat dissapation and detonation allowing you to run more boost which makes more power.
ProStreet71 is offline   Reply With Quote
Old 12-03-2009, 09:28 AM   #44
Alex1
Alex1's Avatar
Agreed, however I don't think the plan is an all out blown motor here. I think it's just a small street blower on low boost.
781's and 049's a pretty much the same - I would prefer the same casting numbers for both heads though - but once worked over they would be pretty much the same.
Old 12-03-2009, 12:56 PM   #45
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
From what I have read on several boards including here, in stock form it seems folks like the 781 as a "really good head" for a street motor, and they seem to like the 049 in a bit better. However, if you are going to massage them and move up to larger valves like 2.19 intakes etc... by the time you are done they will essentially be the same..
I gues it also goes back to the original intent for the motor and your application.
Best of luck, I would go and try to find another of each, then when you decide which way to go, you will have a spare set or good swap meet material
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 12-15-2009, 03:44 PM   #46
70stroker
70stroker's Avatar
Ok guys i found another 049 head so i am in business. but i got a few questions.
If i got .030. over on my bore that puts me at 4.280 I can not seem to find a head gasket thats close to that. the one i found is 4.380. would this work?
http://www.summitracing.com/parts/FPP-1071/
I talked to lunati the other day, got all the parts numbers for camshaft, lifters, valves springs. so i am good in that department.
However what do i need to be looking for for these heads? Bigger valves, what sizes? Also how do i need to figure out what size stems i need? Ill probably have stock size guides put back in unless someone sees a problem with that, again what is the stock I.D. of bbc guides?
thanks in advance guys
Old 12-22-2009, 08:20 PM   #47
70stroker
70stroker's Avatar
bump anyone?
Old 01-20-2010, 12:07 AM   #48
70stroker
70stroker's Avatar
Old 01-20-2010, 12:39 AM   #49
ripdog28
ripdog28's Avatar
Send the heads to the machine shop and have them set them up.
69 c-10 BBC
Old 01-20-2010, 06:30 PM   #50
70stroker
70stroker's Avatar
heres some more parts that came in today.
and my blower powdercoated.
