#26 |
Re: new guy ~ old project (53 chevy)
[IMG]
#27 |
[IMG]
#28 |
[IMG]
#29 |
[IMG]
#30 |
[IMG]
#31 |
Registered Chevy Owner
I can tell the rear isn't stock, but I'm not sure what it's from, and I don't know if the front is drop or not.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
#32 |
That rear end is a GM 10-bolt, looks like A-body judging by the upper control arm mounts on it.
#33 |
is it a decently strong rear end? im not trying to throw much at it but want to eliminate weak links. anybody else have any information on these parts?
#34 |
Depends on what you want to do with it. I thrashed and hammerd stock 10 bolts in the 60's and never broke one, but that was with 215Hp 283's. When I got a real engine I switch to an Olds rearend. My 64 Chevelle has a approx 325 HP 350, TH350 and stock ten bolt with 3.08 gears. I don't abuse it but have launched it hard on 235 wide tires without any problems. For everyday use they are fine, lots of stock 60's muscle cars, Vettes, etc. came from the factory with them. They can be upgraded with stronger gears, bearing, axles, posi, etc. if you want to use the housing.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#35 |
im gonna keep the 235 and put a vette manifold on it. nothing too special. so ill keep it as long as it will hold. whats the cheepest way i can get low? should i just remove some leafs? can anybody tell me if this is a drop axle?
#36 |
that is not a dropped front axle. you can however buy a dropped axle from speedway for a good price or go to droppedaxle.com
1969 c-10- daily driver(sold) 1950 chevy 3600 current project http://67-72chevytrucks.com/vboard/s...d.php?t=402562 1955 ford f-100 1968 ford mustang 1966 ford mustang |
#37 |
yep kulturekat is right. your front end is bone stock. i have a 53 as well. welcome to the forums!
53 Chevy 3100 1/2 ton 1st Armored Division, OIF Veteran ![]() |
