#26 |
One day...
Re: Tail light gas filler
Thats a real cool idea, i have seen a few done that way.
Um yeah thats a CHEVY bed on the blue truck.. |
#27 |
Jonny
I'm planning on doing this with a 40 gal suburban tank. I want to set up the dual tanks on my truck so that one pulls from the side tank, which will have diesel, and the other from a tank at the rear, which will have WVO.
Just a little info for you guys who may not be familiar: In order to run veggie oil it's neescessary to warm up the motor first, then you can switchover. Since I'd be running the oil for 90% of the time it makes sense to have a bigger tank. I'm also thinking of re-routing the filler for the saddle tank and putting it in the wheel well.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
#28 |
Location: Where I come from, it's cornbread and chicken...
you might want to think about getting a poly tank for that 40 gallon burb tank...the metal tank will form a 'chicken skin' so to speak on the inside of it....just fyi...
I'm planning on doing the same thing on my truck also... how exactly did you do the two tank setup without the switching valve...is it self fill the other tank by itself, or do you have to do it youself |
#29 |
Jonny
I plan on doing it with the stock switching valve. I thought about putting a temp switch on the engine to activate the valve so it would automatically switch once it was up to temp. I haven't really looked into that, yet.
#30 |
Are there any more pics of the gas tank behind the tail light??? This would be perfect for my suburban
#31 |
Building Dreams out of Dimes!
Just wanted to bump this thread to see if anyone else has attempted the Tail Light Gas Filler...
Too call not to be done! |
#32 |
So is there a bracket out there to do this? I'm sold if its an easy install.
#33 |
#34 |
#35 |
#36 |
x3. IŽd be interested in that oo. Especially if there was a easy bolt or weld on kit to do this.
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
#37 |
78K & 79C Jimmys
I had to look,a friend had a 57 said it was in the fender,had not seen this either
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#38 |
That looks like a 56 tail light
1951 Styleline Deluxe 2dr 1957 Belair 4dr 1975 Scottsdale 1979 Silverado 1987 Silverado 1987 Cutlass Supreme (For Sale) |
#39 |
78K & 79C Jimmys
yup,thats google for ya,couple of nice ones here
