07-11-2018, 01:15 PM | #26 | |
Posted via Mobile Device |
07-14-2018, 01:38 AM | #27 |
Re: dual tanks with late model EFI?
The later model c10s from i think 83 to 87, i have a 86, the transfer valve can handle up to 65 psi iinstalled a msd efi on my 86 put a pump in each tank and wired the power to the pump through the switch on dash using an 87 switch, if you have an 87 should be easy the early model c10 had a low pressure valve but new is good to go
01-05-2020, 03:23 PM | #28 |
Another run at the top.
How about using in-tank TBI pumps, through external filters, then to the switch tank valve, then into the high pressure pump, the to a regulator, then into the fuel rails?
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
01-05-2020, 03:40 PM | #29 |
I have about 20k miles on the dual tank setup in my 74. Used EFI tanks with the pumps in the tanks, the soft EFI rated fuel line to the high pressure valve, then to a corvette fuel filter regulator, then a single line up to my LS rails. I can switch tanks on the fly without even noticing.
The only issue I’m having now it that my newly installed Dakota digital RTX gauges don’t seem to like the fuel signal going through a switch so it doesn’t read correctly. Had no issues with the stock gauges. I track my mileage(~20mpg) so it’s not a huge deal right now but I need to figure it out.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
01-05-2020, 03:49 PM | #30 | |
I have the VHX Dakota dash and haven't had any issues with the fuel gauge.
01-05-2020, 05:30 PM | #31 |
It’s been so long since I did the swap but I’m pretty sure I used the TBI fuel pumps I’m my tanks. I previously had an in line walbro and hated it. Too loud. There is no reason to feed an in line pump with an in the tank pump. Your just over complicating a pretty simple system.
01-05-2020, 05:41 PM | #32 | |
I appreciate your response, but how am I overcomplicating when I just wanna add a single in line pump to an existing setup? Seems like the LEAST complicated (and most cost effective )way to get it done. Fuel pump noise doesn't bother me, most can't be heard when the vehicle is running anyway. I am running dual Bosch 044's on my turbo K5 and a Magnafuel 1000HP rated pump on my drag car. That pump is loud, like 2 stroke chainsaw loud.
02-09-2020, 07:37 PM | #33 | |
02-12-2020, 10:17 AM | #34 |
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
02-12-2020, 02:01 PM | #35 | |
Moderator
A surge tank system uses the in-tank pumps as lift pumps to keep the surge tank filled. The stock pumps will flow more GPH at the lower pressure demanded to keep the surge tank filled. 5-7PSI is what I'd guess the pressure in the surge tank will level out at. I bet the TBI pumps that normally run twice that pressure will flow plenty of fuel to keep the high pressure pump happy. They'll run cooler with the higher flow and lower pressure as well. You can build your own. The surge tank should have four fuel lines. -A feed and return to-from the engine for the high pressure EFI system. You'll get more fuel returned than you might think. -A low pressure fill and return from-to the tank(s). -A high pressure fuel pump. You should be able to mount the surge tank in the engine bay to keep it safe from road debris. Tuck it down by the battery tray and the radiator support to hide it. You can run the stock dual tank valve and lines with a modern EFI setup using this configuration. As noted earlier on. You could also use the stock dual tank setups from the LS powered vans that used the PCM to control the tanks as if they were one tank. You'll likely have to roll your own fuel pump/sender module mount for the donors fuel pump/sender modules.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-12-2020 at 02:12 PM. |
02-12-2020, 03:29 PM | #36 |
thanks hatzie!
