02-10-2010, 03:56 PM | #26 |
Re: I want to spin both tires
a 12 bolt is a semi-floating axle. the axles are held in by c-clips that go on the ends of the axles where they meet the carrier. a full-floating axle has outer hubs, and you can remove the axle shafts without even taking off your wheels or jacking your truck up. in my opinion, a semi-floating 14 bolt is a waste of time, and the extra strength over a 12 bolt isn't enough to make the swap worth it. plus, i don't know how much a semi-floater weighs, but a full floating 14b weighs almost 600 pounds IIRC. I just think a differential swap is wayyyy overkill in your situation unless you ever plan on putting huge tires on your truck. If you're on a budget, just get a lock-right and stick with that for now. They're under 400 bucks. I'm not denying the strength of the 14 bolt, but not everyone needs one, especially high school kids on a budget. Just my .02
amcgeh01-look in 88-95ish "heavy half" chevy trucks. They had 14sf axles. Someone else will probably chime in with the exact years they came in. And i don't think you can limp home on one axle on a semi-floater, just the full floater, which is an 8 lug axle.
1970 GMC 4x4 swb fleetside custom 4 inch lift with rear shackle flip, mild sbc, tci trans, rebuilt np205 w/twin shifters Last edited by yellow70GMC; 02-10-2010 at 04:10 PM. |
02-10-2010, 04:48 PM | #27 |
personally spinning 33"+ tires on pavement is asking for trouble with any axle... but it's not my truck or money...
Benelli, is this thread concerning pavement or mud?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 02-10-2010 at 04:49 PM. |
02-11-2010, 02:39 AM | #28 |
Watchin the rust grow
Mike, It's concerning mud. Two of my friends have Ford explorers with positraction systems in them and they give me plenty of crap for only spinning one tire when I get high centered.
I don't do the whole burn out thing. I guess I used to, but I'm over that now. A careless driving ticket causes you to grow up awful quick. I think I'm just going to go ahead and do the lock-rite right now, and if I decide to step it up to 35's someday I'll swap to a 14 bolt, that's a long, long ways off from now though. The motor is Not stock but I don't think it's quite as ballsy as to demolish an axle unless I'm doing something stupid, 9.5:1 Compression ratio, .46 intake cam (not sure on duration), 650 CFM carb, Alum intake manifold, boared .060, headers, I rebuilt the transmission and part timed the transfercase, I'm just working my way around the truck. After the axles I plan on patching the rust holes and maybe repainting the white.
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000) 1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000) 1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850) 1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done 2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now Underneath that rust is a heart of gold
02-11-2010, 02:47 AM | #29 | |
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
02-11-2010, 09:44 AM | #30 |
A good way to go is with a 73up 14 bolt Full Float. That's what I used. You might get lucky and find one with a limited slip, but better off to go to a detroit locker. I don't know about a 6 bolt option though.
Just another opinion. Sorry if someone already mentioned this. Doug
68 CST 396, 60K original miles 70 Longhorn project 72 Stepside (150% complete) 67 Stepside project 71 RS Camaro 90% done 71 BB Corvette 50% complete 78 K5 project |
