11-03-2014, 03:44 AM | #26 | |
Re: AC POA Valve Update
Sanden: Smaller, lighter, more efficient and much more durable. Win-win. |
11-03-2014, 09:47 AM | #27 |
I bought a Haynes A/C Manual and learned to do my own A/C work, to avoid constant trips to the A/C shop. My 72 Cheyenne has the same A6 compressor as when I bought it in 2003. I had the POA adjusted for 134a, new dryer and expansion valve and my A/C has worked fine in south Florida for over 10 years. My 1972 Cutlass, same set-up but also with a cross flow condenser pumps out 30 degree air from the vents. Also, same A6 compressor as when I bought it in 2006, and it hadn't been replaced in the 4 years the previous owner had the car.
I have a 1970 Bonneville that I am rebuilding. Classic Auto Air in Tampa suggested I get a rebuilt A6 right before I install it. The seals have a tendency to leak if they sit on the car or on the shelf and not used. Even a brand new seal can go bad and leak if the system is not charged and used. |
11-03-2014, 03:31 PM | #28 | |
A6 compressor is big enough to cool a small house and it's the only compressor I've ever seen with it's own oil pan and oil pump. Some shoddy re-builders have given others the impression that they are not good, but really they are very good. I just think their day has came and went, too big and too heavy with a small clutch diameter that makes for a weak clutch that does not hold up well on a cycling system. I have a question for you that I've tried to research to no avail. Is there a different expansion valve for 134A? |
11-03-2014, 05:30 PM | #29 | |
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
11-03-2014, 05:35 PM | #30 |
Not sure who says an A6 can't be used cycling. I had a '77 and a '79 Pontiac Bonneville with A6 compressors and pretty sure both had cycling systems. The '77 had almost 300,000 miles on the original compressor. Ford also used them. We had a '79 LTD that had an A6. I don't know if it was cycling or not.
I have installed a few of these kits with no big issues. Put on a '71 C10 and a '67 Firebird. Both still going fine as far as I know.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
