Old 05-17-2010, 04:13 PM   #26
57 3100
57 3100's Avatar
Re: Lets see lowered beam trucks..
Originally Posted by Dave K View Post
You will also need to move the brake line so the drag link will not tear it off. Easy to do just drill a hole a little higher on the frame.
maybe because mine is only a 3 inch dropped axle, but i didnt have to move my brake lines.
dave, did your mono leafs give you a true 3 inches of additional drop ?
how much travel do you have between the axle and frame ?
would you happen to have a pic of that area ?
thanks.
leonard
57 3100 is offline   Reply With Quote
Old 05-17-2010, 04:34 PM   #27
57 3100
57 3100's Avatar
Originally Posted by b00sted View Post
Where did you get th e3" drop mono leafs at? i did not see them on sids site..
here are a set
http://www.performanceonline.com/sto...cat=767&page=1
but you can get them from a few different places..
leonard
Old 05-17-2010, 06:39 PM   #28
Dave K
Dave K's Avatar
thanks.
leonard
Yes they gave at least 3" but there is very little travel and the axle slams into the frame on medium+ bumps in the road. My monos might be kind of tired and desprung because I got them used. I am going to put a notch in the frame at some point.
I will take a picture of the spring to frame clearance when it stops raining .
Dave K is offline   Reply With Quote
Old 05-17-2010, 06:44 PM   #29
Dave K
Dave K's Avatar
leonard
You need to move the brake line if you run a 4" drop axle and mono leafs together. With a 3" axle and monos you might not need to but if you ever add the monos I would check to make sure
Old 05-17-2010, 07:08 PM   #30
57 3100
57 3100's Avatar
thanks for the help dave... lots of good info.... one day i have to drop mine a little more.
leonard
Old 05-17-2010, 10:27 PM   #31
chevynutt58
chevynutt58's Avatar
hey dave do you have any pictures of your axle with the casters shims installed?also did you have any problems with your tie rod hitting the leafs?
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=396157
chevynutt58 is offline   Reply With Quote
Old 05-17-2010, 11:07 PM   #32
Dave K
Dave K's Avatar
I don't have any pictures of the shims installed. I don't think my truck is a good example anyway. When I got my used mono leafs they had a 4 deg. cast shim with them but I believe Sid recommends 6 deg. so I just added the stock shim to the 4 deg. shim to get as close as I could to 6. Kind of hokey but it was like night and day how much better it drives with the added 4 deg. over when it only had the stock shims. If you are going to add caster shims check with Sid and see what he recommends and you can order the correct shim.
The steering arm has no problem hitting the leaf as long as you have the steering arm flipped and you have the caster shims
Old 05-18-2010, 04:24 AM   #33
57 3100
57 3100's Avatar
Sid taper reamed the steering arms for modern tie rod ends, and reversed the taper so the tie rod now mounts from the bottom, to clear the leafs. the tie rod now runs under the leafs.
you can kind of see it here.
http://s251.photobucket.com/albums/g...t=DSC01376.jpg
http://s251.photobucket.com/albums/g...t=DSC01550.jpg
leonard
Old 05-18-2010, 10:39 AM   #34
b00sted
b00sted's Avatar
hey dave where did you get the used mono's? My pockeets are not real deep right now and those new ones are a bit pricey...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 05-18-2010, 08:33 PM   #35
Dave K
Dave K's Avatar
A buddy of mine who builds lots of trucks wound up with the monos on trade, he also hooked my up with my drop axle 6 years ago. I have a very very small budget so it has taken me 9 years to get to where I am on my truck. It is frustrating as hell to have to wait for the parts to show up at the right price but they always do if you hold out.
Old 05-30-2010, 03:16 PM   #36
51 Hotrod
51 Hotrod's Avatar
Here is my 51..... I just got the 4" drop axle from Sid installed, removed three leafs from stock worn out springs, rear is 3" lowering blocks. Still need to adjust steering box as this truck wanders all over the road, but its still a blast to drive!! Tires are 205/15's in the front....
51 Hotrod is offline   Reply With Quote
Old 05-30-2010, 03:24 PM   #37
57 3100
57 3100's Avatar
wow. thats low. looks awesome man.
could you please take a pic of the leaf to frame clearance up front ?
i am wanting to remove another leaf or two from the front of mine too.
thanks.
leonard
