01-26-2013, 02:35 PM | #26 |
Re: My bolt in Bear Claw latches
My thoughts also. Are AD latches not as secure as TF latches? It seems to be mostly AD owners who are changing.
01-26-2013, 03:33 PM | #27 |
01-26-2013, 11:46 PM | #28 |
Hollister Road Co.
When i was learning to drive a few years back I was learning in a field with my grandfather 51. I went to make a turn and hit a hole the door popped open and I was out on the ground on my backside.
I think the price is fine and bear claws are the way to go unless you like the thrill of leaving a moving truck backwards. |
01-27-2013, 12:19 AM | #29 |
Yeah we've talked about this before. If you grew up in the 60's riding in 50's cars or trucks you know stories of people, kids, dogs, groceries falling out of them.
The amazing thing is I've only ever heard mostly funny stories and never the tragic stories you'd think would go hand in hand with this kind of thing. Which is why I want to be double extra careful about my TF. Yeah, its a bunch of money but I bet it sounds pretty damned cheap compared to what MIGHT happen if a door came open at speed. |
01-27-2013, 12:21 AM | #30 |
is it because the ad trucks chassis flex that makes them open. if so what about when they are boxed in
01-27-2013, 01:11 AM | #31 |
thanks for the picts,, saving up now....
01-27-2013, 11:26 AM | #32 |
This is the exact reason I am investing in a set.
01-27-2013, 12:50 PM | #33 |
Yeah Coach, it just seems to me like (relatively) cheap insurance much like us pulling the gas tanks out of our cabs and installing safety belts. Will we ever have a fire in the cab? A violent collision? Chances are, no. But do you want to potentially stake your LIFE on it?
Posted via Mobile Device |
01-27-2013, 02:05 PM | #34 |
any worn out latch may pop open, i've had doors pop open on doors with sagging doors and worn out latches too, but never with new latches.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-02-2013, 04:42 PM | #35 |
Dan,sorry for the long wait,here some TF install pics..
02-02-2013, 11:02 PM | #36 |
ALL59, Thanks for the photos. How easy/difficult was the installation? Any tricks or suggestions?
02-03-2013, 08:16 AM | #37 |
If you're a tight a$$ like me, you might buy some bearclaws off of Ebay like this @ $34.95:
http://www.ebay.com/itm/Large-Bear-C...ab2af2&vxp=mtr Then try this: Then this: I made a spacer and put it inside the jamb pocket so the sheet metal wouldn't collapse when I tightened the striker up. It took a little time, but I have bearclaws for less than $50. (Ogre, you have plenty of yellow paint left, don't you?) This setup is compatible with blackdiesel's one-piece window setup, and I added power door locks that mount inside the door, just above the upper hinge.
Bob "It won't take long and it won't cost much." '55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed) Bob's Retirement Build - My 55 TF Bob's 700R4 Build (how-to) |
02-03-2013, 12:23 PM | #38 |
I admit LOVING the idea of $34.95 vs. $349, but I admit to not really having the fabrication chops to pull it off. For myself I think I'll go with the Trique setup just for ease of installation and reliability.
Looks like you pulled it off successfully though. Big congrats to you! Posted via Mobile Device |
02-03-2013, 12:38 PM | #39 |
Hollister Road Co.
Personally I think with the Trique kit you don't have to fab the outer handle mechanizim, the lock plate or the inner handle. You could easily take a day or two if your not inclined just to fab all that up. If your into making each piece that goes into you truck then the $39 kit is the way to go but if you have other things to do then I like the kit from Trique
02-03-2013, 01:58 PM | #40 |
I agree that the Trique kit is pretty "trique". I've just been trying to get better at fabbing stuff, so I went for it. If I bought everything on this truck that was screwed up I'd go to the poor house!
02-03-2013, 03:21 PM | #41 | |
02-03-2013, 05:37 PM | #42 |
They're power, remote operated, no handles inside or out. Emergency cables run to the top of the kick panels inside and to the wheel well outside.
02-05-2013, 04:03 PM | #43 |
Dan,its a real easy install I think it took about 1 hr per side taking my time.
02-05-2013, 04:31 PM | #44 |
I had to go and do everything backwards ... I wanted to be able to mount my door poppers in the cab corners. Don't remember want brand the bear claws were as this has been done a while.
02-05-2013, 04:50 PM | #45 |
I will make the change. My old 54 i had opened several times. To me personally its worth the money.
02-05-2013, 05:01 PM | #46 |
Nice job! That outside-the-box thinking really works!
02-05-2013, 05:21 PM | #47 |
Yep, the only thing is with nothing in the door opening the doors will be operated by a button for the popper for day to day use, and then a small release handle mounted in the corner for an emergency.
02-05-2013, 05:58 PM | #48 |
if i did bearclaw latches, i'd do it like bcubed did
nice install bcubed
02-08-2013, 08:43 PM | #49 |
hey brit if u take an turn your handle machnizim up side down your door latch rods will fall in the channel an it looks better an when u put your door panels on your rods want bind on them, mine did so i turnd mine upside down an they work perfect, u cant go wrong
04-04-2016, 11:18 PM | #50 |
I didn't see a part # on the Trique website for a 1972 C10. Which one do you use?
Shawn 1972 C10 Custom LWB, 3-speed automatic, 350 bored .060 over, Vortec heads, Crane Energizer 260 H10 Cam My Beater/Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=502044 |
