Old 06-06-2010, 04:48 PM   #26
RocketKing
RocketKing's Avatar
Re: The Fuse is Lit...
Thought I would put the TJ jeep springs in..
I had read that they fit very well in the stock location but I was still surprised by how well they fit.
Since I had the heavy duty springs out back, the coils were very thick and the jeep springs were much smaller diameter. That lead to quite a bit of slack between the frame and spring as you can see here...
I am sure that most of the slack would have been taken out when tightened, but I did not see the need of it if I could tighten it some. So, I massaged the coil retainer with a great big hammer.
First I flattened the middle and then around the edges to make it more level
ended up with this
In these pic you can see how that the fit is much better
and final fit looked good as well
As you can see I also took a pic of my high dollar fluid retainment system, if anyone is interested I could hook you up for a small fee
I also have the lowering blocks on and I will try to post some pics of that later.
Hope you like it!
RocketKing is offline   Reply With Quote
Old 06-06-2010, 06:50 PM   #27
VA72C10
VA72C10
VA72C10's Avatar
looking good. So are those the blocks in the last pic?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-06-2010, 09:10 PM   #28
RocketKing
RocketKing's Avatar
yep, I have more pics of the blocks but I have not got them up yet.
Rex
Old 06-07-2010, 04:59 PM   #29
RocketKing
RocketKing's Avatar
Here are the pics of the lowering blocks
I went to my local scrap yard and bought a piece of square tubing that was 14" long ($3.00) and then cut it in half and then measured (two or three times) and drilled holes for the u-bolts.
I had the u-bolts made at a local truck shop, 3/4" rod with 3 1/2" interior width and 10" long. I could have used a shorter length but I want to trim it to size in case of scrub line issues. I also took off the nuts that came with the u-bolts and replaced them with grade 8 nuts that gave me more clearance.
This is what I ended up with. I have never done this before but it went together easy enough and so far has not fell off so I am going to deem it a sucess
Rex
Old 06-07-2010, 05:05 PM   #30
67cheby
67cheby
67cheby's Avatar
keep up the progress
67cheby is offline   Reply With Quote
Old 06-07-2010, 05:13 PM   #31
JimmyFloyd
Looks great. where did you find the Suburban for $1000? I need to find one of those.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-07-2010, 05:28 PM   #32
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress and nice build! Also, your welds on your gusset on your frame look really nice too!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-07-2010, 05:53 PM   #33
RocketKing
RocketKing's Avatar
No kiddin'. It came up for sale on a local radio station here in town. Guy was asking $1500 for it, he was trying to shoe horn it into his '70 el camino. He said that it would not fit and was going back to the original motor.
I did not have the 1500 but we worked out a deal that I gave him 1000 and he kept the interior. He was happy and so was I!
I am like everyone else who usually just hears about great deals like this and never finds one himself. I guess God just decided it was my turn!!
Rex
Old 06-10-2010, 10:17 AM   #34
67cheby
67cheby
67cheby's Avatar
Hey Pm me your address, i finally dug out this other seat belt buckle for you, thanks again
Old 06-11-2010, 12:24 AM   #35
mcbassin
Still Learning
mcbassin's Avatar
I really like the "Cherry Bomb" project! Just about everything you have done reminds me of some of the things I have done on trucks over the years. I didn't have any idea a 91 burb setup is that close. keep up the good work, I'll be watching for more ideas.
mcbassin is offline   Reply With Quote
Old 07-06-2010, 11:06 PM   #36
RocketKing
RocketKing's Avatar
Okay, I admit it... I painted my frame too quick.
I thought I was about ready to put the cab on, so I redrilled for the back mounts.
Then I installed the 2 1/2 drop spindles from GMC Pauls
I was going to do some more painting and touch up...
but this is when I made my mistake... I could not help but wonder if a '80s Blazer tank a friend had would somehow fit under the bed. I did a search and sure enough... LFD had already been there done that. To top it all off while I was searching for that info I came across the pics of cutting through the crossmember for the exhaust.
I am either going to have to quit reading this site or just stop fighting and let the madness take over.
Rex
Old 07-06-2010, 11:12 PM   #37
RocketKing
RocketKing's Avatar
I know the holes look pretty rough but my bit blew up about 2/3 of the way through... exciting yes, but at least I did not catch myself on fire again.lol
A little filing and grinding and she will look good.
I also did a little mock up for the gas tank. I have not quite decided which way I want it... I just know I want it!!
Things are gonna get ugly with the panhard bar...
Rex
Old 07-06-2010, 11:53 PM   #38
mcbassin
Still Learning
mcbassin's Avatar
I like the tank idea, but like you said, the panhard bar? Whats the plan?
Old 07-07-2010, 12:12 AM   #39
RocketKing
RocketKing's Avatar
Good question, and one I don't quite know the answer to yet.
I could try an adjustable panhard bar with one end attached to the walking arm and them fab a bracket that hangs lower than stock on the frame side.
I have also heard some have put the panhard in front of the diff. although I have never seen it done.
Rex
Old 07-07-2010, 09:48 AM   #40
67cheby
67cheby
67cheby's Avatar
your idea on the panhard bar would work just fine, just build a bracket to come down some from the frame and run the long panhard bar... i feel your pain on the frame i have had mine completely done 2 times now working on the last time !!!! lol
Old 07-18-2010, 10:31 PM   #41
RocketKing
RocketKing's Avatar
Starting working on the cab this weekend. Tore out the rocker panels and what do I see...
Yep, the old Expand-O-Foam. Spray a little foam, apply a little bondo and paint your way to a new rocker... well, at least for a while.
At least it comes off easy.
Rex
Old 07-19-2010, 03:04 AM   #42
67chevy1series
67chevy1series's Avatar
nice build ill be watchin this one
67chevy1series is offline   Reply With Quote
Old 07-19-2010, 09:29 AM   #43
67cheby
67cheby
67cheby's Avatar
bout time you got back to work
Old 07-19-2010, 09:32 AM   #44
67cheby
67cheby
67cheby's Avatar
were you in Branson sunday ?? at Olive Garden by any chance ??
Old 07-19-2010, 10:13 AM   #45
RocketKing
RocketKing's Avatar
Yeah! Were you there?
You could have bought me that steak dinner. hahaha
Rex
Old 07-19-2010, 10:50 AM   #46
67cheby
67cheby
67cheby's Avatar
i told my wife..hey i know that guy, but i couldnt place where (geez im getting old) when i got on line this morning i said ...dang thats who it was , you walked right past my table... dang my bad memory...What steak Dinner??? i thought we agreed on MCdonalds
Old 07-19-2010, 11:23 AM   #47
drjeffdc
drjeffdc's Avatar
Inspirational, I'll be watching yu. I just started cutting down a chasis for my ol 71 this past weekend, got it all cut down and welded up. She now a short bed, Was tempted to go a couple inches shorter than normal short bed but wasn't sure how it would really look. Decided to stict to the norm as this is my first C10. I'll have to get her blasted and painted now.
drjeffdc is offline   Reply With Quote
Old 07-19-2010, 12:23 PM   #48
brn agn
brn agn's Avatar
Looking good! Subscribed!
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 07-19-2010, 03:57 PM   #49
RocketKing
RocketKing's Avatar
Congrats!!Looks good.
Yeah, my buddy tried to talk me into taking the whole 20" out of the front of the bed. I told him you realize that would put the wheel well in the middle of the bed. He said " yeah, it sure would be different." I told him that different does not always mean better. lol
Some people like that look and more power to them, but like you, I am more traditional (says the man who just hacked his frame, and moved his gas tank, and modified for exhaust)
For the record my buddy still thinks I am nuts for not going his way.
Rex
Old 07-19-2010, 04:01 PM   #50
RocketKing
RocketKing's Avatar
No way! Man, I wish I would have seen you. I was to concentrated on some Chicken Polenta to be aware of my surroundings. lol
Don't worry though...most people don't acknowledge me in public anyway.
Rex
