Old 07-20-2010, 07:47 AM   #26
Alvin
Never Done?
Alvin's Avatar
Re: Ethel: The Legend Continues...
Originally Posted by lowdownstar View Post
Love the truck! those wheels fit that truck to a tee. Do you know what size they are and the BS on them? Good luck with her
Thanks Ray
Thanks! Sure do!
Originally Posted by Alvin View Post
American Racing Torq-thrust Originals (Series VN309 according to the American Racing website). Purchased from http://myworld.ebay.com/eliteswheels. 17x8 all the way around, 4.5" backspacing, 255/50 on front, 275/60 on rear. Rear tires are a little too wide and rub on the inside of the bedside when aired out, so I have the narrower 6 lug axle to convert to 5 lug and install rear discs that will hopefully pull them "in" enough to fix the rubbing.
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 07-20-2010, 07:49 AM   #27
Alvin
Never Done?
Alvin's Avatar
Originally Posted by Big J View Post
Glad to see ya puttin' time in on it. I know your as ready as I am to be behind the wheel instead of behind the wrench, lol.
I sure am! The wife and I ran through the budget last night.. August is not looking good for buying truck parts! Hopefully I can sell some things so I can get this big stuff out of the way.
Old 07-22-2010, 03:09 PM   #28
68Stepbed
68Stepbed's Avatar
What drop is on it in the pics on the trailer bringing her home? Do you have any shots of it aired up to ride height? Id like to see how those wheels would look with a static drop. I really like them but would rather run 17x9.5's in the rear of mine.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 07-22-2010, 03:52 PM   #29
Alvin
Never Done?
Alvin's Avatar
At this point I don't have pics of ride height or any idea what the static drop equivalent would be. However....
If I remember correctly, board member see ten has exactly the same specs on his front wheels and tires. I seem to remember his rear wheels being 17x9.5 too. He is static dropped 4/6 I think. I tried searching but since I'm not a subscriber I don't get too many results.
Old 07-29-2010, 11:47 AM   #30
heymoe
heymoe's Avatar
Looks killer! I am not to far away if you need a hand sometime. I could also use some pointers if you are ever near the Trenton area.
heymoe is offline   Reply With Quote
Old 07-29-2010, 12:52 PM   #31
1LoC10
Insert Title Here
1LoC10's Avatar
looks great, glad its home
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-29-2010, 01:00 PM   #32
Alvin
Never Done?
Alvin's Avatar
Thanks guys! Unfortunately, things are pretty much at a stand-still for now. Waiting for funds to get a rebuilt caliper for the driver side, and then I can bleed the brake system. Trying to come up with other things I can do that don't cost money, but the heat and humidity have been keeping me inside anyways.
Old 07-29-2010, 10:41 PM   #33
KMACD71
KMACD71's Avatar
Here's a link to Seeten's info. Page 6 if it doesn't take you directly there.http://67-72chevytrucks.com/vboard/s...=143835&page=6
KMACD71 is offline   Reply With Quote
Old 07-30-2010, 09:36 PM   #34
Alvin
Never Done?
Alvin's Avatar
Today, with the help of a friend, I was able to get the Lokar cable shift linkage installed. It still needs adjusted, but it's in and works! Also took a look at some of the other things coming up. Tomorrow morning I'm measuring for drive belts and hopefully picking up a caliper for the driver's side. We'll see...
Old 07-30-2010, 09:56 PM   #35
smbrouss70
smbrouss70's Avatar
Could you post some pictures of your cable shift setup? I'm getting ready to tackle that project on mine.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-30-2010, 10:14 PM   #36
Alvin
Never Done?
Alvin's Avatar
I'll get some pics tomorrow and post 'em up. It really wasn't too awful to do. I opted to loosen the steering column and push it into the engine bay about 3/4" so I could mount the aluminum arm. Only a few seconds with a dremel to remove the bumps on the column and it bolted on. Then it was figuring out the best way to orient everything to get full swing on the lever on the trans. Pictures will help explain it.
Old 07-31-2010, 03:40 PM   #37
Alvin
Never Done?
Alvin's Avatar
Frustrating day of trying to get things done. Got a caliper for the driver side and some belts. Belts wound up being too short (my first time measuring for belts). Had some trouble connecting a line, also did not like how the front braided stainless hoses fit at all. Now I have a half-bled master cylinder sitting in the garage leaking (thanks plastic fittings). Just nothing seemed to go right.
Old 07-31-2010, 10:04 PM   #38
heymoe
heymoe's Avatar
Hang in there bud you will get it done.
Old 08-02-2010, 06:34 PM   #39
VA72C10
VA72C10
VA72C10's Avatar
keep at it! we all have "those days"
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-03-2010, 01:30 AM   #40
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet, glad you finally got her home
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 08-06-2010, 07:15 AM   #41
Alvin
Never Done?
Alvin's Avatar
Well I've been sick as a dog since Saturday evening. Finally starting to feel a little bit better today. I do have pics of the shift linkage on the steering column. I'll try to get those uploaded today.
Old 08-06-2010, 09:15 PM   #42
Alvin
Never Done?
Alvin's Avatar
Here's the pics of the shift linkage arm installed. I had to push the column into the engine bay a little bit so I could mount the arm above that collar. My battery died after these two pics, so I'll try to get better ones soon.
Old 08-06-2010, 09:38 PM   #43
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
those cables are nice, again I love your truck!
John
1999 Toyota Tacoma 4x4
Old 08-07-2010, 03:45 PM   #44
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I have one of the Lokar cable shifters on my Truck & I dig it
Looks good bra
Sinister
Killer
Old 08-11-2010, 01:07 PM   #45
JRBECK64
Thats a great idea, I really like the shift cable. I take it that it goes to a shifter thats on the floor? Great lookin Truck!
JRBECK64
JRBECK64 is offline   Reply With Quote
Old 08-11-2010, 01:27 PM   #46
Alvin
Never Done?
Alvin's Avatar
JRBECK64
In the pics I'm showing it mounted to the steering column. The other end of the cable connects to the transmission. So this is for the stock column shifter. I have a couple more pics to upload showing that end of things, but they're on my home computer.
Old 08-11-2010, 01:44 PM   #47
smbrouss70
smbrouss70's Avatar
I had to push my column into the cab more to be able to get the Borgeson u-joints to not bind up while trying to get around my upper control arms on a camaro subframe that is in my truck. I'm hoping that I have enough room for my cable set-up. I guess I better test-fit it soon.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 08-12-2010, 02:06 AM   #48
huero
1969 Short, Fleet, and Beat
huero's Avatar
Yes! I love pics of that truck. Keep em coming Alvin
huero is offline   Reply With Quote
Old 08-12-2010, 12:24 PM   #49
lil hoodlum
lil hoodlum's Avatar
Great looking truck!! I absolutely love it!
Quick question for you?
Do you happen to know the body color? I think it might be 1967/ 1968 light blue # 507.
I recently found a 1967 GMC BBW in a junkyard with a 327 SB same color as yours. I can not quit thinking about the color.
Good luck with your build. I will keep watching this one.
Keith
lil hoodlum is offline   Reply With Quote
Old 08-12-2010, 12:51 PM   #50
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice truck!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
