#26 |
Re: opinion on the 6.2 diesel engine
Yes seafoam is the brand name and you can buy it at any parts store even wal mart this is the best you can use along with lucas fuel treatment
![]() ![]() '82 ![]() (Hot Rod) '90 ![]() (Daily Driver) '53 m38a1 Willys Jeep (Toy) |
#27 |
Can't speak for the 6.2, but on 6.0 & 7.3 powerstrokes and the 5.9 cummins If you turn up the fuel on stock turbo they smoke like crazy. If you then upgrade the turbo the smoke almost disappears.
#28 |
I've got an 86 K30 6.2 and I get about 16-18 mpg. I just use it as a farm truck, it's got 4.10 gears and an SM465 tranny. The glow plug controller is bad on mine, I've got a push-button wired up on the dash to make them cycle. I would think that a 305 may have more power.
#29 |
#30 | |
thanks guys for all your input im gonna try to keep my eyes open for a 6.2 that has been taken care of and aint set around and got all out of wack or find a truck with no motor and do a cummings swap would be the best thing to do i think.
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod ![]() |
#31 |
When your looking for a good 6.2 to use i was told to remove the radiator cap with it running and check for air bubbles. The starting is a big part of motor condition, If it got eithered even just a little bit, it could be to low on compression to start, the low compression motor can still run well once started (like my donor motor, which is why i didn't do the swap). The glowplug controllers are crap, someone on Dieselplace.com said blowing a hair dryer down the throttle body works as well better than the glowplugs, Good luck on finding one and i hope it went better than my search.
#32 |
If you're thinking of a Cummins re-power and you're just wanting to drive it around more than actually haul anything I would suggest the 4 cyl motor. I know a guy that dropped one into an 86 C10 with a Getrag 5 speed and 3.08 rears. His best mpg is 27. Also, a 6 cyl Cummins will weigh more and will be harder on your front end if you aren't planning on putting it into a 1-ton.
