08-09-2010, 01:55 PM | #26 |
Truck and auto performance nut
Re: Project -underfunded - '68 shortstep/carb'd LSx/200-4r build
doesn't that exhaust manifold with the shield off look like a cast iron shorty header?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
08-09-2010, 02:43 PM | #27 |
They do. Look way better then my maniflods nonflowing self.
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
08-09-2010, 06:22 PM | #28 |
Man thats 1 tall intake when you look at it from the side like that,It's cool though
08-09-2010, 08:14 PM | #29 |
Yes, I think its taller then some of the single plane intakes. Thats why I measured one side shot...wondering if it will all fit under the hood!
08-11-2010, 12:16 AM | #30 |
narrowed the cam down to 2 choices...tho my foot says #2.....* is my 1st choice
*223/231 @ .050 - .610/.617 lift - 112 LSA or 227/235 @ .050 - .614/.621 lift - 112 LSA
08-11-2010, 07:49 AM | #31 |
112 lsa, should be nice & choppy!
08-14-2010, 01:11 AM | #32 |
stayed with the Comp LSr, the 273Lr HR12... 223/231 @ .050 .610/.617 112LSA cam, bought the Patriot Gold kit with double springs and titanium retainers and locks. I got the Crane spring tool to change out the springs and all while the heads are still on and a pushrod checker to verify what pushrods I'll need. Also got all the LS2 front cover and sensor stuff to replace the VVT stuff along with a bunch of ARP bolts...and a flexplate kit for older transmissions to go with my GMPP adapter. Between it all I should be able to mate up the trans, and I'll just sell the one I don't use.
Trans has been painted and the new energy suspension mount will be here in a few days. The front control arms are ready to go so I'll be bolting in the new drop spindles this weekend, hopefully mocking up the trans, so I can install my frame boxing plates, and also painting and bolting in the rear end...or maybe I'm being too optimistic. oh yah........I almost forgot...based on various tests results I've seen, similar cams, an identical block/heads config.....this cam should push the motor to well over 500hp (probably around 535hp) and roughly 450tq. Not bad for normally aspirated w/o nitrous.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 08-14-2010 at 01:16 AM. |
08-14-2010, 01:28 PM | #33 |
After we both get these done we will have to meat some place. Maybe we can have a LSx swap...meat. That would rock.
08-15-2010, 02:44 PM | #34 |
made a little progress
got some parts in: front suspension ready to go together: painted the 2.5" drop spindles with a "cast iron" coat of paint: springs were black...now they're silver: got the trans painted..its "graphite, and darker then it looks: also bought ARP water pump bolts twice (ooops)...so if anyone needs a set...
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:13 PM. |
08-15-2010, 03:47 PM | #35 |
This is looking good! Are you using the stock truck pan? Does it hang lower than that front crossmember?
08-15-2010, 04:07 PM | #36 |
Thanks! I'm using the stock LY6 truck pan with the ECE mounting kit. The back of the pan is about even with the bottom of the crossmember but...I have the motor supported in the back on a 2x3 and jack stand right now. If the angle changes much with the trans hookup (and removal of support)...it might be 1" or so lower at the back of the pan?
08-16-2010, 08:30 PM | #37 |
got some more goodies today....including my cam!
more pic updates coming soon....
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:14 PM. |
08-21-2010, 01:24 AM | #38 |
well, I got the trans in and tossed in the drive shaft (not cleaned/painted yet) to see how things looked.
I also tossed one of the front 1" drop springs and 2.5" drop spindles on the tubular upper and stock lower control arms to see how it looks. the base for the air cleaner I got is a 3" drop so it looks kind of funny...and will be replaced with a "flat" one.
08-23-2010, 10:50 PM | #39 |
got a little more done. CPP front 1" drop springs, 2.5" drop spindles, and CPP tubular upper and stock lower control arms all installed with new ball joints/bushings...and now waiting for the new brakes to arrive. I need to get rear axle installed so I can determine if the motor needs to come back some or not.
the very back of the oil pan has a dropped area around the drain plug...that hangs maybe 1" below the crossmember with the ECE kit and an LY6 oil pan.
08-24-2010, 08:31 PM | #40 |
PROJECT 7DEUCE
She should really come alive with that new motor cant wait to see her done..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-24-2010, 08:50 PM | #41 |
NICE! What do you go with for brakes? Headers? Or will you be using the stock manifolds?
08-24-2010, 09:28 PM | #42 |
Thanks guys. Haven't made a final decision on headers but looks like I may get some 2nd gen f-body 1 3/4" primary (unless I find a 1 7/8") swap headers. As far as brakes....I'm still going to be running the 15" rally wheels (going to upgrade from the 8" to some 10" rallies for the rears) for a while (until credit cards get paid down so I can charge them up again ) so since they have to fit 15's... I'm going with all new slotted/drilled OEM size front brakes from CPP with new calipers, bearings, etc.. As for the rear...it may stay drum for a while, but I'll get a rear disc kit sometime.
My dream has been to go with a complete custom coilover IFS (porterbuilt, fatman, no limit, jim meyer racing), with rack and pinion steering and adj. shocks...with bags in the rear.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 08-24-2010 at 09:30 PM. |
08-26-2010, 09:05 PM | #43 |
Well he..
Got the trans in so I could see if everything was close to matching up...or needed some adjustment....it needs an adjustment! so....I pulled the motor back out to correct the situation... and to remove the VVT cam and install my new cam, springs, etc.... plus, my new front brakes, brake booster, prop valve, and master cylinder, stainless lines, and a few other pieces should arrive here tomorrow. Once I get all that installed and the motor back in...I'll be getting a lot closer to putting the body back on, and seeing what it'll do!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken Last edited by 68GMCCustom; 04-16-2012 at 03:15 PM. |
08-26-2010, 09:38 PM | #44 |
I can wait to see how you truck sits with the drop. Its what i have on my bare frame at this time
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
08-26-2010, 10:03 PM | #45 |
Sure looks good so far. You are really making good progress.
08-26-2010, 10:33 PM | #46 |
6>8 Plugless........
Nice progress! That thing should be an animal!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
08-26-2010, 11:24 PM | #47 |
Thanks....and I sure hope so!
08-27-2010, 12:29 AM | #48 |
Nice!! I wonder how well the trans will hold up. Is it built?
08-27-2010, 09:41 AM | #49 |
Yes. Local builder/racer/trans guru and Trans shop owner built it for 500+hp and with a 2500rpm stall.
08-28-2010, 01:00 PM | #50 |
Getting closer to having the front end buttoned up. Added drilled/slotted rotors, new calipers, new bearings and seals, and stainless brake lines.
I need to get busy and get the cam and springs in now so I can measure and order my new push rods. I think I'm going to go get 16 of those cheap extending pen magnets to make sure my lifters don't fall.
