#26 |
Re: 1949 AD-kota
i love the use of the original column. i want to lose my tilt column and put the original back in!
#27 |
Re: 1949 AD-kota
what yr chassis did ya go with, you do know the you can swap the 6 lug to the 5 lug to get the 5x4.5 bolt pattern, but will have to swap out the rear tho. i am going to use a gen 1 swb dakota for my 60 dodge tk project as the track width is slightly narrower, by the way its looking good.
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
#28 | |
Re: 1949 AD-kota
#29 |
Re: 1949 AD-kota
Need to get a few pictures taken, football season and the flooding we had slowed me way down.
The original column is getting replaced by a tilt. Only because I couldn't get the auto shifter to work out safely. The chassis is the extended cab, '92 I think. I have some nice wheels for the 6 lug but I do know about the 5 bolt swap. |
#30 |
Re: 1949 AD-kota
Any updates?
#31 |
Re: 1949 AD-kota
I had hernia surgery last Wednesday. Hopefully in a week I can get in the shop to take some update pics.
#32 |
Re: 1949 AD-kota
Suppooooose that's an acceptable excuse. Wishing you a Speedy Recovery!!!!
#33 |
Re: 1949 AD-kota
Been moving slow and doing some light work in the shop. My brother came over to help get the front clip off and the set up block & trans out.
The motor mount now has the torque stap added. Yes, the strap is made from an AD brake pedal. I am a little cheap and it was too late to to buy steel. ![]() Also got the pedal assembly attached to the dash. ![]() |
#34 |
Re: 1949 AD-kota
Now on to the tilt column. With the desire to have column shift, it was not working to use the old column and the dakota booster. My buddy Mark had a clean tilt column for cheap (free).
Here is the lower mount I made up, just a couple more little items and its done. ![]() The billet mount is so easy to use that I can forgive myself for having it. Also seen is the attachment of the brake assembly to the dash. ![]() As it went, I wasn't 100% accurate on the placement and the column rubbed the dash a little. So I made this shim to drop it. 3 1/2 x 1 1/2 x 3/16 inches the slots are 2 5/8" on center with 5/16" slots. ![]() In all its glory, a tilt column with shifter. ![]() |
#35 |
Re: 1949 AD-kota
There was still a little flex at the dash with the column and brake unit. The original attachment point on the dash was chewed up from some harsh service. I made a new brace from some scrap 1/4" plate, 1" square tube and 1"X2" rectangle tube.
![]() A little creativity with the hole saw and a file on the lower part of the mount. ![]() Last edited by T Hilde; 02-05-2011 at 04:34 AM. |
#36 |
Re: 1949 AD-kota
U-joint and 3/4" double D shaft hooked to the rack and pinion. Should be a heck of a lot easier to move around now.
![]() ![]() Last edited by T Hilde; 02-05-2011 at 04:39 AM. |
#37 |
Re: 1949 AD-kota
ahh progress thats what i like to see
#38 |
Re: 1949 AD-kota
Well, I said I wasn't gonna do it...but I did. Tonight the frame was shortened 14 inches to make it 117 inch wheelbase. Then dumb me left the camera in the house. The Dakota shortens like the S10 so not a lot of new info there. Had the cab off and back on in 5 hours.
#39 |
Re: 1949 AD-kota
yeah it is pretty straight forward. but pictures speak a thousand words and more
#40 |
Re: 1949 AD-kota
Here is the frame splice. It is the way the factory did it. I carefully took the cutoff wheel and cut behind the weld, then cleaned up the factory weld with the grinder. Cut the excess off and slid it back together (comealongs and ratchet staps were needed), checked frame square and wheelbase, then re-welded.
#41 |
Re: 1949 AD-kota
Started to fit the front sheet metal. Had to chase a bunch of threads plus drill and re-tap a few. There are a lot of 5/16 nc 3/4" bolts on this, glad I bought a box of them.
![]() ![]() Can anyone tell me what screws I need to buy for the lower valance? The ones that go up into the grille and those from the inner fender to the valance. Found them. #14 metal screws 3/4", I picked up the phillips head but will look for some with a hex head later on. Last edited by T Hilde; 02-14-2011 at 08:31 PM. |
#42 |
Re: 1949 AD-kota
The square nuts for the inner fender sometimes twist out
![]() ![]() Press them out with a large deep socket, bolt and c clamp. ![]() Take a file dress the edges of the nut and the hole of the inner fender, test fit then sand the crud from around the opening. Hold it in place with bolt and a larger nut. ![]() Weld it in, now 5 more to go. ![]() |
#43 |
Re: 1949 AD-kota
Looked at getting the bumper and splash pan fit. Wow that was a ton of up and down, cut/grind/fit/swear/cut/grind/fit.
Here is how it finished. ![]() ![]() After getting it tack welded here is how it was done. I used the front of the 3800 frame, radiator support forward. ![]() ![]() ![]() Last edited by T Hilde; 02-24-2011 at 07:20 PM. |
#44 |
Re: 1949 AD-kota
looking very cool
#45 |
Re: 1949 AD-kota
Thanks RAD.
Well I am back at work, so progress slows. I decided to get the proportioning valve off the frame rail. This bracket is what was manufactured from the scrap pile. ![]() Finish welded the trans mount, took out the old driveshaft and hanger bearing. Then was able to put the motor/trans in it. ![]() Bolted up the power steering pump with Alan Grove bracket, slick stuff. ![]() |
#46 |
Hellasick
![]() Join Date: Jul 2006
Re: 1949 AD-kota
Looking good. Wish I had a shop like yours!!!!
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#47 |
Re: 1949 AD-kota
SCORE!!! I just picked up a set of chrome smoothies in real good shape for $160. Located a 5 bolt dakota axle and rotors that I'll pick up next month.
Got a all new driveshaft made up. Also hooked up the shifter to the transmission. Just a bunch of fiddle work. |
#48 |
Re: 1949 AD-kota
Misc pics of progress.
air cleaner lid fron a 292 I6 ![]() Speedway shift linkage, modification needed. ![]() firewall recess for dipstick tube ![]() |
#49 |
Re: 1949 AD-kota
Little update. The brother and I went in on the Eastwood flare tool. Wow, it is easy to do. Got the front lines done and still need to run the one to the rear.
![]() Traded a set of hubcaps for a pair of stainless '54 tail lights. So today I made the brackets and did a test fit on a spare box. ![]() ![]() ![]() Last edited by T Hilde; 04-24-2011 at 07:40 PM. |
#50 |
Re: 1949 AD-kota
Got out in the shop for some me time. Started trying to get things closer. Some may have seen the box side shortening from a couple weeks back.
Finally put the electric fan on ![]() Made a bracket and mounted the overflow can. Also put on a mopar t-stat housing and flex hose. ![]() Got the Rebel wire harness mounted and roughly routed, waiting for the plugs that I didn't order with the kit. ![]() Ran trans cooler lines to the cooler and made brackets for it. Just need to weld them in. ![]() ![]() Next up a tech on the front marker lights. |
