#26 |
Re: Stock rear gear ratio info
Here is a 70 C10 power team chart for you. It really helps to post what year and series you have when asking a question like this.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#27 |
Thanks Tim, but yes it is a 1970 C10. I didnt know if mine had a different ratio than 3.07 because at 75mph the truck runs at about 3800rpms or so. I do have a built TH350 and 2200 stall converter however so that is probably part of the higher rpms.
#28 | |
Posted via Mobile Device |
#29 | |
I have a burb that was a 6cyl 4spd and a pickup with 327 240hp 4spd They both have the 10 bolt rear. The truck screams in 4th gear at 50mph Thanks
1985 Custom Deluxe long bed 305 3 on tree 2015 Silverado "Great White"1987 K20 dump and plow 1968 K20 327 long bed 4spd big blue 68K20 SuburPan 4spd 79C30 L96 6L90e 86 K10 plow |
#30 | |
All you needed to do was click on the link in my signature, most are there. http://67-72chevytrucks.com/vboard/s...05&postcount=5 4.57 gears spinning a 31" (stock 7-17.5)tire @ 50 mph = about 2475 rpm, that isn't exactly screaming. The indirect drive T-221 t-cases were never quiet.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 09-13-2016 at 07:50 PM. |
#31 |
Thanks, I found the link right after I posted. So the T221 makes that jet sound normally? It starts whining at 40 and close to 50 I need ear protection.
#32 | |
Have replacement parts in hand before pulling anything apart. The idler and output shafts should have zero end play, as in 0.00" is considered ideal as measured with a dial indicator Suggested reading 68 Overhaul Manual pg 7-111/PDF pg334 68 Service Manual Sections 0 and 3
#33 |
I've checked front and rear ends, trans and transfer case. All topped up with 90w
Cardan joint balls? The noise is worse under load, it quiets a bit when I let off the gas, clearly coming from transmission or transfer case
#34 |
The cardon joint balls are the front axle shaft u-joint swivel housings, they have seperate filler plugs L&R and in checking the driver's handbook are to be filled with SAE140 vs the differential's SAE 90.
#35 |
I always thought 3.08 and the granny 4 speed was a sweet combo. No need for overdrive and can still pull a house in first. Just watch the gap between gears!
1982 K10 SWB 1987 V20 - Sold - Doh! |
#36 |
Suggested reading and in hand resources.
#37 |
Thanks, that's great I wish I had them. Unable to download the manual onto my phone. Just need to see diagram or know where fill is for cardan joints.
#38 |
Here...
