Old 11-22-2010, 10:18 PM   #26
Wheelie
Re: Tami's 51 build
Your chop is on spot man. Smartest way I have seen it done. Trucks coming along awesome!
Wheelie is offline   Reply With Quote
Old 11-22-2010, 10:22 PM   #27
Fat Mike
Fat Mike's Avatar
Re: Tami's 51 build
Thank you for the pictures! It really helps us novice welders to see both the front and backside of a weld.
Fat Mike is offline   Reply With Quote
Old 11-30-2010, 12:57 PM   #28
skip99
skip99's Avatar
Re: Tami's 51 build
I am trying to find curved wheel tubs like these, anyone know who makes them, all I need is about 3" of tub
skip99 is offline   Reply With Quote
Old 11-30-2010, 01:01 PM   #29
Spackle100
Re: Tami's 51 build
Check out posts #403 and #420 of Kabwe's build
http://67-72chevytrucks.com/vboard/s...318301&page=17
Hope it helps..
Spackle100 is offline   Reply With Quote
Old 11-30-2010, 01:09 PM   #30
skip99
skip99's Avatar
Re: Tami's 51 build
thanks ! it helps....ya know I was hoping for a set already welded up for like $20..I can wish , right?
they have the fenders at tractor supply, I guess I only need one though..
Old 11-30-2010, 02:55 PM   #31
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Tami's 51 build
Hope it helps..
Hey man I wanted the same tubs that you posted pics of but decided to go a different route after seeing the price. No limit Engineering has them for too much money for me to consider. But if the look is what you have to have I say go for it. Here is a link to the No Limit tubs. http://nolimit.net/products.asp?dept=1200
Kabwe is offline   Reply With Quote
Old 11-30-2010, 06:58 PM   #32
skip99
skip99's Avatar
Re: Tami's 51 build
kabwe,thanks..I'll post on your build..
Old 12-01-2010, 12:30 AM   #33
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Tami's 51 build
Hey Skip,
The reason I went with two fenders instead of one (I could have cut one in half also) is because I like the rolled look instead of a wheelbarrow or Bar B.Q pit looking tub. If you can find a fender that has the roll on the front and back of the fender you would be good to go, I could not find one. Buy the way, I brought mine on ebay for something like 40 bucks for the two of them.
Old 12-01-2010, 11:01 AM   #34
Fat Mike
Fat Mike's Avatar
Re: Tami's 51 build
What did you use to cut the rear part of the cab. The part I am talking about is the part that is around the window. Mine is about 2"-3" thick and what to make sure the cut is straight.
Old 01-11-2011, 11:58 AM   #35
skip99
skip99's Avatar
Re: Tami's 51 build
finally got time to a little more work... here's a few pics...
PO did a crappy job of putting in panels , so I am cutting it all out and re doing it...stuff was off by as much as 3/4 inch in places.
welded up the lower seam, I read that here and would never have even thought about it.. thanks!
top's lower,,, now gotta make the doors fit..
we were going to put a 3/16 round bead where the drip rail used to be, but once I got it this close, we (meaning her..lol) decided to leave it smooth
hard to see , but we are messing with the idea of putting some louvers, intake, what ever you want to call them into the hood, I like it !
one thing I just could not find that I liked was a vent setup for when we add AC, it all was either cheap looking plastic or, well you know... so I just put in 2 louvered boxes in between the ign. and lighter.. hopefully I'll have room for the ac switches in between.. to me, this had more of a (looked like it was built that way look) and since we smoothed the dash..(filled in the old radio, speaker, ashtray) and smoothed the glove box door, this is a clean look..
Old 01-11-2011, 12:42 PM   #36
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Tami's 51 build
Looks very good. That looks like duraglass you are using on the welded seams. I do the same, I love the stuff for things like that.
Old 01-11-2011, 02:09 PM   #37
skip99
skip99's Avatar
Re: Tami's 51 build
yep, duraglass, costs a lot, but saves a lot more !!lol
Old 01-11-2011, 03:41 PM   #38
OrrieG
OrrieG's Avatar
Re: Tami's 51 build
What did you use for the louvered boxes in the dash?
OrrieG is offline   Reply With Quote
Old 01-11-2011, 06:22 PM   #39
skip99
skip99's Avatar
Re: Tami's 51 build
The ac vents were really simple, just time consuming... cut a hole, ran 1/8" round rod on the edges , and welded 1/8" x 1/2" flat for the louvers, just put 7/16 nuts between the slats for even spacing and just kinda "tilted" them like a stack of dimes for a nice angle, and tacked them in place. then just built boxes out of 20 ga. with 2" muffler pipe to attach to vent hose, and drilled a hole through from the front of the dash put a screw in and welded it flush to make a stud from behind. there is a factory fold in the bottom of the dash that holds the bottom of the vent box in place..only needed the one stud to bolt it from the top.
can post close pics if you like..
Old 01-11-2011, 06:49 PM   #40
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Tami's 51 build
Nice work, keep posting pics as you move forward.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-11-2011, 06:59 PM   #41
52 Rat
52 Rat's Avatar
Re: Tami's 51 build
Nice build.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671
52 Rat is offline   Reply With Quote
Old 01-11-2011, 10:59 PM   #42
OrrieG
OrrieG's Avatar
Re: Tami's 51 build
Thanks, thats the info I needed. I don't like the cheesey plastic one that came with my VA set up either and have been playing with different ideas. Yours has me looking at my just painted dash again....
Old 01-15-2011, 09:32 PM   #43
skip99
skip99's Avatar
Re: Tami's 51 build
here's the shot of the vent boxes I made..
and started smoothing the dash
this is converting a pull down handle to the pushbutton type
these are the original hole for pull down on a 51
this is a reinforcement plate out of a 52, I just cut out a 2x3 square area around the original holes, lined up the plate from the inside, put the handle on temporarily , then welded the correct hole section in out of a 52 skin. welded up the 51 door lock hole and cleaned it up.
the rear gap in the door was touching, so I also had to drill about 10 holes through the skin , spot weld to hold the skin in place then cut off about 1/4 " on the edge of the door, lay a weld bead, and grind it straight.
Old 01-18-2011, 08:53 PM   #44
skip99
skip99's Avatar
Re: Tami's 51 build
Started on the bear claw install, ...pretty much the same idea as in the past, but I thought I could move the pivot point down and basically gain mechanical advantage, making it easier to push the button..
I ended up making a couple of these intil I got it right, this is the first try on the right,,,
I also forgot that when I made the second one, I had to make a mirror image of it..whoops!! oh well make another..
better make sure these fit..
Old 01-19-2011, 01:39 AM   #45
Tri5Nerd
Tri5Nerd's Avatar
Re: Tami's 51 build
Great fab skills, which one is the one you're going to use as your finished product? The one on the Left or the one on the Right? The one on the Left looks like it has more room to work with the push button.
Tri5
Old 01-20-2011, 12:36 AM   #46
Tuned55
Tuned55's Avatar
Re: Tami's 51 build
Nice build. Really like your detailed progress pics. I've been wondering about AC vents myself. I like yours also.
I want to try a chop someday soon. Your pics will come in nicely
Bruce
So.Utah
Build Pics http://www.picturetrail.com/tuned55
Tuned55 is offline   Reply With Quote
Old 01-20-2011, 04:58 PM   #47
skip99
skip99's Avatar
Re: Tami's 51 build
thanks guys, I actually won't use either, I fine tuned them a little more ( since I bought this really cool slip roll, brake, shear combo thingy,,!lol!)
and you are right I went with more or less the one on the left, it gave me a little more room for the pushbutton. and I'll add nylon washers..
Old 01-20-2011, 05:23 PM   #48
Tri5Nerd
Tri5Nerd's Avatar
Re: Tami's 51 build
and you are right I went with more or less the one on the left, it gave me a little more room for the pushbutton. and I'll add nylon washers.. and since I have a few of these I might just build another set and offer them up..?
I would be interested in a set if it will work on the large bearclaws, it looks like you are using the small ones.
Tri5
Old 01-20-2011, 11:08 PM   #49
Tuned55
Tuned55's Avatar
Re: Tami's 51 build
I'd like to see this really cool slip roll, brake, shear combo thiny. I've got a slip roll and brake I'd like a shear but my shop is getting smaller all the time.
Bruce
So.Utah
Old 01-21-2011, 10:54 AM   #50
skip99
skip99's Avatar
Re: Tami's 51 build
I'll post a pic today, I got mine here...
http://reviews.tractorsupply.com/051...ws/reviews.htm
it won't shear heavy gauge metal, but it will bend nice and roll sweet !!
tractor supply had one left, I offered them $300 and they took it.
I would like to of had separate machines to do heavier metal, but I need the room also..plus smaller pieces do really make up 99% of what I need to do.
