Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-13-2010, 10:49 PM   #26
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: 1973 K20 Build Thread
Got a little more done today. I'm close to getting it running again, but this home stretch is taking for ever. I painted all the power steering brackets and put the pulley on the new/reman power steering pump. You can see the new detent cable installed. You can also see the wiring on the firewall and the wiring down next to the oil pan.
Again, I used Adel clamps. These things are great to help clean things up.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-13-2010, 11:03 PM   #27
TheWhiteElephant
God is good!
I installed the alternator, power steering pressure line, and spark plug wires. I was having second (and third, and fourth) thoughts about the non-subtle, super bright blue plug wires but they've grown on me in the past few hours. I'm going to route them underneath the manifolds for a clean look.
I put in new fuel lines from the pump along with a glass fuel filter. I'm a big proponent of glass filters. Very helpful when diagnosing. You can also see a new intake heater hose fitting I got from the good ol' "Help" section @ Oreilly's for $5.49. Much better than the $11.59 they want for it from Classic Industries.
Mando
Old 11-14-2010, 03:03 AM   #28
nbpro
looking good man
nbpro is offline   Reply With Quote
Old 11-14-2010, 11:25 PM   #29
TheWhiteElephant
God is good!
Originally Posted by nbpro View Post
looking good man
Thanks so much, I appreciate the kind words!
Mando
Old 11-14-2010, 11:54 PM   #30
nbpro
does that thermostat housing have a temp gague built in?
Old 11-15-2010, 12:57 AM   #31
GMC Guy
GMC Guy's Avatar
that thing looks great!
how much you have invested so far? i love the build on budget trucks
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 11-15-2010, 03:43 AM   #32
cvalcore
cvalcore's Avatar
that engine is look pritty good. could you do me a huge favor could you give me a messurment from the ground to the bottom of the frame right under the cab if you could do that i would really appecate it thanks
cvalcore is offline   Reply With Quote
Old 11-16-2010, 09:24 PM   #33
TheWhiteElephant
God is good!
It is a screw-in unit that I bought a few years ago from Moon. It screws into the thermostat housing. I'll post some close-ups soon.
Mando
Old 11-16-2010, 09:25 PM   #34
TheWhiteElephant
God is good!
Thanks. To be honest, I wanted to keep things very low cost, but I am pushing the budget just a bit. So far I probably have a little over $1,000 in it, but I could have definitely kept the cost much lower. I didn't really need the Milodon oil pan and timing chain cover, the valve covers, or the fancy transmission dipstick, so you can see I'm pushing it a little. I WANTED to replace the starter, alternator, PS pump, and fuel pump. It NEEDED a complete tune-up, belts, hoses, and the exhaust manifolds, and I really wanted to clean up the engine and spray it.
All this could definitely be done for much less than $500 if you want to skip the fancy stuff and only replace the needed items. And do the work yourself, of course. I have all the receipts and may tally them up at some point.
I have a few things in store for it but mainly I want to get it running reliably so that I can enjoy it while work on it simultaneously.
Mando
Old 11-16-2010, 09:31 PM   #35
TheWhiteElephant
God is good!
Sure thing. It measures 15" from the bottom of the frame right at the front cab mount down to the ground. The truck has 225/75/16 tires with the stock 3/4 ton suspension. Let me know if you need any other measurements.
Mando
Old 11-16-2010, 09:36 PM   #36
nbpro
cool Thanks
Old 11-17-2010, 03:02 AM   #37
cvalcore
cvalcore's Avatar
thanks i realy needed that measurment.
Old 11-18-2010, 02:51 AM   #38
kikkegek
kikkegek's Avatar
WOW! really good job for just being in the driveway and not the garage.
couple question for ya:
- did you put anything under the car when cleaning the engine of grease? because otherwise you would sting the street like hell?
- what do you mean by "intake heater hose fitting"? I am pretty newby, sorry.
When temperatures go up again (right now it is freezing at night) I want to take up cleaning the engine too. Right now the greese nicely protects it from all the salt they are gonna put on the roads when snow or frost comes along! terrible for corrosion of my car.
kikkegek is offline   Reply With Quote
Old 11-18-2010, 11:14 PM   #39
TheWhiteElephant
God is good!
Thanks for the kind words. Yes, I really made a HUGE mess for about 3 days straight. All the grease fell on the driveway, rolled onto the street, and effectively drained into the drain on the street. (not proud of that, by the way, but it had to go somewhere)
A buddy loaned me a very strong pressure washer, so I'm going to tackle my driveway as soon as I get the truck rolling again. I don't want to leave any stains on my relatively clean driveway. The fitting on the intake is the one to the left of the glass fuel filter in the picture above. The heater hose from the firewall goes into it. The original fitting was very rusty so I needed to replace it.
The nice thing about South Texas weather is that you can work on your vehicles year round. Right now the weather is perfect. Only bad thing is it gets dark by 6 pm, but that's ok.
Mando
Old 11-19-2010, 09:38 PM   #40
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Just checked out your build thread after you replied to my thread...so far I'm loving you engine...this was what I am planning on doing with my engine.....right now it looks like what yours did in the beginning....well actually maybe worse...I can't tell all of it because the previous owner took a can of black spray paint to it before I bought it so I don't know what is lurking under some of that.....I'll be bookmarking this for reference later.....just wondering though....how were you able to paint the lower sides of your engine with the red paint so well? Did you go under and get to them? Looking good though!
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 11-19-2010, 10:03 PM   #41
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice truck to start out with! You are doing a great job on bringing it back to life as a DD. Keep up the great work!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-20-2010, 01:50 PM   #42
79gmcclassic
79gmcclassic's Avatar
this is guna be a cool build
1979 GMC Sierra Classic
Freshly lowered 5 inches
79gmcclassic is offline   Reply With Quote
Old 11-20-2010, 04:09 PM   #43
C25 Farm Truck
C25 Farm Truck's Avatar
This is a great thread! It's inspiring to see a build without a big shop or a complete teardown. It makes me want to go borrow a power washer and get to work!
One question - how did you repaint the engine while it was still mounted? Did you mask off for overspray or just aim carefully?
1985 C2500 3+3 Sierra Classic 454/TH400
Stock right down to the wheels, it's primary purpose is to haul cows.
It's secondary purpose is to provide me with many hours of fun and frustration.
C25 Farm Truck is offline   Reply With Quote
Old 11-21-2010, 03:05 AM   #44
TheWhiteElephant
God is good!
Thanks so much for the kind words, folks. I'm a big believer in elbow grease, and I didn't want to pull the engine in my driveway (see my above comments). I don't have a cherry-picker and I don't have a big garage or shop to work in, so I made the decision to basically take EVERYTHING off the engine while it was still in the truck.
Then I just cleaned, and scrubbed, wire-wheeled, scrubbed some more, and masked what I didn't want sprayed. Yes, I had to get under the truck to paint the bottom of the engine. I carefully masked the engine mounts and sprayed around them. Since I changed the oil pan, valve covers, and timing chain cover, I was able to paint around those without having to mask them. Aiming carefully and going over in several coats helps.
Make no mistake about it--good quality rattle can spray paint and hard work go a long way. I'm on a pretty tight budget, but it still takes some cash to replace what really needs to be replaced. I appreciate the comments.
Mando
Old 11-22-2010, 03:44 PM   #45
Dieselwrencher
For not removing the engine, you did a really good job. It looks great!
Ryan
Old 11-22-2010, 04:14 PM   #46
MTCK
MTCK's Avatar
Solid build - I'll be watching this one!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 11-22-2010, 04:42 PM   #47
palposity
palposity's Avatar
Looking good!
Project #1 "Pops"--1980 Chevrolet Scottsdale C10 3rd Generation in the same original owner family. GOAL: Restore to "almost" original.
View Project Pops HERE
Project #2 "Cletus"--1986 Chevy K20 4.10 Gear Ratio GOAL: Restore into a heavy duty work/plow rig
View Project Cletus HERE - SOLD
DD--2008 Duramax CCSB
palposity is offline   Reply With Quote
Old 11-22-2010, 05:08 PM   #48
Pop's C-10
Pop's C-10's Avatar
that motor is looking good man
Pop's C-10 is offline   Reply With Quote
Old 11-22-2010, 05:13 PM   #49
Catfisher'
Dang, that looks good! I was thinkin bout paintin my engine orange. How hard is it to do?
Catfisher' is offline   Reply With Quote
Old 11-22-2010, 05:27 PM   #50
Dru
Looking very good, after just cleaning a dirty old farm motor out of a truck, I can imagine the work it took to get around everything while still being inside.
One of the things I've learned if you spend too much time on your vehicles, something else has to give (namely, family time), so I'm going to keep this on a budget of time and money.
I completely agree with you, material objects will come and go, but you can never get lost time back.
I live in a neighborhood with a homeowner's association and am doing all this in my driveway, so I don't want to upset the neighbors with my junk in the driveway (my wife is embarrassed enough as it is).
lol, I'm surprised you got away with it, I have heard stories about neighbors getting irate because someone left their trash can out, in neighborhoods with associations. I live in a historic district myself, and its not quite as bad as some of the fancy neighborhoods, but I dont think they would appreciate me out in my driveway with a cherry picker. Have found a good solid tree in the yard to use back in the older days.
Dru is offline   Reply With Quote
1973, 1973 k20, ball joint, ball joints, rough country
