Old 12-16-2011, 07:16 AM   #26
brokenspoke
brokenspoke's Avatar
Re: 700R4 replacing 3 speed
Originally Posted by Touchdown67 View Post
What about putting a 200R4 instead of the 700R4? Will the 200 fit better?
Its a 2004R...a good transmission...check out Bowtie Overdrives for a TV hookup.....
brokenspoke is offline   Reply With Quote
Old 12-17-2011, 12:02 AM   #27
Captainfab
60-66 Nut
Yes the 700R4 will bolt up just fine. I believe the biggest issue you will have is fabricating a TV cable bracket for your carb setup, and getting it adjusted correctly. I know there are others here that have the 700R4 behind I6's, but it seems to me they are using other than stock intakes and carbs.
Originally Posted by KVB View Post
I have 1965 230 inline 6. Will the 700R4 bolt up to the 6cyl?
Ken
Old 12-17-2011, 09:34 PM   #28
samuellg1977
samuellg1977's Avatar
Just a little food for thought. Here is a carb mod for the 700R4 TV cable. I found this searching online a while back. Something like this should work pretty nice for you guys. I have yet to see anyone that makes one for those carbs. I definitely see a market for it...
Sam
samuellg1977 is offline   Reply With Quote
Old 12-17-2011, 09:52 PM   #29
jocko
jocko's Avatar
Both can be built to withstand stuff. Keep in mind the 2004R was stock behind the 87 GNX, so it can take it (or at least be built to take it). I personally like the idear of the 2004R - had one in a MOnte SS and it was a great trans.
Old 01-23-2012, 11:54 AM   #30
greenmtnboy
greenmtnboy's Avatar
Has anyone adapted the 700r4 to the stock 3 speed manual column shifter linkage?
I have a '63 that originaly had a 230/3spd and is now 283/3spd. I'd like to keep the stock column.
greenmtnboy is offline   Reply With Quote
Old 01-23-2012, 03:33 PM   #31
lil_sahara450r
would love to hear some imput on this subject
lil_sahara450r is offline   Reply With Quote
3 speed, 700r4, hump, tranny
