Old 12-17-2010, 09:25 PM   #26
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Re: My 84 CC Dually mod thread - there will be plenty of pics
Looks good. what ya doing with the old cab ferrings?
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 12-17-2010, 11:16 PM   #27
502ss
502ss's Avatar
The racerback? No plans, why?
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 12-17-2010, 11:28 PM   #28
cochino12
It followed me home?
cochino12's Avatar
I like the LED fender lights, more info please
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-18-2010, 12:31 AM   #29
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
I kinda like the look was wondering if maby you would like to part with it?
Or maby Santa could bring it to me for Christmas? LOL
Old 12-18-2010, 10:36 AM   #30
502ss
502ss's Avatar
Make me an offer!
Old 12-18-2010, 10:44 AM   #31
502ss
502ss's Avatar
You can buy the strips here
http://www.superbrightleds.com/cgi-b...pecs%2FLB3.htm
I then just hogged out the back of the housing, laid the strip in and then sealed everything with silicone. I used silicone because these strips are not waterproof. I did this mod on my old set of lights to try it, when I buy my new lights I will angle the strip a little bit so it shines straight out the back when mounted in the fender. Currently they are mounted flat in the housing so they are brighter when standing a little to the side vs. straight on the rear.
Old 12-18-2010, 12:40 PM   #32
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
Make me an offer!
lol b4 i offer will you ship to canada? I would pay of course
Old 12-18-2010, 04:57 PM   #33
502ss
502ss's Avatar
I have no problem shipping it to Canada but based on the size of the boxes I bet it's $200 in shipping!
Old 12-18-2010, 05:51 PM   #34
jitteryguy
GoatLube Experss
jitteryguy's Avatar
looks better already .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 12-18-2010, 05:52 PM   #35
kikkegek
kikkegek's Avatar
nice,I am gonna follow your build!
kikkegek is offline   Reply With Quote
Old 12-18-2010, 06:18 PM   #36
SS Delux
SS Delux's Avatar
What kind of steering wheel is that ? It looks reall cool, and what diod you mean by bags just created to much maintenance ?
SS Delux is offline   Reply With Quote
Old 12-18-2010, 06:38 PM   #37
502ss
502ss's Avatar
It's a grant wood grain steering wheel. When I first saw it I said "that thing has to go" but then I drove the truck some and it feels real nice!
Between airlines, valves, compressors, etc. Airbags can be high maintenance. Where I am going to towing a big boat I really don't want any problems which is why I opted for a static drop instead
Old 12-18-2010, 06:50 PM   #38
502ss
502ss's Avatar
Running boards are gone.
Hopefully the bed will be off tomorrow!
Old 12-19-2010, 04:49 PM   #39
502ss
502ss's Avatar
The bed is off! Now the fun starts!!
Old 12-19-2010, 06:29 PM   #40
C-10 simplex
1) What's the mpg?
2) mpg when towing?
C-10 simplex is offline   Reply With Quote
Old 12-19-2010, 10:03 PM   #41
502ss
502ss's Avatar
Originally Posted by C-10 simplex View Post
1) What's the mpg?
2) mpg when towing?
12-14mpg empty, 8-10mpg towing a 10,000lb boat!
Old 12-19-2010, 10:50 PM   #42
D.FENS
Never seen anyone pull a truck bed like that. I'll keep those pics on file if you don't mind.
Also, that tan / gold two-tone is AWESOME. Please don't paint it.
D.FENS is offline   Reply With Quote
Old 12-19-2010, 10:57 PM   #43
71'tahoe
71'tahoe's Avatar
I know you said bags can be high maintance,But if you run the back of your truck with helper bags then there is really no issue. Or if you did a 4 link then use an air tank and a leveling valve with a small compressor,you never have to maintance anything except to drian the small amount of water that may build up after a year. Every air tank I use in my projects as well as customer projects have a drain valve in the bottom of the tank. I use air tanks from the trucking industry and they have a pull cable on them so you dont have to get under truck to drain moisture. I also work on Semis and they never have issues with lines and air bags. Just a thought. And when you load the trailer..the leveling valve will add air as needed to set truck as the pre set hieght,when you unhook trailer,it deflated the bag until leveling valve is back to the preset lenght.Not to menchen how much better it will ride when empty. I have Air ride and my own designed 4 link in the back of my 97' cre cab truck. It rides like a caddy! Hope this helps. Cool truck and boat!
Greg "GT" Tholen
71'tahoe is offline   Reply With Quote
Old 12-19-2010, 11:05 PM   #44
502ss
502ss's Avatar
That's the way you do it when your all by yourself and you don't have easy access to a chain fall. I have one in my garage to pull engines but it's location in the ceiling doesn't lend itself to removing a bed!
Old 12-20-2010, 12:03 AM   #45
pig rig
pig rig's Avatar
I built a 2x4 frame that was about the same height as my truck frame and then with the rear wheels and bumper off I just slid it off the back thats how I do mine
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 12-20-2010, 12:10 AM   #46
pig rig
pig rig's Avatar
this is a good picture to look at. you'll need to remove them over load stops that are on the frame once you get the shackels in and cut the one support on your bed where the shackle hits it having your bed on saw horses will make that task easy
if you look at your front hanger you can see what I was saying about making a braket and move it up it be easy
Old 12-20-2010, 10:37 AM   #47
502ss
502ss's Avatar
That's a cool way to do it! And with the tires off you eliminate the clearance problem with the lower edge of the fender!
Old 12-20-2010, 10:41 AM   #48
502ss
502ss's Avatar
So your new shackle hit the bed support? When I was doing some checking the other day with the bed still on I noticed it would be close but it didn't look like it would touch. Can you snap a photo?
Old 12-20-2010, 11:31 AM   #49
kelsfine69
18 Till I Die
kelsfine69's Avatar
Also, that tan / gold two-tone is AWESOME. Please don't paint it.[/QUOTE]
X2
Or stay with a 2 tone them....
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 12-20-2010, 05:27 PM   #50
Hulk Will Smash
Hulk Will Smash's Avatar
Man, that's a nice clean truck! Good luck with the project. And the boat... referesh my memory (I feel like you've said elsewhere), but I'll guess Scarab Panther?
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
