Old 02-13-2011, 02:25 PM   #26
bobcostas
bobcostas's Avatar
Re: faux-tina paint jobs
Hey Malibob
Can you post a closeup of your white roof? i was curious as to what the two tone would look like roughed up.
Jocko, i am definitely going to check out whats underneath my paint first. Thats a great idea.
and does anyone know a trick to painting the dash with the glass still in. it seems like an area prone to error.
thanks dudes. I'm getting a little ramped up about this.
'64 Corvair Ragtop
'66 C10 Stepside
"The oxen may be slow, but the Earth is patient"
bobcostas is offline   Reply With Quote
Old 02-13-2011, 03:54 PM   #27
Chapstr's65
Chapstr's65's Avatar
I have thought about doing ot to mine. I know there is two other colors under the Orange. This way I van still drive it while I do the body work. I just hatethe down time because it is a running truck and I am going to tear it a part to change out the drums to disc all around and tear the body about to do the body work and paint the frame.
-Chapa
65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear.
Chapstr's65 is offline   Reply With Quote
Old 02-13-2011, 04:11 PM   #28
lakeroadster
Here is a photo of a red and a blue truck, with light colors underneath. They looks ok, but just don't look "quite right"..IMO. The factory didn't use light colored primers on these trucks.
lakeroadster is offline   Reply With Quote
Old 02-13-2011, 07:14 PM   #29
rustycarr
sun baked!! first time this truck has been under a roof in its life..
rustycarr is offline   Reply With Quote
Old 02-13-2011, 07:25 PM   #30
scrapmetalart
Junior Member
looks like a cheap repaint in red years ago that is fading off to see the original paint underneath, not primer...
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 02-13-2011, 07:37 PM   #31
BarnFind
Chizzler, that truck looks great !! I was able to find a longbed that had original patina. I put it on a shortbed chassis and painted the bed to match. Used the original tailgate, wheel tubes, and header board. Sean
BarnFind is offline   Reply With Quote
Old 02-13-2011, 08:36 PM   #32
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Originally Posted by miller92 View Post
gorgeous truck chizzler!
thanks
Originally Posted by mano View Post
hey chizzler is that a 70 chevelle in the gargare.
70 chevell 383 stroker
Originally Posted by malibob View Post
chizzler, i love that paint on your truck. Friggin awesome man, you got a build thread or can you tell us how you did it?
Srvblue64- i think your patina looks awesome too. Maybe once you get it all together buff it a little and see where it goes. If it looks good then keep going on it, if not leave it, it looks super cool.
no build thread.i followed the trucks episode.
Originally Posted by barnfind View Post
chizzler, that truck looks great !! I was able to find a longbed that had original patina. I put it on a shortbed chassis and painted the bed to match. Used the original tailgate, wheel tubes, and header board. Sean
looks killer
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 02-13-2011, 08:56 PM   #33
CHIZZLER
CHIZZLER's Avatar
Not much to it.we started by sanding with 320.didnt even blow it off after.then the first coat was black put on with a brush.(yes a home depot paint brush).second coat we mixed orange and black to make brown.we put it on with a roller (yes a home depot roller).we put too coats.second coat was mainly on the hood and roof and bed rails.(nice and thick) third coat we sprayed the blue with a harbor freight gun.fourth coat we used white header spray paint and sprayed it from far back just misting it.after it was dry we started wet sanding with 1000 grit for a long time.you need to take your time and only break through the layers that you want.if you push to hard you will find bare metal.the slower you go the more first layer (black) you can find.after your happy with it you take some red scotch brite pads and hit the whole thing.this will take the sheen from the wet sanding away.hope this helps.we used duplicolor from napa.
61-crew cab D-max
Old 02-13-2011, 09:20 PM   #34
lakeroadster
Hey Chizzler, thanks for the "how to" data on your patina job. Your truck looks great!
John
Old 02-13-2011, 09:38 PM   #35
Malibob
Malibob's Avatar
Diggin it chiz
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 02-13-2011, 09:45 PM   #36
rideblue00
rideblue00's Avatar
This was on ebay like 5 years ago. This is what i would like mine to look like. But would be very time consuming to create. Like 45 years! lol
rideblue00 is offline   Reply With Quote
Old 02-13-2011, 10:02 PM   #37
CHIZZLER
CHIZZLER's Avatar
killer original patina.
61-crew cab D-max
Old 02-14-2011, 09:11 AM   #38
admiral grey bush
admiral grey bush's Avatar
Mine an my buddies 65/66. One pic i buffed the 66
admiral grey bush is offline   Reply With Quote
Old 02-14-2011, 09:21 AM   #39
skysoldier173rd
skysoldier173rd's Avatar
This is mine, courtesy of previous owner.
skysoldier173rd is offline   Reply With Quote
Old 02-14-2011, 09:28 AM   #40
Malibob
Malibob's Avatar
Originally Posted by bobcostas View Post
Hey Malibob
I dont have any close ups of the white roof on mine. I will be honest though. I plan on re-doing mine in gloss and rubbing it through- think I will like it a little better.
Flickr
Old 02-14-2011, 10:23 AM   #41
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
There is a guy in my area with a mid 60's VW Bug with a faux patina job. It looks like the areas were sanded down to bare metal and then he cleared the whole car. Now its shiny with a patina look. Its cool, but when you get close you see the shine. That part I dont like.
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-14-2011, 11:35 AM   #42
Stew64
Stew64's Avatar
I thought the faux-tina was soo cool I ordered the video from Trucks. They sent me a video labled faux-tina but it was just a recap of several other episodes. I called their 800 number several times and emailed several times and never got any response. I will never order anything from Trucks or Horsepower TV again.
Thought I would let you know before you get ripped off like I did.
1964 Longbed
Stew64 is offline   Reply With Quote
Old 02-14-2011, 04:22 PM   #43
steve'62
steve'62's Avatar
I know fauxtina is a love or hate thing, but I love them and think I'm gonna give it a shot!
steve'62 is offline   Reply With Quote
Old 02-14-2011, 04:26 PM   #44
61_FL_Apache
Who Me?
Worst case and you dont like it, repaint it.
Steve
Old 02-14-2011, 05:09 PM   #45
jimmydean
jimmydean's Avatar
Is it better/worse than the video I posted? I would expect the video to be more in depth than the online version. I got enough out of the online version to know what to do.
My truck has quite a bit of real patina, so I will use that as a guide if I get around to doing it.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-14-2011, 07:09 PM   #46
Stew64
Stew64's Avatar
Yeah, stick to the online version. Like I said, they sent me the wrong video then ignored all my phone calls and emails. No refund....nothing.
1964 Longbed
Old 02-14-2011, 10:24 PM   #47
richards72chevy
richards72chevy's Avatar
richards72chevy is offline   Reply With Quote
Old 02-14-2011, 11:38 PM   #48
jimmydean
jimmydean's Avatar
Damn, it was the wrong one all together? OK, that is a whole new level of suck.
<edit>This is a favorite of mine. I think I have talked myself into doing my truck, only following the existing patina pattern.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-14-2011, 11:48 PM   #49
CHIZZLER
CHIZZLER's Avatar
let me know if you need a hand jimmy.im over here in west linn.soon to be in sherwood.much bigger shop.
61-crew cab D-max
Old 02-16-2011, 01:45 PM   #50
50bomb
50bomb's Avatar
I posted this up many times wish i had more photos. I am really not into the fake patina stuff but when i had my truck the body shop painted it red oxide primer and I ended up not liking the color. So I primered it all black and left the top part white. After sometime I missed the orange color and tried sanding it down and got to tired to finish the sanding and it ended up like this. Wish I had more pictures of it but got lost when comp crashed.
50bomb is offline   Reply With Quote
