Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 01-13-2012, 12:40 AM   #26
65crew
65crew's Avatar
Re: Need pictures of your trucks to make a video.
here are some shots of the 65 when I first built is on a 95 chevy 1 ton frame
before I switched to the 2000 chevy 1500 frame and floor pan
65crew is offline   Reply With Quote
Old 01-13-2012, 09:27 AM   #27
jeffg1010
jeffg1010's Avatar
I like them both! Did you build them both from the ground up? And I noticed the 67 has a 4th door. That's a lot of work! I want a crew BAD!
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 01-13-2012, 12:45 PM   #28
65crew
65crew's Avatar
I did build both of them, the back doors are a little bit of a challenge on the 65 I made them out of fiberglass the door skins bolt on the 67 I used metal, I used the suburban rh door the lh I shortened a drivers door. the problem with that is the front has a different curve than the back this causes a taper or drop to the rear. I fixed it with a new door skin and I did a pie cut (5/8") on the front below the curve. A better way would be to use a suburban skin if you can find a non rusted one.
