#26 |
Re: 53 GMC Chassis Engineering front end install with 8.8 explorer rear end
What was the reason to take the pieces out of the bed? For tire clearance? How wide was the Ford diff, brake drun face-to-face-?
#27 |
Were the motor mounts already welded to the upper buckets or did you locate them?
Very nice cool build. ![]() |
#28 |
Tim,
You did a lot of work on your truck, you can be proud of your accomlishments and the truck is good for another 50 years! You ended up with a great ride enjoy it ! Bob
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#29 |
53chevtforever. I noticed in your photos that you are using lower a-arms instead of the stock MII a-arm and strut what is in the shown in the Chassis Engineering catalog. Did you modified the crossmember your self or was it a special order from Chassis Enginering. Either way your truck looks great.
#30 |
Looks awesome! Can't wait to reach that point in my build
Current project: 1946 GMC 1/2 ton on S10 Chassis, powered by a 5.3L LSx with a 4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=431631 |
#31 |
Yes...I plan to install mini tubs..I have 275/60/15 tires on eight inch rims...and can go bigger if I want...the width outside of drum to drum is 59 1/2 works great and are cheap in the salvage yards...most are 3.27 or 3.73 ratio. Tim
#32 |
#33 | |
#34 | |
#35 |
#36 |
#37 |
Thanks...I was in west plains two years ago and bought a seat from a mopar guy for my 73 plymouth duster...his name was bill and they call him small block..in the construction business...small world...Tim My wife is from paragould arkansas.
#38 | |
Did anybody mention STEAM in your system, or air pockets in the cooling system? Do you have a overflow on your rad.? Heat and cool it 5 or 6 times but make sure your overflow tank is full when it is hot and let it sit overnight and see how much water it takes out of the O F tank. Do you have a Inferred gun to check actual temp of things, engine, rad,. heads? I had the same problem and kept blaming it on the sending unit !! I made up a bleeder sleeve for the upper rad hose with a valve on it and bleed it until I had all the air out of the system. Make sure your rad cap is in GOOD condition and enough pressure not to blow your rad!! You will overcome!!!!!
#39 | |
#40 |
I really love your truck. Your interior is nearly dead on to what I want to do. I'd love to see some more pictures of that. Also when you installed that bolt in IFS how did you get it positioned? Did you have to measure or did it locate using existing holes or marks?
#41 |
![]() Join Date: Aug 2008
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Great looking rig!
Down......with the sickness!! |
#42 |
Is that the third row seat(Back seat) for a safari van or a front seat????, and where did you get the door panels??
I only hope mine turns out that nice. Great work!
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup Last edited by av8tr33337; 02-29-2012 at 04:25 PM. Reason: clarity |
#43 | |
to my upholstery guy...and he copied it pretty close...if you will send me your email I will send a copy of the pic I took to him...Tim |
#44 | |
av8tr33337@yahoo.com
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
#45 |
I have 2 questions, First , are your front spindles standard or 2 inch drop? Second, the explorer rear is offset to the passenger side so did you just run the drive shaft offset and have the universals make up the angle. Now that its running it looks great.
#46 |
Spindles are standard and the front springs are 350lb...325 lb might be better but after a while they will sag some...but you can adjust up again...mine with the 350 lb are just a little stiff to my liking but not bad...rear is offset but no prob with driveshaft angle...mopars and others are the same for years...I would be sure and box all of the frame. My grandson likes it alot...haha... Tim
#47 | |
Another picture at our local park. |
#48 |
Very nice truck! Thanks for the replies.
#49 |
You did a really nice job! Good looking truck!
#50 |
![]() Join Date: Mar 2011
Very nice.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
