#26 | |
![]() ![]() Join Date: Jan 2011
Re: Lowering on the cheap - 68 SWB C10 6 lug drum
CPP offers a 3" drop coil and either 2 or 2.5" spindles for your 69. I think the two can be purchased for about $310+ shipping. If you want to go that low that's the route I'd suggest or look at bagging it ![]() Either way man, maybe a 2" drop coil and a 3" spindle? I'd get some of the suspension travel back if I were you. Get it off the bumpstops. Just my opinion. You can bend A-Arms, etc. Dangerous stuff man. Take it easy.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#27 |
Ya it is rough riding but its only a weekend cruiser I probably will only get Miles on it this yr so I don't mind the rough ride. I think this winter I'll go for a 3" coil and 2.5" spindle, I would also like a little less coil drop in the back and get a 1" block.
I noticed when I swapped tires out it doesn't take much travel before the spring is loose so it probably is 2+ coil cut but I haven't noticed a problem yet with that. I don't take it on the freeway so am not as concerned with high speed pumps and having the coil shift. Thanks for the reply
69 c10 lwb |
#28 | |
Check out my Photos http://67-72chevytrucks.com/gallery/...ry.php?cat=769 L.L. N.M. 63 chevy c-10 67 chevy c-10 71 chevy Blazer 4x4 ![]() |
#29 |
Grandpa in the rustmobile...
I think a 3" drop coil is maximum.
After that you need control arms or spindles I believe
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#30 |
Old Blue is right - I wouldn't go much more than 3" spring if any. You will run into issues with alignment and the fact the spring would be too short to fit into the spring pockets. IF you jump a hill or something like Dukes of Hazzard, your coil spring could come flying out. Bad news ..
Drivability would suffer and IMO, start to become dangerous. I actually sold the blue stepper I had in this post but man I think it turned out ok with 3" CPP coils. It took it a while to settle but it did. a 235/70/15 front tire and it was right on the fender lip. I thought it looked fine, but you may want it lower. It starts to get expensive at that point.
#31 |
Yes Yes,, I think for now that's what I will do ,, 3" front and go with a 1" block in the rear with my 5" spring ,, that will look nice ,, thanks guys
#32 |
I have 1 coil cut from my front springs (2" drop?) They 'try' to come out going over big hills fast (think dukes of hazzard). I can hear them
#33 |
I wouldn't want to run into probs thats for sure...
