Old 12-24-2014, 06:11 PM   #26
poway
Re: Reverse lights not working.
Orangetonic:
Just looked at your build. It's beautiful!
Poway
poway is offline   Reply With Quote
Old 12-24-2014, 09:41 PM   #27
Orangetonicclicc
Orangetonicclicc's Avatar
Originally Posted by poway View Post
Orangetonic:
Poway
Thank you sir!
Orangetonicclicc is offline   Reply With Quote
Old 06-30-2016, 01:56 AM   #28
Justlearning
I have a question! My plan is to wire my reverse lights to a toggle switch hidden under my dash (long story) but here's my issue, I have power and I have ground and brand new bulbs but the lights won't light... Anyone have any suggestion as to how I could solve this issue
Justlearning is offline   Reply With Quote
Old 06-30-2016, 01:29 PM   #29
midniteblues
midniteblues's Avatar
In either case of stepside or fleetside the reverse lites and tail lites ground too the bed.
Besure all the mounting bolts and mounting areas are clean tight and rust free from the bulb socket too the bed mount.
Common problem on fleetsides is rust between the bed and light fixture where they mount in the pockets.
Then you need too make sure your bed is grounded too the frame and that connection is clean and tight.
Reverse lights on a hidden toggle switch is a good way too forget too turn them off or not even use them in the first place both not good.
A micro switch mounted securely too the shifter body or the oe setup is best.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
