Old 05-21-2011, 10:32 PM   #26
oldspowered67C10
Re: McGaughys 13" Front Brake Kit Interchange Parts
Hey guys. I have a 73-87 drop spindle/disc brake set-up on my 67. Does anyone know if the McGaughys kit would change the track width any from what I have now?
oldspowered67C10 is offline   Reply With Quote
Old 05-23-2011, 08:31 AM   #27
way2lo2
way2lo2
way2lo2's Avatar
probably not, might even be narrower. What spindles are whose spindles do you have now?
Dealer for Billet Specialties, Ridetech, Airlift, Vintage Air and others. Feel free to call, email, or PM for a quote.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Way2Lo2@aol.com <----also my paypal
http://www.hubgarage.com/mygarage/way2Lo2
way2lo2 is offline   Reply With Quote
Old 05-23-2011, 08:38 AM   #28
Whittaker
With CPP and McGaughys spindles that are their new modular ones 13" were what I looked into and they were 1- 1/8" total less wide than the typical kit using stock style spindles a separate hub and slide over rotor combination.
They how both places explained it to me.
Whittaker is offline   Reply With Quote
Old 05-23-2011, 10:24 PM   #29
oldspowered67C10
Ive have some no-name 2.5" drop spindles for a 73-87 that I bought probably 15 years ago. I like the reduction in track width(allows for deeper wheels) that the CPP spindles give you and was wondering if the McGaughys was similar. According to Whittaker that seems to be the case, thanks guys.
Old 12-29-2013, 05:52 PM   #30
BurlyCrew
What about the McGaughy's rear kits, do they use the exact same rotors? I have heard some issues with clearance on rear axles, do you know any more info on this and/or if its been rectified over the years?
BurlyCrew is offline   Reply With Quote
Old 12-30-2013, 09:25 AM   #31
CC69Rat
CC69Rat's Avatar
On the rear kit the problem is the center bore where the rotor fits over the axle. I had to get my Moser 5 lug conversion axles machined down a little to fit. It's not a lot, basically just shaved maybe a 1/16 to get the rotor to fit.
Another bit of input doing the rear kit if you use AC Delco part number 18P5 for the emergency brake cable it will fit perfectly. You can use the OE parts and adjustment rod, I had stock trailing arms on the truck I put together. ~7" static drop. With that em brake cable it had plenty of adjustment so if it needed .75" more or so you'd be fine.
The only issue I had with the MCGaughys stuff is the wheel studs are really short. Dorman 610-298.1 works nicely. I was running Billet Specialties if it matters.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 12-30-2013, 12:58 PM   #32
BurlyCrew
Ahhh okay, thanks for the info. :-)
Old 12-30-2013, 08:59 PM   #33
way2lo2
way2lo2
way2lo2's Avatar
the rear kit does use a C4 Front rotor like they use in the front, I'll have to check to make certain but I think the hub register is opened up some.
216 481-5219 office
216 481-4240 fax
216 789-1647 mobile
Old 05-29-2020, 09:17 AM   #34
Mator
Mator's Avatar
I know this is an old thread but its as close to my question as I can get in a search. I need to replace my pads on the McGaughey's disk brake kit I installed. What pads do I use? Is it the 2000 Chevy truck calipers? I emailed McGaughys but I am impatient. Thanks
Mator is offline   Reply With Quote
disc brakes
