Old 05-16-2011, 05:54 PM   #26
oldman3
oldman3's Avatar
Re: Jimbo's 67 Long bed step side build
That's todays post, tomorrow more work on the frame......Jim
oldman3 is offline   Reply With Quote
Old 05-17-2011, 04:55 PM   #27
oldman3
oldman3's Avatar
Work on the frame today.
Parts arrived, suspension stuff from CPP, hood, fender, etc for Classic Parts.
Old 05-17-2011, 04:57 PM   #28
oldman3
oldman3's Avatar
Pic 1 Marking up frame rails for C notch kit.
Pic 2 Another view.
Old 05-17-2011, 05:00 PM   #29
oldman3
oldman3's Avatar
Pic 1 Braced the frame and then made the cut out.
Pic 2 Marking holes for drilling.
Pic 3 Painted frame with Eastwood encapsulator paint before installing notch.
Old 05-17-2011, 05:03 PM   #30
oldman3
oldman3's Avatar
Pic 1 C notch installed with bolts and also tacked in place.
Pic 2 Top view of tacked bracket.
Old 05-17-2011, 05:05 PM   #31
oldman3
oldman3's Avatar
Pic 1 Both sides installed.
Pic 2 Both side were welded in solid.
Old 05-17-2011, 05:07 PM   #32
oldman3
oldman3's Avatar
New shock relocator pieces and new shocks.
Old 05-17-2011, 05:10 PM   #33
oldman3
oldman3's Avatar
Pic 1 New 5" drop rear springs, compared to old.
Pic 2 Installed new springs to check fit.
Pic 3 View of spring and shock.
Old 05-17-2011, 05:14 PM   #34
oldman3
oldman3's Avatar
Pic 1 Back on the ground, looked a whole lot better.
Pic 2 Also installed new rear stabilizer bar.
Pic 3 Installed new pan hard bar.
Old 05-17-2011, 05:15 PM   #35
oldman3
oldman3's Avatar
That takes car of the back, tomorrow will work on front suspension.
Old 05-18-2011, 03:10 PM   #36
oldman3
oldman3's Avatar
This is your typical drum to disc brake change, but wanted to post the pics.
Pic 1 Old drum brakes.
Pic 2 Old brakes, arms, springs, etc. removed, with new 2-1/2" drop spindles and 1-1/2" drop coil springs.
Old 05-18-2011, 03:13 PM   #37
oldman3
oldman3's Avatar
Pic 1 A look at the frame area, this will all be cleaned up later.
Pic 2 Uppper "A" arms, one blasted and one waiting.
Old 05-18-2011, 03:17 PM   #38
oldman3
oldman3's Avatar
Pic 1 Both upper arms painted with encapsulator paint.
Pic 2 New cross shafts and ball joints installed.
Old 05-18-2011, 03:21 PM   #39
oldman3
oldman3's Avatar
Pic 1 Lower "A" arms, etc.
Pic 2 All cleaned up.
Pic 3 Painted with encapsulator paint.
Old 05-18-2011, 03:25 PM   #40
oldman3
oldman3's Avatar
Pic 1 Everything together and put back on frame.
Pic 2 New 5 lug 12" disc brake rotors.
Old 05-18-2011, 03:30 PM   #41
oldman3
oldman3's Avatar
At this point I have a question for all of you, that knows these trucks (first time for me). The front end seems really wide compared to the rear. If I checked right the rear axle mounting flange to flange is approx. 60" wide,while the front measures at approx 65". Is this because of the conversion stuff used, or is the 70-72 narrower because they came from the factory with disc brakes? Someone give me a clue.
Old 05-18-2011, 03:32 PM   #42
oldman3
oldman3's Avatar
Installing new gas tank in rear (Blazer style from CPP).
Old 05-18-2011, 03:37 PM   #43
oldman3
oldman3's Avatar
Pic 1 Where cross sill would go.
Pic 2 Spacer I made to go between frame and tank, so tank would not be so far above the frame, and only part of cross sill removed.
Pic 3 Modified cross sill.
Old 05-18-2011, 03:39 PM   #44
oldman3
oldman3's Avatar
Because I lowered the tank, the frame had to be notched for filler tube clearance.
Old 05-18-2011, 03:41 PM   #45
oldman3
oldman3's Avatar
Sorry forget to post pic with truck back on the ground with new front end stuff.
Old 05-18-2011, 03:42 PM   #46
oldman3
oldman3's Avatar
Well, that's todays post, see you tomorrow.....Jim
Old 05-19-2011, 11:16 PM   #47
oldman3
oldman3's Avatar
Sorry so late posting, had things to go to.
While waiting for more parts, I started to remove the drip rail, cut off on the side first in short sections.
Old 05-19-2011, 11:19 PM   #48
oldman3
oldman3's Avatar
Then weld back together, and do the next section. This way I didn't let everything move around.
Old 05-19-2011, 11:22 PM   #49
oldman3
oldman3's Avatar
Here you can see across the front, you have the A pillar header, inside roof and outside roof, with the drip rail removed.
Old 05-19-2011, 11:23 PM   #50
oldman3
oldman3's Avatar
Just as before this got welded together a section at a time. Here the next section is cut out.
