#26 |
![]() Join Date: Dec 2015
Re: Emergency Flasher button
I'm sure all original parts, and the cancel feature was not working for left anyway. Thank you!
1968 Long Bed 2016 Honda Civic Coupe EX-T ticket magnet |
#27 |
Thanks for this lead! LMC did not have this.
I see you are also in Arizona. ![]()
#28 |
![]() Join Date: May 2010
#29 | |
Who Changed This?
![]() Join Date: Jan 2013
#30 |
My red flasher button was broken too when I bought my 71 C10 three months ago and the left signal would not cancel. I installed a new turn signal switch, the canceling cam and the upper column bearing. The new switch has the red knob and the correct plug so no adapter is needed. The bearing and the canceling cam were both worn and the left canceling spring was off the turn signal switch just laying inside the column. Anyway, I purchased all the parts from LMC and their shipping is super fast.
#31 |
![]() Join Date: Dec 1999
Wes at Classic Heartbeat has the switches as well.
Smitty '71 Short Fleetside Spring Valley, Ca. |
#32 |
Do you have any more of those red knobs?
#33 |
Old member
I have bought a couple of the turn signal switches with red flasher. As stated though I bought the whole thing. I figured I had to take it apart to swap I may as well do the whole thing.
Here is my thread on it. It was worth it to know it all will work together for another 50 years. ![]() https://67-72chevytrucks.com/vboard/...d.php?t=733325
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
