Old 08-01-2011, 11:57 AM   #26
CamaroChris
Re: 1986 suburban build with 6.0l swap
After I got the motor cleaned up I started the wiring FML I put the engine trans and T-case together, I figured this would be the easiest way to do the harness. don't worrrie the engine is very secure on the blocks
This is kinda the end result I'm going for, I want to get the wires tucked away as much as I can. so I rotated the Injectors around to hide the wires one the inside of the fuel rail
The mess
Another question is on the VSS, where do I get a plug for this connector? It seems to be different than the VSS plug in the engine harness
And last the fire wall. How in the EFF am I to get this S### off the firewall so I can seal seal and paint it. I tried wire wheel, it just melts it a smears it. I tried heat gun and scraper, just smeared. tried paint thinner, just made it all glob
I LIKE TRUCKS
1986 GMC Suburban Build Build link
1982 Chevy SWB 2wd Scottsdale, Build Link Sold
1987 Jimmy Build, Project Cheap A$$ Build Link
CamaroChris is offline   Reply With Quote
Old 08-01-2011, 08:49 PM   #27
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Grafitti remover. "Goof Off" is something we have up here. Search "shaved firewall" on here and you'll find some ideas.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 08-02-2011, 05:11 AM   #28
CamaroChris
So I'm over thinking this but I want it to be right. Is it bad to run a -6 AN braided hose ~15' from the tank to the fuel rail? Is there a way to use my stock 3/8th hard line from the fuel filter to about 2' away from the engine and using braided line from there? I have been searching through summit and I cant find parts to flare the line and adapt it to a -6 AN. any ideas? I seen the compression fittings but they are only rated to ~40psi
I LIKE TRUCKS
Old 08-02-2011, 10:17 AM   #29
Gordonr1973
Home Built '87
Read my build thread about 2/3 the way through where I did my fuel lines or Glock's where he has all of this stuff listed.
Tubing cutter to cut the line, put on AN grommet and back half of the fitting, flare tool to 45 degrees, there's AN fitting that is designed for this that screws onto the grommet to tighten the two pieces of the fitting on your line, good to go after that.
Gordon
Old 08-02-2011, 10:23 AM   #30
MTCK
MTCK's Avatar
I ran braided the whole way. Lots of mounting clamps...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-03-2011, 06:33 PM   #31
CamaroChris
Today I ordered all my fuel system, fittings and all the lines and fittings for the hydroboost and transfer cooler. Man that **** is expensive. Also ordered my radiator from ebay. Today was expensive.
I LIKE TRUCKS
Old 08-04-2011, 01:21 AM   #32
shenk10
shenk10's Avatar
Like Gordon said, for me the best way to get that stuff off is some kind of stripper. I did about two coats depending on how well it came off with a scraper and then just hit it with the wire wheel and it worked great, a lot easier than anything else I tried.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 08-07-2011, 04:42 AM   #33
CamaroChris
I need help, on the trans there is a neutral safety switch, on this "NSS" There are Two connectors. (which are ****ing GLUED in) why do they glue them? 3 harnesses I have done up were all glued! Anyway, the bottom connector has Four wires. BLK/WHT, WHT, YEL, GRY. These wires are from the neutral park switch to the PCM. the top connector has ~6 wires 2 PINK 1 PPL/WHT 2 LHT GRN 1 BLK WHERE DO THESE GO? These wires don't go to the PCM they went into the cab. I have searched tech with no luck. one should be a TCC to brake pedal? or does the TCC come from pin 33 brake switch on the blue connector?
I LIKE TRUCKS
Old 08-10-2011, 09:06 PM   #34
CamaroChris
I received my order from summit today. I was Surprised It came so fast, I ordered Monday at like 8pm. But a little bummed because I assumed that the 3/8 fuel rail fittings were 3/8 barb and its a 5/16 barb. a bought 25 feet of 5/16 line because of the return but is 5/16 too small for the feed line to the injectors?
I LIKE TRUCKS
Old 08-12-2011, 11:02 AM   #35
CamaroChris
Worked on my truck tonight. I finished the wiring on the engine and I am also getting ready to have the fire wall and engine bay painted. so I went to Interstate and bought a new front clip because the old wheel wells and fenders were rusty. I assembled it all together so I could fit and dril every hole I needed and mark the ones I'M not so I can fill them in. also saver some money on bolts. I went to LMC website ind the bolts I was looking for were 1$ a piece and the clips were 2$ a piece
so I stopped by Fastenal and they actually had all the bolts and clips I needed. the fender and wheel well stuff. I got enough to do 3 trucks for only 50$ tomorrow is fuel system day! anyway to the PICTURES!
I will clean this cut up this is just the ruff
I LIKE TRUCKS
Old 08-17-2011, 05:42 AM   #36
CamaroChris
Just bought the Ebay Entropy Radiator. Its expensive so it better me amazing...
I LIKE TRUCKS
Old 08-17-2011, 07:24 AM   #37
cletis
cletis's Avatar
The harness came out pretty clean. With the clip on it it looks like a truck again.
cletis is offline   Reply With Quote
Old 08-17-2011, 08:00 AM   #38
bloodybigblock
bloodybigblock's Avatar
ALL THOSE WIRES!!!!! more power to ya man, id loose my mind trying to to do the 6.0 swap! cant wait to see it finished
bloodybigblock is offline   Reply With Quote
Old 08-17-2011, 11:51 AM   #39
shenk10
shenk10's Avatar
good progress so far, did you order the radiator directly from them, because I don't see one listed for our trucks on ebay
Jordan
In progress....
Old 08-18-2011, 06:52 AM   #40
CamaroChris
I did a little of both. They had a listing on Ebay for a 73-91, But I needed the steam vent. So I Emailed Tony at Entropy and he built to suit. nice guy to deal with. when I clicked the "buy now" it took the ad down. I'm sure it will be up again soon. I spent along time looking for radiator options. there are a lot cheaper ones but This suburban is getting a little surprise and I wanted the best cooling I could afford.
I LIKE TRUCKS
Old 08-18-2011, 06:57 AM   #41
CamaroChris
It looks super frustrating, And when you first start It is WAY overwhelming. The hardest part is that I'm using 2002 factory Cruise,tow haul, A/C and adding electric fans. so It took a while tracking down all the info for which wires and pins needed to be added and changed around.
I LIKE TRUCKS
Old 08-18-2011, 01:04 PM   #42
shenk10
shenk10's Avatar
thanks for the info, can't wait to see everything put back together now
Jordan
In progress....
Old 08-22-2011, 06:41 AM   #43
CamaroChris
I picked up a 50mm BOV and a 38mm WG for the 'burb today. I got a good deal on the pair but the 38mm will be to small so I'm looking for a 44mm or a 50mm WG. Radiator gets here Wednesday. Tonight a pulled the gas tank Which is A Beioch, installed the new sending unit and walbro 340gph fuel pump. Friday and Saturday. I put the motor in for the 2nd to last time. I will put the radiator in this weekend and find a place for the 76mm snail. I will get the turbo piping hot and cold side done. get the truck running and tuned. then I will tear it all apart get the turbo shiz powdercoated and engine bay painted. and put it together and drive it for winter. save up and get the body painted next spring. One problem... I planed on using the corvette filter/regulator, I have already bought it and all the fittings. now I'm wondering if the regulator will prevent the injectors from getting pressure they need while in boost. I'm planning 8-10 psi
I LIKE TRUCKS
Old 08-22-2011, 10:55 AM   #44
MTCK
MTCK's Avatar
Very cool. I somehow missed the fact that you were going to be blowing into the motor... There was a guy in the mid 2000's who built a 1/2 ton chevy with a turbocharged 6.0 in it. I recall both the fueling system and engine management were quite involved, and he had detailed write ups on it. Do a search for Parish. Blue single cab 4x4 silverado... Good progress!
-Marcus
Project Plow Truck
Old 08-23-2011, 06:28 AM   #45
CamaroChris
This was decided last week...
I LIKE TRUCKS
Old 08-23-2011, 08:20 AM   #46
Thealien
Thealien's Avatar
Looks great
Old 08-23-2011, 09:42 PM   #47
CamaroChris
So I have a guy coming Friday evening to soda blast the frame and underneath the body so I can seal it all up and get rid of some rust. I need opinions. Spray por15 (I already have enough or should i use something else?
I LIKE TRUCKS
Old 08-26-2011, 10:04 AM   #48
CamaroChris
Driving to work yesterday. Im sure its totaled, I will have the cash now to get my interior redone and my sound system put in .
Also got this in the mail from Entropy
And started working on final placement of this :P
sorry for the blurry pictures, this is a 50mm Tial BOV
hydroboost lines to new PS pump. I have read a lot about the fittings you need to make the factory lines work with the pump. I took these lines off an 1986 3500 and they fit just fine. hard lines took some massaging to fit but it worked out nicely.
I LIKE TRUCKS
Old 08-26-2011, 01:22 PM   #49
Cherub
Cherub's Avatar
gotta love that hydroboost
Cherub is offline   Reply With Quote
Old 08-28-2011, 06:37 AM   #50
CamaroChris
So few things this weekend, Entropy sent me the wrong radiatior. I need the 19" core and Tony sent the 17" core. simple mistake. I messaged Him and waiting for a reply. I hope I don't have to pay shipping again. Next, there was lots of rust on the frame of this thing and some on the underneath the body, I'm going to have a tun od Doe wrapped up in this thing by the time it's done. I was afraid it would just rust more and ruin my new paint and all my work. so I hired this guy to come out. It was pretty awesome to watch him do this. he is hard core, I would move the lights around so he could se and that shiz HURT and he is in a wife beater...
VIDEO
VIDEO ^^^
I LIKE TRUCKS
4x4, 6.0l, lq4, suburban, swap
