Old 06-12-2011, 09:15 AM   #26
weaintscared
weaintscared's Avatar
Re: 69/72 Restoration/Rebuild (we ain't scared)
Well I am going to try to get the bed off today and get started on it.
Got a tank coming from another member so I can work on that to.
weaintscared is offline   Reply With Quote
Old 06-17-2011, 03:27 PM   #27
weaintscared
Got gas tank in today to go under the bed!!!!! From oldblue1968chevy Thanks
Old 06-17-2011, 04:02 PM   #28
RCbowtie69
RCbowtie69's Avatar
Hey from N.C.You're looking good,nice motor.Keep the pictures coming & keep on truckin''
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 06-17-2011, 04:07 PM   #29
ll____b0t____ll
ll____b0t____ll's Avatar
Looks like a great project , ill keep on eye on this one i love these kind of projects .
My faverite saying is "If its Factory..Fix it"!
Keep up the good work and good luck.
ll____b0t____ll is offline   Reply With Quote
Old 06-18-2011, 08:57 AM   #30
weaintscared
[quote=ll____b0t____ll;4740722]Looks like a great project , ill keep on eye on this one i love these kind of projects .
Keep up the good work and good luck.[/quote
Looks as if I have a money pit!!!
Problem is I'm puting money in it and not digging money out of it
Old 06-18-2011, 01:22 PM   #31
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks like a good start but toss that flex fan they are known for coming apart
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 06-19-2011, 02:55 PM   #32
weaintscared
Did't no they come apart, someone else said ditch it & put electric fans on to gain HP
Old 06-19-2011, 08:39 PM   #33
FRENCHBLUE72
PROJECT 7DEUCE
The last one I had come apart on my 74 nova almost came all the way through the hood and scared the crap outta me... E fans are the way to go..
MEMBER #6377
Project "7DEUCE"
Old 06-19-2011, 10:30 PM   #34
weaintscared
Which way do I go single or dual fan? Does anyone no which car or truck came with electric fans that would fit and work?
Old 06-19-2011, 10:48 PM   #35
BlackTopMotors
http://www.jegs.com/c/Cooling-AC-Hea...10117/10002/-1
Maybe this will help?
BlackTopMotors is offline   Reply With Quote
Old 06-20-2011, 09:50 AM   #36
weaintscared
I'll check them out Thanks
Old 06-23-2011, 12:03 PM   #37
weaintscared
Well I got me a set of electric fans so the old fan can go!!! More cool,More Horse power,,,
Old 07-09-2011, 11:33 AM   #38
weaintscared
Beds off and welded up holes in the top rail and on bed sides where molding was... Little at a time one day it will be done...
Old 07-30-2011, 10:26 AM   #39
weaintscared
Well what you think???
Old 07-30-2011, 10:29 AM   #40
weaintscared
more work
Old 07-30-2011, 11:52 AM   #41
Cameron 1137
Cameron 1137's Avatar
WOW! looks like you hit the welding hard. i wish i had some welding skills. you are going to have a great truck when your done. ill be watching this one.
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 07-30-2011, 01:04 PM   #42
mcbassin
Still Learning
mcbassin's Avatar
Looks like a great project. Subscribing.
mcbassin is offline   Reply With Quote
Old 07-30-2011, 02:43 PM   #43
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by fastwillie 696969 View Post
that harmonic balancer needs to go wont hold up ,flex fan toss that in the can too,just my 2 cents
I second that. Outer ring slippage or the rubber getting hard make them work poorly. Any damage to the stock cast iron balancer hub area makes it a ticking time bomb. With a performance engine you really want better than stock on there and getting the SFI spec part wouldn't hurt either.
I have see too many destroyed shrouds / hoods / radiators from flex fans coming apart to ever use one again. The flex fan robs power and doesn't work that well any way. Get a good 7-blade clutch fan on there instead. More power efficient and will cool the engine much better. Electric fans are OK too if you get them into a shroud to work efficiently.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-01-2011, 05:01 PM   #44
RCbowtie69
RCbowtie69's Avatar
looking like progress is being made,keep the pictures coming & Keep on Truckin'
Old 08-06-2011, 09:51 AM   #45
weaintscared
More welding time,,, It never stops does it?
Old 08-06-2011, 10:57 AM   #46
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Rain gutter shaved is the cleanest thing dont to a firewall!!!!
John
1999 Toyota Tacoma 4x4
Old 08-06-2011, 02:18 PM   #47
weaintscared
weld cleaned up and ready for the new step.. more pictures later
Old 08-06-2011, 08:24 PM   #48
Cameron 1137
cool. gutter looks great!
Cam
Old 08-06-2011, 09:26 PM   #49
weaintscared
Ok got it finished up & primed in got the nasty looking seam on the back of the roof welded up and smoothed out & primed in Pictures to come....
Old 08-13-2011, 11:40 AM   #50
weaintscared
ok here is the pictures of it primed in. Add a couple of pictures of the gas cap relocation that's going to be behind the rear tail light.. What you think???
