Old 08-11-2011, 03:28 PM   #26
72SWBChevy
72SWBChevy's Avatar
Re: 68' Chevy c10
Originally Posted by XxCHEVYMANxX View Post
Thanks 72SWBCHEVY. I do have the load leveler, and thanks for the core support tip. right now the hood is off, but not core support. I thought it looked like it might hit rear motor mount support. (cross member ?)
Aghh I see now, that top piece is up past the floor bottom, others will need to chime in, I have never removed a manual shift tranny of this style, not much room for it to move around while taking it out..maybe you could loosen the front cab mounts and tilt the cab back some to give you more room..?
1977 Camaro 468 BBC - SOLD -
1972 Chevy SWB....in the works!!
2006 Crew Cab Dmax/Allison Summit White-SOLD-
2009 Toyota Tacoma V6 Pre Runner - daily driver -
my build thread -http://67-72chevytrucks.com/vboard/s...95#post4774595
72SWBChevy is offline   Reply With Quote
Old 08-11-2011, 03:51 PM   #27
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: 68' Chevy c10
Thanks again for the help. going to see what happens. if it wont go, I'll just remove the trans. would be easier if I didnt have to do it in the gravel drive, but I will make it happen!
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 08-14-2011, 01:01 PM   #28
XxCHEVYMANxX
Re: 68' Chevy c10
Here's the latest. got the engine/trans out, and I did have to raise the cab to clear the trans. overall it went pretty smooth. the most trouble came from one bolt when removing the front clip. you guys know what I mean (that last bolt!)
Oh well, all that hard work makes the end result that much sweeter.
here's a couple pics.
John
Facebook LoL
Old 08-14-2011, 05:56 PM   #29
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: 68' Chevy c10
i took my tranny out and engine together, i almost flipped the cherry picker but it went out smooth/
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 08-15-2011, 10:10 AM   #30
72SWBChevy
72SWBChevy's Avatar
Re: 68' Chevy c10
Glad it all worked out. Its always that last bolt that will get ya!
Old 08-15-2011, 11:43 AM   #31
XxCHEVYMANxX
Re: 68' Chevy c10
It's no joke when you see that cherry picker coming off the ground!
Thanks 72SWBChevy, Now that I got that one out, it's time to get the others pulled. maybe I can just skip the last bolt situation...
John
Facebook LoL
Old 08-15-2011, 12:19 PM   #32
rondog4416
rondog4416's Avatar
Re: 68' Chevy c10
nice start on a cool truck !!!!! i lived in Decatur for a few years. worked for the city transit as a diesel tech. good luck with your truck
rondog4416 is offline   Reply With Quote
Old 08-15-2011, 03:36 PM   #33
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks rondog, Decatur is not so great is it? Originally from Texas, I'll go back in the next few years.
John
Facebook LoL
Old 08-16-2011, 04:05 PM   #34
XxCHEVYMANxX
Re: 68' Chevy c10
Ok I got engine/trans #2 out. It went a lot smoother this time.
Heres a couple more pics.
John
Facebook LoL
Old 08-19-2011, 09:19 AM   #35
XxCHEVYMANxX
Re: 68' Chevy c10
Well my 327 is off getting rebuilt. I still have to pull engine/trans #3, and the crossmember from the 85' donor truck. the crossmember in the 68' has one bolt left on each side, so it's ready to come out. Thinking about a one piece driveshaft, not sure though.
John
Facebook LoL
Old 08-25-2011, 07:53 AM   #36
XxCHEVYMANxX
Re: 68' Chevy c10
Update, been workin on the truck when im not at work. the firewall,frame degreased and powerwashed. the bench seat and in cab fuel tank are out. I'll get some pics up soon.
John
Facebook LoL
Old 08-26-2011, 07:10 AM   #37
Blue666
Re: 68' Chevy c10
You're making great progress. Keep it up.
In your first post - third picture, you show a huge rear mounted fuel tank. Can you provide some details on what's from & what size (gallons). Is it set up for fuel injection?
Thanks.
Blue666 is offline   Reply With Quote
Old 08-26-2011, 08:54 AM   #38
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks.
Hey Blue666, Thanks. The tank is an LMC rear mount kit.(basicly a blazer tank) its 21 gal. truck will be carburated. I guess you could use it for fuel injection. If I had to do it again I would use a 60s car tank where the filler is behind license plate. I did'nt find this site soon enough.
John
Facebook LoL
Old 08-26-2011, 07:32 PM   #39
XxCHEVYMANxX
Re: 68' Chevy c10
Here's a few more pics. a little progress.
just about everything off the firewall. still have to sand it.
fuel tank and seat out.
shift hump back from blasting, and painted.
I seam sealed the in cab seam. (not sure if that will cause any problems)
also made a patch for the fuel fill hole in cab.
John
Facebook LoL
Old 08-27-2011, 09:20 PM   #40
XxCHEVYMANxX
Re: 68' Chevy c10
pulled engine\trans out of 85' donor this morning. It took more time than the other two. Now I can pull the crosmember tomorrow.
John
Facebook LoL
Old 08-28-2011, 09:14 PM   #41
XxCHEVYMANxX
Re: 68' Chevy c10
Ok I swapped crosmembers today.
test fit looks good just one hole to drill on each side and elongate a couple more. Happy I read the swap thread on here.
John
Facebook LoL
Old 08-30-2011, 06:39 PM   #42
XxCHEVYMANxX
Re: 68' Chevy c10
well I have the crossmemeber back out so I can do the cleanup,paint, and rebuild. also grabbed the power steering, and brake booster. It looks like the BB wont work without bracket alteration. I knew I would have to modify the armature from brake pedal to booster. not sure but I might need a different year booster. searched for this swap, but couldnt find any answers. the donor is an 85' GMC 1/2 ton. heres a pic of the booster. was also going to use a different master cylinder. Thanks for any info.
John
Facebook LoL
Old 08-30-2011, 06:47 PM   #43
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
if you're speaking of frame brackets you can use 73-87 motor brackets with the big block. Any truck is fine as they are all the same small or big block for those years but work great for big block for our year trucks.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-30-2011, 06:56 PM   #44
XxCHEVYMANxX
Re: 68' Chevy c10
sorry I should say the brackets I'm referring to are the brake booster (6 bolt mounting.) thanks for the reply.
I should,nt have wrote BB for brake booster. my mistake
John
Facebook LoL
Old 08-30-2011, 07:02 PM   #45
VA72C10
VA72C10
VA72C10's Avatar
Re: 68' Chevy c10
my bad
On the brake booster, you can buy the correct bracket and bolt that booster to it, or just modify the lever as you said....but the ideal thing is to get the correct bracket as the angle is wrong if you just modify the arm and pedal pressure will be harder.
Old 08-30-2011, 08:36 PM   #46
XxCHEVYMANxX
Re: 68' Chevy c10
Thanks VA72C10, that helps alot. I will get the correct bracket and keep movin forward.
John
Facebook LoL
Old 08-31-2011, 01:28 PM   #47
72SWBChevy
72SWBChevy's Avatar
Re: 68' Chevy c10
Looking good!!
Old 09-01-2011, 07:54 AM   #48
XxCHEVYMANxX
Re: 68' Chevy c10
Got my engine back from the machine shop yesterday. now I have to paint it.
before I can do that I have to get that crossmember back in so the truck can be moved. Its the only spot left in the garage I can use.
heres a pic of the front frame w/por 15.
John
Facebook LoL
Old 09-01-2011, 01:03 PM   #49
XxCHEVYMANxX
Re: 68' Chevy c10
Looking good!!
Thanks 72SWBChevy, almost out of money again.
your build is lookin awesome!
John
Facebook LoL
Old 09-04-2011, 11:00 AM   #50
XxCHEVYMANxX
Re: 68' Chevy c10
A little more done! crossmember degreased, and painted satin black. Lucky for me its in good shape.. ball joints, seals,and brakes dont need replaced yet. heres a few pics.
John
Facebook LoL
68 chevy, c10 2wd fleetside
