Old 02-12-2012, 12:24 AM   #26
ryanroo
ryanroo's Avatar
Re: 72 k20 project
got the front axle back in and put the cab and clip on for a look
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 02-12-2012, 12:39 AM   #27
VA72C10
VA72C10
VA72C10's Avatar
Re: 72 k20 project
Looks tough! I like it!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 02-12-2012, 10:18 PM   #28
ryanroo
ryanroo's Avatar
Re: 72 k20 project
fiddled around today trying to learn some rust repair i also started stripping the paint off the fender. i can tell that process is going to be good for my mental wanderings
the offending hole
i am new to this stuff, but tape seemed like a good way to get strait lines for cutting
traced the old part onto the non rusted fender and chopped out what i needed
going in.
after some sanding
closer shot
as much paint removal as i got done before i had to stop and burn a slab of beef for dinner
the patch isn't as good as i had in my head before i started but i am going to make a dolly tool tomorrow that will hopefully get the low spots out. it will still need a little skimmer of bondo. i suppose it could be worse for the first time I've ever done it
72 K20 12v build
Old 02-13-2012, 12:52 AM   #29
mjensen
mjensen's Avatar
Re: 72 k20 project
Looks like a fine job to me.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 03-02-2012, 10:35 PM   #30
ryanroo
ryanroo's Avatar
Re: 72 k20 project
ive been sanding paint whenever i felt like it after i get home from work and the gym during the week for the last couple of weeks. my wife was back for the last two weekends and the week in between, so i did absolutely nothing in regards to the truck (although i was rather forcibly told i needed to purchase my engine and i should also either buy a trans or some tool that i wanted as a valentines present ). anyhow, all that is left is the front right fender and the hood, although i may end up ditching this hood so i will be ignoring it for the time being. i also think that i will take the cab to the blaster and have the impossible spots and most of the interior blasted. that will happen after the engine gets placed though as i plan on modifying the firewall to allow me to set the engine back a touch further.
i also got the dent in the back of the cab that i have no idea how it happened to be pushed back in for the most part. im not sure if its noticable in the pic
ryan
72 K20 12v build
Old 03-02-2012, 10:42 PM   #31
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Nice progress and great work on that rust repair!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-03-2012, 12:05 PM   #32
RCbowtie69
RCbowtie69's Avatar
Re: 72 k20 project
Nice progress you have made,hope to see more picture soon.Keep the hard work going forward & keep on truckin'.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 03-09-2012, 11:39 PM   #33
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i had a lot of plans for this weekend but, at 10 this a.m. i found out i need to build an ejector nozzle that has to be in the Mohave monday night or tuesday morning. so tomorrow i have to do that as well as hopefully get a little more done on the 72 stuff that i need the to do at work. hopefully i wont have to go in sunday and finish the nozzle.
anyhow, i cut some stock
this will end being the gooseneck ball mount. the tubes are 2"x4"x1/4" and they extend out to the stock frame rail web. my frame boxing plate will butt up to the 2"x4" tube and should make the overall product very stout. i will figure out how i am going to actually mount the ball later. i hope to be able to either rob a B&W system or copycat it.
as you can see the rear axle is out. more on that later this weekend i hope.
Ryan
72 K20 12v build
Old 03-10-2012, 01:29 AM   #34
Maxxd07
Maxxd07's Avatar
Re: 72 k20 project
Wow, great stuff. Must be something about the name Ryan, since there is now 2 of you doing cummins conversions in 72 K20s. Cant wait to see it done!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 03-10-2012, 02:09 AM   #35
coggonobrien
Re: 72 k20 project
i take it you fabbed the boxing plates? how thick of plate did you use?
coggonobrien is offline   Reply With Quote
Old 03-10-2012, 02:09 AM   #36
coggonobrien
Re: 72 k20 project
also how much did you buy?
Old 03-10-2012, 09:13 AM   #37
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i used 3/16" p&o plate for the boxing plate. i'm not sure how much i bought so far. i would guess what i have used at 12-14 ft^2 but i have no idea. i buy it from work and i bought a partial at first and used parts of it and then i cut the funny shaped parts from a different sheet we had laying around at work. i am quite sure that a full 4'x10' sheet would be more than you need. for what i've made so far i would say i have spent 80-90$. keeping in mind i get the steel for barely more than cost
72 K20 12v build
Old 03-11-2012, 09:51 PM   #38
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i ended up at work for about 12 hours saturday and 7-8 today so i didnt get nearly the progress i had hoped for. but i do have a little to show for my weekend
i started tacked up the rear section of frame rail that i am replacing due to some ugly rust pitting that i dont like.
i made some provisions for a bumper and receiver hitch mount
the holes were drilled out to .75" and sleeved with .75"x.120" wall DOM. i countersunk the holes and welded in the groove and sanded it all flat
this is sitting on the frame that it will replace. i had intended to have this all welded up and the new shackle hangers in place this weekend. i didnt have the time to cut and tack up the hangers but they are ready for cutting on the table when i get around to it
ryan
72 K20 12v build
Old 03-15-2012, 07:56 PM   #39
Dieselwrencher
Re: 72 k20 project
Very nice fab work! It looks great! I plan on doing a B&W style gooseneck in mine as well. Dang you. I keep seeing people box their frames and I think I'm going to have to do it now too. I have a different route I'm going with mine again so the extra strength can't hurt.
Ryan
Old 03-15-2012, 10:01 PM   #40
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks! i think if i can get my machinist friend to do it for me i think i will make my own turnover ball dohicky. of course if i find a cheapsky B&W i would be time and probably money ahead to just use whatever of it i need to.
i wanted to box the frame partly because i like doing fabwork, and partly because i know that these frame are a little limp as is. if i end up getting stupid with the diesel power i want something solid to tie it too.
what is the current plan of attack?
72 K20 12v build
Old 03-16-2012, 02:08 AM   #41
cub1450
cub1450's Avatar
Re: 72 k20 project
This thing is going to be sweet!
Keep up the god work.
cub1450 is offline   Reply With Quote
Old 03-17-2012, 11:43 PM   #42
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i had a little motivation and time today so i got a few things done. i had some friends stop buy and we spent enough time jackjawin that i didnt get as much done as i planed. but i made it into town before the hardware store closed so i have the required bolts to put it all back together if i get that far tomorrow.
these are the new shackle hangers. there will be a little more to them when its all said and done. material is 1/4"
managed to hack the frame all to pieces
and got the replacement part sat in there before i had to shut down. i tacked the little tabs on in my way so tomorrow i will fix that and burn it in
72 K20 12v build
Old 03-18-2012, 12:24 AM   #43
Dieselwrencher
Re: 72 k20 project
Great work! Loving your hangers too!
Ryan
Old 03-18-2012, 09:29 PM   #44
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
got a little more done.
tacked in
welded
a few views of the hangers
these will be a little more gusseted and plated in. eventually. right now i just want to make it roll again.
nailed the width
hopefully i will be able to go get my engine at the end of the week. that is why i want it to roll. that depends on availability but fingers are crossed.
72 K20 12v build
Old 03-20-2012, 11:36 PM   #45
mjensen
mjensen's Avatar
Re: 72 k20 project
That's it! I'm taking my project off of here!
Looks really nice. I like how you're doing the rear section of the frame.
Mike
Old 03-21-2012, 05:16 AM   #46
72KAY20
72KAY20's Avatar
Re: 72 k20 project
Very nice looking welds. Going to be a heavy duty K20 beast
Can't wait to see it finished.
72Kay20 Bel Air, MD
1972 Hugger Orange K20 LWB
350, 4wd, 4spd Sm465, Dana 44, HO52
Other Toys
69 Cortez Silver Z28
86 White Buick T Type
72KAY20 is offline   Reply With Quote
Old 03-21-2012, 08:06 AM   #47
ryanroo
ryanroo's Avatar
Re: 72 k20 project
thanks guys. i really liked how that rear section came out too. sort of makes me wish i would have just built a whole new frame... to far along for that though.
hopefully it will be heavy duty, but i'm sure it'll be heavy either way. haha
this wandered into my driveway last night. the truck is completely thrashed.
however, this is in great shape and runs good. has 160,xxx. the truck came from a mine and smacked a crib while driving. wrecked the transfer and trans and i will have to look into the rear axle. tie rod was smashed... and the body was totall hammered as well. perfect. it is a 96
72 K20 12v build
Old 03-22-2012, 11:18 PM   #48
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i got the stationary spring hangers for the rear fixed up. years ago the springs were coming out and good old Midwestern rust had frozen the bolts. my dad torched them out and lacking the proper skill he managed to mangle the bolt hole on the drivers side. it had a cheezball welded washer fix so i cut it off and made a better repair out of .25". i welded that on and squirted a little paint. hoping to have it back on its wheels tomorrow. i will get a picture of it all then.
after that fun, i think i may start dismembering the donor dodge in my driveway for the amusement of my neighbors.
ryan
72 K20 12v build
Old 03-23-2012, 11:37 PM   #49
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i did get the truck sitting on its wheels again.
i also started taking apart the dodge. i got the dash all pulled apart so i can save the harness in case i should need to steal any of it. i didnt take any pics, but just imagine a tornado in a oklahoma trailer park and you get the idea of what the cab looks like now.
72 K20 12v build
Old 03-23-2012, 11:49 PM   #50
birdistheword
birdistheword's Avatar
Re: 72 k20 project
Lookin good. Love the Cummins swaps. Would like to do one myself someday.
birdistheword is offline   Reply With Quote
