Old 05-08-2012, 01:34 PM   #26
Ford Assassin
Ford Assassin's Avatar
Talking 2wd Conversion Progress Pics.....
Got the 14 bolt pulled and sold. Went ahead and pulled the 4l80e and NP208c transfer case too. Dropped the 4L80e off at my trans shop to be converted to 2wd. I also bought a poly urethane A-arm bushing kit, ball joints, calipers, rotors, ceramic pads, brake hoses, pitman arm, and steering box for the front end rebuild (mostly from RockAuto).
Burned out the old bushings last night, still need to remove the bushing 'cups'. I plan on getting the 5.3 pulled today and start on removing the rear 4x4 spring hangers to replace them with the 2wd versions.
Pics as requested:
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 05-09-2012, 08:53 AM   #27
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Bought my old K5 back, now receiving a 5.3 swap...
Nics man!! Thats a lot of work to make it 2wd..
tvblazer78 is offline   Reply With Quote
Old 05-09-2012, 10:09 AM   #28
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
So you where running a 80E/205 before? Want to sell the t-case adapter ?
bowtieguy79 is offline   Reply With Quote
Old 05-09-2012, 01:46 PM   #29
Ford Assassin
I guess you didn't read post #7....
But I'll still sell my adapter, $100 shipped.
Cable
Old 05-09-2012, 02:13 PM   #30
bowtieguy79
Ephesians 2:8
Re-read, thought I saw 205, I see you typed 208.
lol, you shift gears like Paul Walker in Fast and the Furious. I think I'm caught up now
Old 05-14-2012, 03:42 PM   #31
Ford Assassin
Went to mock up the 2wd crossmember and its about .5-.75" too narrow...
Prob going to cut it half down the middle, bolt it up, the plate/box the cut back up.
Or remove the A-Arm mount rivets, slot the holes outward, then bolt them back on.
Cable
Old 05-21-2012, 12:42 AM   #32
Ford Assassin
Time for another update....
Ended up using a ratchet strap to suck the frame rails in enough to get the crossmember installed.
I also ended up scoring a pair of 56" rear springs (stock is 52"). Since I was changing to 2wd rear hangers anyway, I placed them 4" further back. The springs themself have an offset center pin by 4" to keep the wheelbase the same.
The front A-arms have new urethane bushings and new ball joints installed.
I plan on getting the diff installed tomorrow, along with the new 2wd steering box. The 5.3/4L80e to follow.
Cable
Old 06-07-2012, 01:25 AM   #33
bL.A.zer90045
Im following your lead man!!! Lol,YOU sir have convinced me to go ahead and now(after my 87 Elco is finished up shortly) to do this to my 86 which I modded as youve done to a full vert ising a 74 donor!!!
only ive got a 94 Corvette lt1 with 8,000 miles on it(its my first time,be gentle please:p staying tuned for the show!!!
bL.A.zer90045 is offline   Reply With Quote
Old 06-09-2012, 01:40 AM   #34
Ford Assassin
http://67-72chevytrucks.com/vboard/s...d.php?t=525702
Cable
Old 06-13-2012, 07:32 PM   #35
Eagle Custom
If you dont mind me asking what radiator are you using
Eagle Custom is offline   Reply With Quote
Old 06-13-2012, 07:37 PM   #36
Ford Assassin
Not at all, I'll share any info on my truck.
Its a stock replacement 3-row brass-copper from the local Autozone (replaced last in 2007).
Cable
Old 06-17-2012, 09:08 PM   #37
Ford Assassin
My buddy got creative....
Cable
Old 07-18-2012, 08:13 AM   #38
Ford Assassin
Talking Re: Bought my old K5 back, now receiving a 5.3 swap...
Thought it might be fun to mop the floor with a few folks in my square, so I added this over the weekend....
Cable
Old 07-18-2012, 08:22 AM   #39
68Timber
I know the pieces fit
68Timber's Avatar
Wow. That'll do it. What's the advertised hp?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-18-2012, 09:09 AM   #40
Ford Assassin
On a bone stock 5.3 w/manifolds, stock cam, etc... 450HP on the crank. Since I have a boost friendly cam and long tube headers along with the bigger throttle body and meth injection, I am aiming for 400 @ the wheels.
Honestly the dyno numbers don't interest me a whole lot, quarter mile numbers are another story. Too many times I've seen Supras making 700HP on a dyno, then run 12's in the quarter....
Cable
Old 07-19-2012, 02:18 PM   #41
Firebirdjones
Same setup I got for my 6.0 blazer swap,,,,you'll like it
Firebirdjones is offline   Reply With Quote
Old 07-19-2012, 02:38 PM   #42
Ford Assassin
Dyno'd it yesterday, put 430/440 HP/TQ to the ground with 7 psi.
Cable
Old 07-28-2012, 12:13 AM   #43
Ford Assassin
Dyno vids:
Cable
Old 12-18-2012, 01:22 PM   #44
67cheby
67cheby
67cheby's Avatar
nice, just starting on mine 4x4 to 2wd convesion plus 5.3
67cheby is offline   Reply With Quote
Old 01-21-2013, 06:41 PM   #45
Ford Assassin
I finally hooked up a boost gauge on Saturday and much to my surprise I am making 10-11 psi when the kit is suppose to be 7 psi on a 5.3 litre.*So I borrowed a SnapOn scope from a buddy and took a look down a spark plug hole. Sure enough, flat top pistons and until at least 2007 no 5.3 had flat top pistons. So it looks like I have a 4.8 afterall.Still making more than enough power so I am not too upset about it, don't have more than $200 in the long block anyway.
Cable
Old 01-21-2013, 07:39 PM   #46
68Timber
68Timber's Avatar
A few months back the same thing happened to the Hot Rod magazine crew on an engine they threw a turbo on. Seems like it made 800 hp or so but it revved to 7000 rpm. So they had to look closer at what they had and it turned out to be a 4.8. That was kind of an eye-opener since everyone loves the 6.0's best. All of that gen truck motors are great imho.
John
74 Honda Z50 build
