Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-12-2012, 03:41 PM   #26
Curt's_72
Curt's_72's Avatar
Re: Curt's '72 K20 Resto-mod
I scored these 16.5x9.75 wheels recently. Finally found a set with the outer nubs.
Name:  9.75x16.5 outer hubcap nub1.jpg
Just took them to get blasted and powdercoated. Gloss white. I should have them back next week.
I think I need them rather than the 8.25's that are currently on the truck. We'll see once I get them.
The backspacing is different on all three sets that I have. Backspace is only .25" greater than the 8.25's. That concerns me, because I don't want them to stick out too far.
Curt's_72 is offline   Reply With Quote
Old 01-12-2012, 03:52 PM   #27
patrickth
I know all areas are different, but do you mind telling me what the budget quote was for blast and powder coat? I have the same decision to make myself right now.
patrickth is offline   Reply With Quote
Old 01-12-2012, 05:52 PM   #28
jeremy zander
jeremy zander's Avatar
Nice..good progress...I paid $300 for blast and powdercoat on my 16.5 wheels
WTB 1972 CHEVY 3/4 4X4
1971 chevy c30 4x4 NAPCO (project)
1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers
1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete
2006 chevy LBZ crew cab duramax,4 inch,beadlocks
2015 chevy tahoe Z71 my fifth one,love em
2016 chevy 2500HD Z71 LTZ duramax midnite
2018 chevy suburban Z71 midnite
jeremy zander is offline   Reply With Quote
Old 01-12-2012, 08:49 PM   #29
68 Four on the Floor
68 Four on the Floor's Avatar
Good looking truck. Gonna be sweet with the yellow/white two tone. I know a guy in town that has one. Its different stands out. Keep at it!
68 Four on the Floor is offline   Reply With Quote
Old 01-12-2012, 08:54 PM   #30
patrickth
Wow, expensive. I only paid $200 more for my whole truck. Guess I will have to do it myself. Hoping to make things simple. They do look good though.
Old 01-13-2012, 10:16 AM   #31
Curt's_72
Curt's_72's Avatar
The quote was $30 to $32 dollars a wheel. This was a shop here in my hometown. The ones currently on the truck were the same cost from another outfit.
I'll post pics when I get them back.
Old 01-13-2012, 10:21 AM   #32
Curt's_72
Curt's_72's Avatar
Jeremy,
If that was for all the wheels in both pictures, then that's about how much it appears to be everywhere. About $33, right?
Old 01-13-2012, 10:24 AM   #33
patrickth
Sorry, thought you meant per wheel earlier. $30-$32 is very reasonable.
Old 01-16-2012, 10:54 AM   #34
Curt's_72
Curt's_72's Avatar
Velocity Yellow got the nod. Comparing paint chips isn't a good way to make a long term choice, but it worked out.
Getting ready to layout the lines for the two tone. Rather than measure using the documents in the assembly manual, we used the trim instead. The fenders had mounting holes so we had that reference point to start.
The paint divider trim on the cab uses studs adn they were still in place, so we didn't have to lay anything out there.
We'er looking at days now, rather than months. What a great feeling!
Old 01-16-2012, 11:09 AM   #35
mjensen
mjensen's Avatar
That's looking great! Can't wait to see the yellow!
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 01-23-2012, 11:34 AM   #36
Curt's_72
Curt's_72's Avatar
Got the wheels back from the powdercoater. $128 total. I think they came out great! I read all the threads on these 16.5x9.75 wheels whenever they come up. I've not seen anything about the little hole in the second picture. Anybody know?
Name:  9.75x16.5 outer hubcap nub2.jpg
It appears to be a locating hole...
Old 01-23-2012, 06:20 PM   #37
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Did you get the truck painted?? Looks like a Yellow 2-tone behind those rims...
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 01-24-2012, 11:08 AM   #38
Curt's_72
Curt's_72's Avatar
Nick,
Yeah, it's painted. It's home and the assembly is well underway. At the beginning of the thread I talked about it finally being done.
I was showing over time the process that it had gone through before I actually revealed the body complete.
Here it is just after the yellow was applied.
The frame has been redone using POR-15 chassis black over the regular POR paint. This stuff is good!
Old 01-24-2012, 01:36 PM   #39
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Nick,
Coming OutcSweet
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 01-24-2012, 07:15 PM   #40
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Nick,
Very cool. I've looked at so many builds, i forget who is doing a re-cap and who is posting as they go. I like the yellow and white, its a little different than what you see every day. You were lucky to have the stud holes drilled for the trim already. My truck had zero trim on it, and im sure it will take some head scratching to get the 2-tone spacing laid out correctly. (once i get to that point obviously) Keep on truckin!
-NICK
Old 01-25-2012, 02:49 PM   #41
Curt's_72
Curt's_72's Avatar
We've set the bed back on to get ready to install the trim. Wow. It's getting very close.
Not being around body shops for some time, seeing the use of plastic rather the paper was new to me.
So happy with the yellow and white. The two tone layout always works with any tasteful color combination, though. Can't wait to see the trim installed.
Old 01-25-2012, 10:03 PM   #42
mjensen
mjensen's Avatar
That's killer!
Mike
Old 01-30-2012, 12:53 PM   #43
Curt's_72
Curt's_72's Avatar
Trim is going on!
I was going to attempt this myself when we got the truck home. I'm glad that I left this part up the bodyshop. It was going to be a extra cost.
But he was looking for a pair of 15x6 ralley wheels, which I had stashed. A good trade for me.
Pretty amazing how much difference the trim makes!
They tell me I'll have it at the end of the week....
Click below to see my build thread...lot's of stuff there
http://67-72chevytrucks.com/vboard/s...d.php?t=494493
Old 01-30-2012, 01:07 PM   #44
67swb72klb
67swb72klb's Avatar
lookn gooood
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 02-10-2012, 12:52 PM   #45
Curt's_72
Curt's_72's Avatar
It's home! I've posted some shots of it arriving on the main 67-72 truck page. I wanted to show off, I guess, to others that don't follow 4x4's. Everybody has a bodyshop experience in the world of restoration and I wanted to share the joy of that experience being behind me.
We've started to remove years of bodyshop crud and to POR-15 areas that need to be done. After what we went through with redoing the frame, I wanted to make sure that didn't happen again.
The Chassis Black is good stuff! Goes on thick. I wore a throw-away jumpsuit and gloves. Knowing the end result made the hours laying under it worth it, though.
It got almost overwhelming at times. It seemed like there were places everywhere that i missed or just couldn't get to.
I decided to after I got it on the road, I'd put it on a lift finish under the cab and complete the second coat under the bed.
We'll paint the front end this weekend after the new springs are in place.
Old 02-11-2012, 12:32 AM   #46
mjensen
mjensen's Avatar
Which version of the Chassis Black did you use? Did you use their primer too? I'm getting ready to send my frame to the blaster, so I'm curious...
Mike
Old 02-13-2012, 11:48 AM   #47
Curt's_72
Curt's_72's Avatar
Semi gloss POR-15 paint was first. It's not UV resistant, though. It will get chalky if exposed to the sun for very long. I've seen it.
I ended up going over everything with POR-15 Chassis Black. No choice of sheen, though. It's a very good shade of black.
No primer. I when right over the paint after cleaning it.
Old 02-13-2012, 12:38 PM   #48
Curt's_72
Curt's_72's Avatar
Good progress this weekend. Bad weather outside, great weather inside.
New springs got installed. Went with a 2 1/2" lift from Skyjacker. Had it since 2009.
We had some problems with the bushing insert lengths. They were too long. We ended up having to cut them down to fit the shackles in the front.. Then, we had to ream them out to get the factory bolts to fit. I considered smaller diameter bolts, but I didn't want to compromise any integrity of the suspension.
The kit said 73-87 on the bag, so I figured they provided me with the wrong bag assembly. But the instructions for all years stated that same assembly, so we modified what we had.
We ended up removing and suspending brake calipers because the front differential wouldn't drop far enough.
Everything is back together now.
Wow. I thought I was never going to get all the little cracks and areas cover with chassis paint. More time scraping and painting.
Old 02-13-2012, 12:51 PM   #49
Curt's_72
Curt's_72's Avatar
We removed the steering column and master cylinder. That was a huge space saver as far as being able to access the firewall and the engine on the driver's side. More parts to blast and powdercoat.
I had purchased a finned transmission cooler to mount on the frame cross member. I didn't like the big dorky one that was mounted to the firewall behind the grill.
It went on very easy and is out of sight.
The motor is cleaning up very nice. Actually, easier than I thought it would. Being able to stand inside the doghouse makes this task alot better.
Using a pressure washer in the driveway would have been the ticket, but a bucket of soapy water, brushes and 409 worked well.
Old 02-14-2012, 12:05 PM   #50
Curt's_72
Curt's_72's Avatar
Cleanup is going great. My Corvette valve covers and NOS Z-28 air cleaner aren't correct, but I like them. Brings me back to my muscle car days.
I was going to look for a better fan shroud. Bought some satin black plastic paint in a rattle can, and it came out fine.
