Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-16-2012, 10:05 AM   #26
onebadbowtie
onebadbowtie's Avatar
Re: 1972 K10 Project "Daily Driver"
got everything i bought installed this weekend. just need to paint the radio delete plate when it warms up.
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 01-18-2012, 12:38 AM   #27
Chevymaniac
Planning on putting a lift and bigger tires at all? Truck looks way better with the rallies and BFG's on it. Coming along nicely.
Chevymaniac is offline   Reply With Quote
Old 01-18-2012, 08:39 AM   #28
onebadbowtie
when i get the chance to do a frame off restoration i would like to go to a 33 inch tire. i don't know if a new set of springs will be enough to make them fit. if not probably do an add a leaf in the rear and ord zero rate in the front. if that wont work then i will have to step up the 2.5 inch lift kit.
James
Old 02-06-2012, 01:51 PM   #29
onebadbowtie
got to do a little work on the truck this weekend. nothing picture worth but progress. First i cut some old exhaust brackets off that weren't being used. cut ugly looking tail pipe off and put an old echo tip on it hidden under the truck. sounds a little louder now but not much. Next i took the dash apart and got the last nut on the dash pad( the pain in the a$$ one behind the head light switch). then i proceeded to scrape old gear oil and dirt off my transmission and transfer case for about an hour and a half. Probably got close to a cubic foot of stuff off of them. guess thats what 40 years of leaking does lol. the bad thing is that they are still nasty. Last i washed the truck for the first time since i got.
Next TODO list lol
-Change all Fluids
-New windshield
-Radio
-New shocks
-New bumbers
-New Exhaust
James
Old 02-06-2012, 05:32 PM   #30
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice progress. Do you miss the other one yet?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-06-2012, 05:55 PM   #31
onebadbowtie
thanks. ya i missed it saturday night lol. we got a big rain on friday. first big rain we have got in a long while. So i just had to go play in the mud. I regret it now but i took my 01 down a mile long mud road a couple times and got it completely covered. So i spent about 30 minutes washing it on sunday at home. now i need to take it to town and wash it with soap cause it still looks terrible. but it was fun at the time. So while the power washer was i out i sprayed down the 72. But it sure would have been nice to have had the flat bed to drive. I never had to worry about tearing it up haha it was already beat up and wore out. I highly doubt i ever mud my black one on purposethough. it drives way to nice to tear up in the mud. the only reason i drive my 01 over it most days is because of gas mileage
James
Old 02-08-2012, 12:12 AM   #32
onebadbowtie
i got a question about my clutch....in my red and white truck. once the clutch pedal was depressed about 3/4 of the way it seemed to cam over and get easier to hold down. like when waiting at stop lights and such. but in my black truck it never gets easier or what i would think to call camming over... is there any way of making it do this by adjustment or something? or am i out of luck?
i hate the stiff pedal. when i press it. it pushes my back way up into the back of the seat and its not comfortable at all
James
Old 02-08-2012, 04:19 AM   #33
Dieselwrencher
You might check the linkage rods for worn ends causing them to bind. Also, try greasing the z bar on the frame. It could be stiff too causing it to be hard to push.
Ryan
Old 02-09-2012, 01:03 AM   #34
onebadbowtie
alright i will look at those.....you think some softer springs on the pedal and clutch fork would help to or is that a no no?
thanks by the way
James
Old 02-19-2012, 08:58 PM   #35
onebadbowtie
More progress.....
-got new mirror heads for the truck due to the one missing the glass.
-changed the oil
-tightened the belts
-painted the radio delete plate
-then proceeded to buff the truck(by hand) until i ran out buffing compond
i will let the pictures show my work but i got the hood, roof and the whole passenger side done and the drivers front fender.
oh and a pic of my other pride and joy
James
Old 02-19-2012, 11:20 PM   #36
MTCK
MTCK's Avatar
Looks great! How long did it take you?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-19-2012, 11:47 PM   #37
onebadbowtie
i got about 3 hours in what i've done so far
James
Old 02-20-2012, 03:24 AM   #38
Dieselwrencher
Man great work! It's looking great!
Ryan
Old 02-20-2012, 03:26 AM   #39
Dieselwrencher
thanks by the way
If they've been replaced in the past they could be too heavy of a spring, but I'd try to make sure it isn't a wear issue first.
Ryan
Old 02-20-2012, 05:28 PM   #40
onebadbowtie
thanks by the way
thanks
i dont think they have been replaced. while i was messing around this weekend i got under the truck and had my brother work the pedal and we came to the conclusion that something in side the truck is making a dragging sound so hopefully this weekend i can get that figured out and finish buffing it.
James
Old 03-07-2012, 11:25 PM   #41
onebadbowtie
I have been driving the ol girl to school this week. Last night on my way home from class my dash lights quit working but my head lights and gauges still work fine. i tried spinning the knob back and forth several times with no luck. Did my switch go bad or what?
James
Old 03-10-2012, 01:08 AM   #42
onebadbowtie
i found and fixed the problem....a fuse was burnt out. turns out the only lights that were working were the head lights lol. anyways put a new fuse in and it burned out again. so got to looking for a short and found a spot where the exhaust had melted a wire and it was grounding out. so shes up and going again. put over 200 miles on it this week. i just really wish i could afford to drive it every day of the year. well i could lol but then i'd have no money to work on it
James
Old 05-09-2012, 06:31 PM   #43
onebadbowtie
Not much of an update but i snapped some pics of the ol girl working hard today enjoy
James
Old 08-09-2012, 06:37 PM   #44
onebadbowtie
So i finally started some more work on the truck last weekend. I have been trying to decide what i wanted to do for a rear bumper and hitch. i have not found a factory bumper that i like that wasnt beat up. i liked the look of the sport bumpers but my truck is no show truck and wanted something tough. So here is what i came up with. 6 feet of 2x6x.25 rec. tubing and my old bumper brackets got me to this point.
i then ordered a receiver hitch that bolts to the bottom of the bumper from harbor freight which i will weld on. im also planning on angling the bottom corners up to make it a little less boxey. then i will have it powder coated.
an another note here is one of my latest projects 85 honda atc 70
James
Old 08-10-2012, 06:08 PM   #45
Dieselwrencher
Great work on the bumper! Those little 3 wheelers are getting harder to find! We had a 185s that was all jacked up when I was a young'n. My Dad always said the only way we could ride it was if we could start it our self. I remember flying over the wheelie bars a few times when it pulled the rop out of my hands. That thing was bad azz, especially for a 10yr old.
Ryan
Old 08-12-2012, 11:15 AM   #46
onebadbowtie
thanks ryan they are a blast thats forsure.
I got the hitch welded on the bumper last night and the bumper installed on the truck. for the tag i just drilled and tapped the 4 holes. i still need to angle my corners up and put caps on the ends but waiting on the saw to get fixed. now for the pics......
Yesterday i also bought a new to me truck and sold my 01 this morning
James
Old 08-13-2012, 12:51 AM   #47
Dieselwrencher
Looking good, nice new truck too!
Ryan
Old 08-21-2012, 06:59 PM   #48
onebadbowtie
I haven't got any more work done on the bumper but i washed the ol girl up and took the tool box out last week some more pics
On another note i bought new the window felt kit from LMC a few months back and everything seemed to be pretty good quality. needless to say it wasnt. As soon as the truck started seeing sunlight the drivers side inside window felt started putting tar on my window as it was rolled up and down. i cleaned it off a few times thinking it would stop but no luck. i think i will try some where else next time although that was the only one that did it. here are a few pics of that
James
Old 08-22-2012, 01:45 AM   #49
Chevymaniac
That bumper turned out better than i thought. Nice and clean fit too. Looking forward to the finished product.
The parts coming far lmc do not seem to be of good quality. Makes me have second thoughts wether or not to order stuff from them.
Old 08-26-2012, 10:21 PM   #50
HEISEL
HEISEL's Avatar
I got my window felts from "classic Chevy truck parts of America" Classicparts.com. I put them on 3 months ago when it was 100+ with no probs. If I were you I would call LMC and let them know what's going on. They should help you out. Classicparts.com seems to have much better prices. Good luck. That a beautiful truck
1972 k/10 4x4 swb
2011 camaro SS/RS M6
HEISEL is offline   Reply With Quote
