Old 12-18-2011, 12:00 PM   #26
oldman3
oldman3's Avatar
Re: 51 Chevy 1/2 ton, My S10 swap
Nice repairs to the door....Jim
oldman3 is offline   Reply With Quote
Old 12-18-2011, 05:36 PM   #27
Wybrow
You're doing a great job on this. I have a lot of the same body work ahead of me, nice to see what you've done.
Wybrow is offline   Reply With Quote
Old 12-18-2011, 06:41 PM   #28
Atommik
Atommik's Avatar
Thanks Jim, Wybrow...
After getting a good look at the drivers door bottom, and my "success" on the other door, I'm definately going to try to make my own repair panels for the inner door. I should be starting on it this week.
Atommik is offline   Reply With Quote
Old 12-27-2011, 08:36 PM   #29
Atommik
Atommik's Avatar
Decided to take advantage of unusally "warm" Minnesota weather (35 degrees) and sand blast the inner fender panels. Was going to wait till spring, but it's supposed to stay "warm" this week, so I can sand blast outside!
Old 12-28-2011, 02:18 AM   #30
Root2812
Root2812's Avatar
I am so glad to hear that. I had to leave my truck in MN while I came down to Louisiana to finish grad school. I'm coming home in a few days and I pray it will stay warm enough for me to get a little bit done before I have to head back south. I was figuring the truck would be under 2 or 3 feet of snow by now.
Root2812 is offline   Reply With Quote
Old 12-28-2011, 06:51 PM   #31
Atommik
Atommik's Avatar
High's in the 30's all week and no snow in sight!!
Old 01-01-2012, 11:23 AM   #32
Atommik
Atommik's Avatar
I got the inner fenders and braces sand blasted and epoxy primed this week. Now back to the door rust repair!!
Old 01-04-2012, 01:02 PM   #33
99 to Life
99 to Life's Avatar
love the progress. I will be doing the same exact thing on my next truck. Lots of metal work. subscribed
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 01-04-2012, 01:40 PM   #34
xpickup
xpickup's Avatar
Atommik, nice job on the doors. I can not wait to see the headlamps lite. They say they are great to drive with. Great job.
Shannon
xpickup is offline   Reply With Quote
Old 01-04-2012, 07:11 PM   #35
Atommik
Atommik's Avatar
99 to life, Shannon, Thanks...I really enjoy both of your builds and always keep track of your progress.
Spent some time today making and welding in, inner patch panels on the drivers door. Maybe some pics tomorrow...The weather is warming up a little (40 degrees) so I may try to do a little more sand blasting too...
Old 01-08-2012, 07:20 PM   #36
Atommik
Atommik's Avatar
I just couldn't pass up 40 degrees and sunny, so I did do a little more sand blasting outside at work on Thursday and Friday. Got the upper radiator panel done (where hood latch sits) the fillers that go from the box sides to the running boards and the upper cowl fresh air intake, blasted and epoxy primed. Back to door rust repair this week...
Old 01-08-2012, 07:52 PM   #37
oldman3
oldman3's Avatar
Nice.....Jim
Old 01-08-2012, 08:02 PM   #38
Pop's C-10
Pop's C-10's Avatar
I like tha headlight mod
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 01-09-2012, 07:44 PM   #39
Atommik
Atommik's Avatar
Back on the drivers door rust repair today. I got the inner all patched and started gringing it down. I hope to start on the outer panels tomorrow.
Old 01-09-2012, 07:48 PM   #40
Atommik
Atommik's Avatar
Some pics...
Old 01-09-2012, 07:55 PM   #41
Atommik
Atommik's Avatar
In case you were wondering, the black on the patch (in the previous post) is epoxy panel bonding adhesive. I welded the main part of the patch in then "glued" the lip on the panel. It will be dry in the morning, ready to grind down.
Here's a couple more door pics...
Old 01-09-2012, 10:22 PM   #42
99 to Life
99 to Life's Avatar
sick, I love seeing this stuff. keep it up
Old 01-11-2012, 09:29 PM   #43
Atommik
Atommik's Avatar
Here's a few pics of the outer panel repairs started today on the driver's door.The patch is made, rusty parts trimmed out...ready for welding. Before I weld on the outer patch, I'll clean up the back side of the welds (on the inner patches) and then "seal" them with the same epoxy adhesive I use for bonding.
Old 01-11-2012, 09:33 PM   #44
Atommik
Atommik's Avatar
Even though the outer panel doesn't look too bad, it had about 30 pencil tip sized "pin holes" rusted through.
Old 01-11-2012, 11:04 PM   #45
99 to Life
99 to Life's Avatar
looking great keep it up.
Old 01-12-2012, 11:49 PM   #46
Atommik
Atommik's Avatar
I got the door all welded up today...Time to start straightening and filling, then prime and block.
When this door is done I'll take a little break from rust repair and start strightening the front fenders.
Talked to our former paint rep (the shop I work at changed paint lines...)he's going to get me the paint formula for the color I'm going to paint my 51...We have left over paint from the change over of paint lines so hopefully I can get enuf mixed(for free) to at least do a little jamming and painting some small parts.
Old 01-22-2012, 10:27 PM   #47
Atommik
Atommik's Avatar
I finished the body work on the drivers door and got it in epoxy primer. Need to do a little priming and blocking, then on to the next part of my project...front fenders.
Old 01-28-2012, 05:11 PM   #48
Atommik
Atommik's Avatar
I got the drivers door all primed and blocked out. I decided to make my cab mounts since I hope to get an s10 frame sometime in the next month...(tax return $$$.) Bought a 4" sqauare tube and basically used "Jeffs 51" plans for the mounts. Front mounts are done and will do the rears this week. I'll post a few pics when they are done. Also made a deal on a small block 327 with the TH350 originally out of a 69 chevy truck.
Old 01-28-2012, 10:04 PM   #49
99 to Life
99 to Life's Avatar
lets see some pics!!! sounds like everything is coming together pretty well.
Old 01-30-2012, 09:15 PM   #50
Atommik
Atommik's Avatar
Cleaned up and repainted the vent window frames. Here's apic of the drivers door in primer, still need one last prime and blocking....
