Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-18-2012, 01:22 PM   #26
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Engine?
I shoulda been more specific... It was a 3200lb car, solid roller on race gas.. The huge advantage with an LS i that they require waaay less labour to make power... I would say there are more bbc aftermarket parts on the market, but that could be untrue is as little as 5 years.. Who knows...! Bottom line is do your research and build what you want
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 01-18-2012, 09:33 PM   #27
Bad70sbchevy
Bad70sbchevy's Avatar
Re: Engine?
Originally Posted by Super73 View Post
Perhaps I am looking in the wrong place, but I don't see that many 9 second 3800lb NA big block trucks, let alone ones that only have 10k in to their motor set ups. I do how ever see a handfull of 10 second ones. But that leads me to ask, that handfull are they pump gas motors or high compression solid roller deals that require race gas and constant valvetrain adjustment.
Again, I'm not flaming the big blocks, just don't know a whole bunch about them.
Well this would do it easily.
http://www.hotrod.com/techarticles/e...e/viewall.html
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 01-18-2012, 09:37 PM   #28
bigboybodry
bigboybodry's Avatar
Re: Engine?
Originally Posted by Bad70sbchevy View Post
I'll take one for 10,000
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-18-2012, 09:49 PM   #29
Blue Rat
Re: Engine?
I will take two for $10,000
Blue Rat is offline   Reply With Quote
Old 01-18-2012, 09:58 PM   #30
Bad70sbchevy
Re: Engine?
Usually when they don't list the price, it costs too much.
Old 01-19-2012, 12:18 AM   #31
ItsRandy
ItsRandy's Avatar
Re: Engine?
LS motors are impressive. You can buy a 750hp LS based (LSX454X) crate motor from GM PERFORMANCE PARTS. A 454 cid small block? Ok...it's a small block, GM says so. Not very streetable, not intended to be (13.1:1cr, solid roller cam and a carb, not injected) and not on pump gas. Makes all the hp and torque numbers at "peak RPM" what ever "peak" is. LS motors are impressive, however, with 502 cid big block you can have 502hp @5200 RPM and 567lb.-ft. torque at 4200 RPM, 500+ lb.-ft of torque at 2500 RPM and drive it anywhere/everywhere for a long time with low maintenance on pump gas. You can't do that with a NA "small block". Now... be nice to me with your replies (I'm putting up my umbrella preparing for the sh*t storm I know is coming). Once you go big block you'll never go back.
ItsRandy is offline   Reply With Quote
Old 01-19-2012, 12:59 AM   #32
Bad70sbchevy
Re: Engine?
All of these motors are impressive but they all got there ups and down. Its like the old saying goes you have three choices when it comes to a motor: cheap, fast, or reliable, but you can only choose two. You can make a gen one small block (350 or 383) crank out 500hp easily and be just as reliable as that 502 as long as you know what you are doing for less. LS motors are great because they are a very efficient design and don't take much to make good power, but they're going to get more expensive as demand grows for them. You can make an old gen one small block perform just as well as an ls motor in performance and "streetability" for the same amount of money if not substantially less than a brand new ls motor from GM. Same applies for a big block, but big blocks are known for making as much power as you want depending on your wallet thanks to the fact that there is no replacement for displacement (but don't expect them to get the gas mileage of an ls motor, but then again I wouldn't complain ).
Old 01-19-2012, 01:03 AM   #33
Super73
Super73's Avatar
Re: Engine?
Are those engine dyno numbers or chassis dyno numbers? Seems like a short power band, 1k rpm. Bad heads/intake on that combo?
My little 418 pump gas hyd cam low maintenece motor made 521rwhp at 6,950 and 469ftlbs at 5,500. Just putting it out there.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-19-2012, 08:50 PM   #34
ItsRandy
ItsRandy's Avatar
Re: Engine?
I have to guess those are the numbers at the flywheel. Those numbers are from the GM Performance Parts catalog, I haven't had my motor on a dyno. 1k power band? Where do you see that?
Old 01-20-2012, 12:14 AM   #35
Super73
Super73's Avatar
Re: Engine?
I was reffering to peak TQ (4,200rpm) and peak HP (5,200rpm)..
Old 01-20-2012, 12:54 AM   #36
ItsRandy
ItsRandy's Avatar
Re: Engine?
I must need an education on what "power band" means. The way I look at the numbers the power starts coming on at 2500 RPM and falls off around 5200 RPM. Sounds like a fairly wide power band to me. If I am wrong please enlighten me. I drove trucks for a living for about 10 years. They had a tight power band: 1600 - 2100 RPM or 1800 - 2100 RPM, 500 and 300 RPM respectively. Now THAT is a short power band.
Old 01-20-2012, 02:53 AM   #37
Super73
Super73's Avatar
Re: Engine?
Most converter companies will set a converter at Peak TQ or a couple hundred RPM past for max 1/4 mile ET on a NA motor. You will go fastest out of the hole hitting the tires with everything you can TQ wise. So, to me, with a drag racing application, you must consider shift extensions of the transmission you are using. Looking at average power in that rpm range is much more important that what is under the curve. Since most transmissions will create more than a 1k rpm drop having a longer peak to peak rpm band is not a bad thing.
Example:
My motor makes peak TQ at 5,500 rpm and peak HP at 6,950 rpm.
Data logger shows a shift at 7,700rpm with the glide and it comes back in second at 5,600.
Data logger shows another pass I shifted at 6,500 and rode the converter at 5,200ish.
Since I should be shifting the old combo about 7,100, I want the most average power between the converter at 5,200 and 7,100 meaning 1,900rpm.
Now I have a 5,200 rpm verter vs a 5,700 due to using a N20 system.
Does any of that make sense?
Some will argue that riding the converter will help multiply TQ with the gear changes and net a better ET. I think that is dependant on combo.
There is much more to this, it's not that plain and simple, but something to consider. Road cars, street cars and drag cars are all differentand require different things.
Old 01-20-2012, 04:31 PM   #38
ItsRandy
ItsRandy's Avatar
Re: Engine?
Example:
Thank you for the education. I've said this before...great picture of your truck with the left front wheel in the air.
Old 01-20-2012, 05:22 PM   #39
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Engine?
big block old school for me
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-20-2012, 08:46 PM   #40
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Engine?
^ That is friggin AWESOME!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 01-21-2012, 07:00 PM   #41
ripdog28
ripdog28's Avatar
Re: Engine?
You can not argue BBC vs LS. Like arguing about a 350 vs Flathead. Some will love the old school, some want the new stuff. Technology advancing can not be argued. Only personal preferance. I would be ticked off if a BBC was still better then a LS which was designed over 30 years later. Yea, "No replacement for Displacement" works but like all things, their are exceptions, Forced Induction, Air flow, NOS, Compression, TECHNOLOGY, ECT.....
I love my BBC but can not stop thinking about an LS. Even thought of selling my C-10 and supercharging my Silverado w/5.3 How fun is Daily driving a 550+HP vehicle with all the creature comforts? I like my BBC but driving it daily is a job. I always say, Driving a new vehicle is nice, it is an experience that i enjoy to drive an old school vehicle.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 01-21-2012, 10:10 PM   #42
ItsRandy
ItsRandy's Avatar
Re: Engine?
I agree LS motors make a lot of HP, however, I think you only have to look as far as the NHRA Pro Stock class and see what the Chevrolet guys are running...it ain't an LS motor, it's a Rat motor.
Old 01-22-2012, 12:08 AM   #43
ripdog28
ripdog28's Avatar
Re: Engine?
Tell me why they have 4 cylinders in those classes. Those 4 cylinders are pushing 1400+hp. LS is superior in the design to a BBC. No need for a 454 when the 6.0 makes more power then any stock 454 placed in an engine bay from the factory. NHRA pro stock is not a RAT, it is a kangaroo. Those engines are around $100,000. Like comparing a Ferrari to a new V-6 Camero. Still a sick car just not the $$ into it the Ferrari does.
69 c-10 BBC
Old 01-22-2012, 02:50 AM   #44
Bad70sbchevy
Re: Engine?
The reason they run rat motors in Pro Stock is because the motors have to be NA, thus a need for bigger cubic inches to make power and I'm pretty sure they don't run turbo 4 cylinder motors in NHRA Pro Stock last time I checked but I can be wrong. You can make a lot more power with a turbo big block than a 4 cylinder, but trying to hook up all that power is another story...
Old 01-22-2012, 03:06 AM   #45
ItsRandy
ItsRandy's Avatar
Re: Engine?
I was unaware they ran 4 cylinders in pro stock. I know they are limited to 500 cubic inch, 90*, NA V8 motors with no spray and if your car is a Chevrolet you have to run a Chevrolet motor, if a Ford then a Ford motor.
A 6.0 LQ4 makes 325 HP. A LS6 (big block 454) makes 450 HP and was installed at the factory in 1970 SS Chevelles. An L88 (big block 427) made an advertised 430 HP but was later proven to make close to 500 HP and those were installed at the factory in 1967 Corvettes. The LS7 (big block 454) made 465+ HP but could only be had as a crate motor. They all have single carb induction.
Old 01-22-2012, 10:10 PM   #46
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Engine?
The Head technology that all the race teams are using is far superior to what most of us are running.
Pro stock,Pro mod,Top comp all these classes run 12-14* type of head's. Guess what degree LS based engines run? 12* I believe.
I wonder much like every one here has. Do I build BBC, LS based motor or do I take advantage of the cylinder head technology and convert from 23* to 14*-18*
Can I save in cost? Will it perform like a LS motor?
So many variables.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 01-22-2012, 11:21 PM   #47
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Engine?
Wouldn't it be nice to run in the 3's.....
http://extremeoutlawpromod.com/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-23-2012, 01:25 AM   #48
Super73
Super73's Avatar
Re: Engine?
Randy,
Numbers from the 60's and 70's were rated differently than todays motors.
The L88 and old school LS7 were more or less all out factory race motors. Look at todays little C6 ZO6 motor that is 427ci making every bit of 505hp from the factory. Smooth idle, runs vacum brakes, weighs less.. With a set of headers and a cam swap, they have been known to make over 600rwhp on pump gas.
Tony Mamo from AFR recently made 730+hp on an engine dyno with a 454ci LS motor. This was a 91 octane drinking hyd roller motor.
I mean really, things could be argueed for days on this.
I still haven't seen a rough cost for an NA high 11/low 12 second big block in a 36-3800lb truck.
4-5 years ago I remember driving around my buddies big block 69 truck wearing aftermarket heads, decent sized cam with 11-1 compression, converter, gear and tire. I was only running 12.30's in my truck then. He gatted me by 2-3 cars do to my lack of traction, went by him before the 1/8 and strapped close to 5 cars on him. Similar results with a second pass. My guess is it was a high 12 second truck at best.
Now I know DJ's old motor would have drove around me.. But what would that motor take to replicate in todays market?
Old 01-23-2012, 01:54 AM   #49
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Engine?
My 496 is $8800. It should have me in mid 11's no problem... The same engine in a chevelle is running high tens low 11's. Pump gas, vacuum brakes, and daily driver.
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 01-23-2012, 02:14 AM   #50
ItsRandy
ItsRandy's Avatar
Re: Engine?
Randy,
How much HP would you say you have to make (with the right tire/gear/chassis set up) to go low 12's/high 11's in a 3800 lb truck?
