07-23-2013, 10:21 PM | #26 |
Re: How To Remove The Lock Cylinder From A Blazer Hatch Handle
Check here, it may help depending on what step you are on...
http://67-72chevytrucks.com/vboard/s...=hatch+drawing
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
01-22-2015, 05:06 PM | #27 |
One of the First
Good information...
08-14-2017, 04:53 PM | #28 |
just wondering if the square stock of the handle is able to be pulled out of handle and a new piece installed...thanks
08-14-2017, 10:01 PM | #29 |
08-14-2017, 10:33 PM | #30 |
i thought it was cast around it thank you very much!
08-15-2017, 06:57 AM | #31 |
Good info here! So say I am able to get my original out of my hatch. Then I am able to get the cylinder out. Now - I need a key. Where do I find one?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
08-15-2017, 07:12 AM | #32 |
The original poster LockDoc. If you send him one of your keys he can match it so the same key works the doors and handle.
08-15-2017, 10:37 AM | #33 |
Carpe manana
LockDoc just keyed a handle for me last week. Big thanks! I've got the handle out to be re-chromed right now.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-15-2017, 12:21 PM | #34 |
I kinda figured he could do it. Thanks. I didn't know a door key was used. Guess I never tried one. Thought it was one of those mailbox sort of keys.
08-15-2017, 12:33 PM | #35 |
That may be the case but the door key will work.
08-15-2017, 12:56 PM | #36 |
Actually last year I bought an NOS hatch lock assembly off ebay and it had a square key like the ignition. I believe so anyhow I will have to dig it out and take a look.
08-15-2017, 01:27 PM | #37 |
Going to try some keys...
08-15-2017, 01:32 PM | #38 |
Just tried several door keys and sum mutha- wait for it- they fit but no deal.
02-26-2018, 11:16 PM | #39 |
K5drive
When it comes to making the square stock that fits over your handle . I was able to find a company that sells this stock . If comes in two or three inch lengths and only 1/2 inch diameter . I was able to machine down a piece of pipe with inside diameter 1/2 inch and outside diameter I had to machine down to look like the original part with a 'c' clip grove for reassembly . Once it was machined down I merely welded the square hole shaft to the new piece of pipe already machined down . The picture below is what the part I machined looks like that fits over the square holed shaft looks like . Again can also be done on drill press if patient . If having trouble email he at srpenner@hotmail.com
02-26-2018, 11:31 PM | #40 |
K5drive
The square stock and the pipe pictured below was able to build a couple parts and have a spare for sale . The square stock was not cheap (about $75) but if your wanting your build to closely resemble the original part then this is your best coarse of action .
02-26-2018, 11:32 PM | #41 |
K5drive
Assembled
08-09-2018, 04:37 PM | #42 |
I'm adding myself onto this very useful thread, thanks Leon.
11-24-2019, 01:17 PM | #43 |
OK. So mine was stuck all kinds of ways. I sheared the pin off at the end of the cylinder. Is there any way to fix this or do I just need another one? Any body got one?
12-02-2019, 11:11 AM | #44 |
Did the handle use the same key as the doors and ignition? Or was it a completely different type of key? Mine came with the original handle, but no key that worked.
1962 Chevy II Nova 400 Sport Coupe 1962 Chevy II Nova 400 Station Wagon 1972 GMC Jimmy |
12-02-2019, 11:38 AM | #45 |
yes ignition and door key works mine
01-15-2020, 10:21 AM | #46 |
I wish this thread existed in the mid-2000's when I bought mine. I pitched that handle and replaced it with a garage door unit. Now I wish I had the original handle back!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
