Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-19-2012, 02:29 PM   #26
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 cummins build brutus ii
Hey, what's that car behind your donor body? And do you guys have any other old pete cabs/parts trucks?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-22-2012, 11:09 AM   #27
mknittle
mknittle's Avatar
Got a little farther friday. got the hood and fenders off and ran into a problem getting the core support bolts out, they turned just enough to let the them just turn in the holes. It looks like the plates that keep them from turning are too short. So I being too lazy to drag the welding cart 200 feet up a inclined driveway took the bolts holding the bed to the frame out. The bolts holding the bed sides to the floor are kind of a pain.They all have broke loose though. So far so good Everything is comming apart a hell of a lot easier than I thought it would! Almost too easy The worst part is the wasps trying to take over they startet just after the first parts came off Maybe the PB Blaster attracts them?
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 04-22-2012, 11:18 AM   #28
Dieselwrencher
Darn fasteners that won't come out are a PITA!
Ryan
Old 04-22-2012, 11:24 AM   #29
mknittle
mknittle's Avatar
The car is a late 30s early 40s packard.I wish I had the front sheet metal for it. It had a inline 8 so it had a looong front end.
my dad has 3 1950s and a 359b? round door cabs. We also have a 1940s "charger" cummins in storage.
Mark
My GMC build.
Old 04-22-2012, 11:38 AM   #30
mknittle
mknittle's Avatar
The yellow one must have spent its life in the valley away from the salt so it really isn't that bad. Most of my problems have been trying to do things that take 2 people by myself. I usually can get away with it if I am close enough to the shop.
Mark
My GMC build.
Old 04-23-2012, 09:52 AM   #31
mknittle
mknittle's Avatar
One of these days Here I will run out of things to take apart. (for this project) and it will start going together. Then I can get back to my GMC.
Mark
My GMC build.
Old 04-23-2012, 02:12 PM   #32
mknittle
mknittle's Avatar
Had another brain fart today, this morning I am looking for parts to build a cab dolly. this is what I came up with: 16.5 feet of 3" I beam 4 mid 1990s saturn spindles and 20 feet of 2"X2" 120 wall tube. The plan, if my wife lets me have the spindles off her defunked saturn. Use the I beam for the sides spaced at 35"or so. tube for ends and legs and a spindle at on each leg. Steering setup like a big garden cart. I want to use the I beam because it would be easy to clamp to. i can use the e-brake too. this would be great for sanding and grinding outside and weldimg and painting inside. using the saturn wheels and tires should make it roll easy too
Mark
My GMC build.
Old 04-28-2012, 10:51 PM   #33
mknittle
mknittle's Avatar
Got side tracked today and cleaned this up a bit. and found enough parts for the blackout driving light. Of course it isn't all stock but none of the rest is either.
Mark
My GMC build.
Old 05-20-2012, 09:05 AM   #34
mknittle
mknittle's Avatar
I haven't got much done in the last month. I am at a roadblock on the runnin gear.I am waiting for the guy that has the parts to decide how he is going to do the front suspensionon on his project. then I can get the parts.
Mark
My GMC build.
Old 07-06-2012, 09:35 AM   #35
mknittle
mknittle's Avatar
Still waiting for the running gear to get taken out.
Mark
My GMC build.
Old 12-16-2012, 03:03 AM   #36
NEWFISHER
NEWFISHER's Avatar
Did you ever build the cart?
NEWFISHER is offline   Reply With Quote
Old 12-20-2012, 10:58 PM   #37
6BT 56
6BT 56's Avatar
This looks like a cool build. On any of those cool old big rigs do you have any old cummins emblems? Im just looking for a image to copy . When my 56 is done Im going to put a old school logo on the door for my marine transport/ service company. going to paint it and then sand it down and age it to suit the old truck. thought a old looking cummins script on the fender may look cool as well.
My build
http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 04-09-2013, 09:58 PM   #38
72smoker
72smoker's Avatar
Any new progress? Looks like you have some good stuff to start with.
72smoker is offline   Reply With Quote
Old 07-06-2013, 12:14 PM   #39
mknittle
mknittle's Avatar
Still on hold but I decided to use the 72 frame. It turns out that even though the Dodge frame has all the components mounted too many need to be moved. besides I can work on the 72 and drive the dodge.
I now have the trans/transfer case and front axle out of the donor.
Mark
My GMC build.
