03-09-2012, 10:08 PM | #26 |
Re: Windshield installation instructions needed
Did you get it in, or just rubber on the glass?
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
03-10-2012, 12:41 AM | #27 |
But Found Her 25yrs Later!
Just rubber on glass.
3 hrs of sweat to just get it on the glass. It might be that the rubber was stiff because of it not being very warm this time of year. I'm going to try and get it on the truck tomorrow or Sunday. Posted via Mobile Device
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-10-2012, 06:27 AM | #28 |
The long flat areas weren't too difficult. But getting the rubber to stay on the corners was challenging in that the rubber kept wanting to return to its previous shape.
So I ended up doing just the top and bottom and then masking taping them in place. Then I did one end and got some tape on it to hold it in place. Then did the other. Ran a space heater on each corner until I could feel the rubber was soft. Then after it cooled, it seemed to hold the corner shape rather well. Saturday (tomorrow) I will attempt to install the windshield in the cab. Here it is all taped up:
03-10-2012, 10:14 PM | #29 |
Most the way done with the windshield; had to stop for dinner.
I'll get back at it tomorrow. Yes, sigshooter, I started at the bottom. At first it hits the upper roof visor. But once I got the bottom interior and exterior lips of the rubber laid down where it belongs, the top just barely slips in under the visor. I'll be back online with my computer in the hour, and will post pics. Posted via Mobile Device
03-10-2012, 11:08 PM | #30 |
Part 1:
So, I first got the rubber on the glass, taped it in place, and let it set indoors for a day to let the rubber conform to the shape of the window. Then I routed the rope around the window pushing it into the groove that will sit over the pinch weld. Then I set the glass in the bottom pinch weld flange, leaned it against the roof visor and then leaned a couple wheels against the glass to keep a constant inward pressure. Once I got the bottom seal lips in place - inside and out, sliding either end of the rope out to both bottom corners - I took a rubber mallet and gently tapped inwardly down on the very top of the glass until it slipped in under the visor.
03-10-2012, 11:19 PM | #31 |
As I worked across the bottom and up the sides, I kept smoothing the outer lips out flush with the metal. Sometimes tapping on the outside with a rubber mallet.
03-10-2012, 11:25 PM | #32 |
This is where I stopped for the day.
I'm real happy with how it's shaping up. Maybe I'll get back on it tomorrow.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 03-10-2012 at 11:38 PM. |
03-11-2012, 01:07 AM | #33 |
Senior Enthusiast
Wow I never would have thought of tires to press against the glass. Great idea. That's really coming along nicely. Did you use any lubricant or sealer, and if so what did you pick?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
03-11-2012, 01:23 AM | #34 |
I'm using water and dawn dish soap for lubricant.
I'm not using any sealer. I've read of good and bad results using an additional sealer, putty, or otherwise. And I've read of good results from using nothing but the bare rubber applied with just soapy water. Beings I didn't have any additional putty/caulk or glue/sealer, I figured I'd just use the bare rubber applied with just soapy water.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 03-11-2012 at 01:35 AM. |
03-11-2012, 01:29 AM | #35 |
Senior Enthusiast
I'm not planning on using sealer either. I've had two windshields with no sealer and no leaks, so I'll risk it a third time rather than put up with the mess it causes. And thanks for taking the time to shoot the photos and post the progress reports. It's very helpful information.
03-11-2012, 01:34 AM | #36 |
I'm using plastic eating utensils for manipulating the rubber's outside lip into place.
I'm going to heat up and bend a plastic knife handle at a 90 degree for working into place the rubber's upper outer lip right under the roof visor. I might bend another at even a sharper angle for getting that upper outer lip in place.
03-11-2012, 04:20 AM | #37 |
Doing mine now, I agree with this suggestion:
03-11-2012, 09:41 AM | #38 |
Lost my 65, Well you did it congrats ! It just gos to show you where there's a will there's a way. But as the tires worked ,it is not a good idea...its a pounds per square inch thing, To much pressure in one spot could break the glass.I would advise asking Poindexter, the neighbor who borrowed the rake from you last fall to come and hold the glass for you next time just to be safe. Again great show of ingenuity !
03-11-2012, 10:16 AM | #39 |
Good job.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-11-2012, 10:29 AM | #40 |
This is some great tech in here... thanks for sharing folks!
-W |
03-11-2012, 07:51 PM | #41 |
Well I did it ! I started at the top, used the rope crossed at the top. Had two buddies holding up and in from the outside. I used a hook tool ( screwdriver with a bent end ) alot to help the rubber along the bottom. Went in first try in about 10 minutes this time.
03-11-2012, 08:05 PM | #42 |
Great Job!
03-11-2012, 08:19 PM | #43 |
Nice Jobs on the windshields. Just wondering how much harder it would be with the custom trim?? Anybody ever did it themselves (with no experience)
03-11-2012, 09:24 PM | #44 |
Watched a video online about with the trim, didn't look much harder. You put the glass in the rubber, then roll the rubber open and insert the trim into the rubber. From there it is the same as a standard rubber. If I can remember where I saw it I will post it. I think it was youtube and was from steele rubber maybe
03-11-2012, 09:33 PM | #45 |
How to remove and replace windshield is the title and it is by Steele Rubber on youtube... check it out I cant get it to upload to this thread
03-11-2012, 11:01 PM | #46 |
Link?
03-12-2012, 01:26 AM | #47 |
Senior Enthusiast
Is this the one? It shows Egge in the background, but they mention Steele at the beginning and end:
03-12-2012, 08:36 AM | #48 |
That is the one alright.... They make it look so easy
Seriously it doesn't look much harder than a plain rubber
03-12-2012, 08:59 AM | #49 |
Thanks for the video, looks real easy how they do it
03-12-2012, 10:31 AM | #50 |
Id like to see some more 60-63 winshield installs
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
