Old 03-15-2015, 04:35 PM   #26
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 55-59 Rear Fuel Tank
Frank, How are you handling the conflict between that neck and the rear cross member? Or do they not conflict? In the photos it looks like you'll have to C the top of the cross member. If you have any photos of how you did it, can you please post them or at least describe how you did it?
Also, you mounted the tank to the bottom flange of the frame rails, not the top flange. Did you do that to make it easier to remove later if needed? Also, why the triangulated 1" tubing? What was the need for that? Sorry to ask so many questions.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-15-2015, 04:59 PM   #27
Dan in Pasadena
Nosing around online and found THIS:
http://www.yogisinc.com/index.cfm/pa...d/prd15884.htm
If I'd known this existed before I wouldn't have to consider matching up sending units and fuel gauges. I figure some other guy will need to know about this product sooner or later.
Old 03-15-2015, 06:02 PM   #28
57chevyman
57chevyman's Avatar
Hey Danny boy , I plan to have a flip down license plate. I'm going to drill a hole in the center of the cross sill large enough to install a 1965-66 mustang filler neck . I have to add a bracket to the bottom edge of the cross sill which will serve two purposes - provide a surface to mount the flip down license plate bracket , and also strengthen the middle of the sill.
Here's a pic of the filler neck that has a flange built into it.
I mounted the tank on the bottom rail of the frame because I needed the tank there for the filler neck to position correctly. The tank is only 7" deep so it doesn't hang down low.
The triangulated 1" steel is to replace the rear crossmember I took out.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 03-15-2015, 07:32 PM   #29
OrrieG
OrrieG's Avatar
For $150 I'd take the time to get the sender matched to the gauge...
OrrieG is offline   Reply With Quote
Old 03-15-2015, 09:51 PM   #30
Dan in Pasadena
Thanks Frank!
So if I had this tank and mounted it to the top frame flange Id have to use a bed fill? The bent fill tube you used would come out too high to clear the bed floor?
Orrie,
Yeah I agree but back when I had my AD - that's Art Deco, a '46 it had a mustang tank already installed in it and when I had it rewired I had to go with after market gauges because the factory garage didn't work...but even if it had it would have worked with the Ford sender. This part would have saved me.
Old 03-15-2015, 10:47 PM   #31
tmoble
you can turn a 30 watt sender into a 90 watt with a 2 watt 60 Ohm resistor inline in the wire. You might be able to do it the other way around by mounting the resistor inline with the power feed wire. I actually haven't tried it that way personally but I certainly would if I needed to.
tmoble is offline   Reply With Quote
Old 03-16-2015, 06:41 AM   #32
57chevyman
57chevyman's Avatar
[QUOTE=Dan in Pasadena;7092015]Thanks Frank!
QUOTE]
yes, It would have to be a bed fill if the tank was mounted on the top of the frame.
when i make more progress ill post pictures :-)
Frank
1957 Chevy 3100
Old 03-16-2015, 06:48 PM   #33
Dan in Pasadena
Ok, thanks!
Old 03-16-2015, 06:56 PM   #34
57chevyman
57chevyman's Avatar
Even with it on the bottom of the frame , it doesn't hang lower than the bumper
Frank
1957 Chevy 3100
Old 03-16-2015, 10:24 PM   #35
Dan in Pasadena
Good to know. I suppose if it was painted or powder coated black it's be nearly invisible!
Old 11-18-2016, 04:53 PM   #36
superado
Originally Posted by FFredo View Post
In my 59 long bed I went with a unit from Tank King. I'm very happy with the quality. Had to build my own mounting and straps although they do sell strapping.
Thread from the dead!
I can't seem to find Tank King online.
Anyone have any info on them or a link to their website?
Tanks in advance!
superado is offline   Reply With Quote
Old 11-21-2016, 07:37 PM   #37
jaws61
That tank in the last pic is from Tank Sinc... In universal ones..
http://www.tanksinc.com/
jaws61 is offline   Reply With Quote
Old 11-21-2016, 07:46 PM   #38
superado
Thanks!
I guess the OP's spellcheck "corrected" Tanks Inc to "Tank King".
Old 11-22-2016, 02:27 PM   #39
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Originally Posted by Speedbumpauto View Post
I doubt you will find a "most" used. I have used Chevy van tanks before but on this build I used a Tanks 49-51 Ford car poly tank. It doesn't hang down as far as many I've seen but still holds 17 gallons. It also allowed me to use a Hagan fuel door in the d/s rear fender and has provisions for an in tank EFI fuel pump which I need. I'm not a fan of in the bed filler locations which are easier and having the tank low enough, especially on a low truck, to use the license plate door doesn't suit me either. Many will advise you to relocate the rear crossmember to the rear, which I did, but still had room to squeeze in a receiver hitch. IMO, the question comes down to the needs of each build.
i keep coming back to that one for my 59 and my son's 55.2. looks like it fits just right and we both don't want a bed floor filler door.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-22-2016, 02:42 PM   #40
roger55
roger55's Avatar
I think the Tanks, Inc poly tank is a great setup for those who don't want a fill in the bed.
After seeing that tank in Speedbump's build, I decided to go with it too.
I mounted mine a little higher than he did.
Here's the whole process I did:
roger55 is offline   Reply With Quote
Old 11-22-2016, 02:54 PM   #41
1-ton of fun
polishing a turd
well done sir. using the old filler neck gives it an original look even though it wasn't there before
Old 11-23-2016, 12:42 AM   #42
idbeast
performance on line 26 gal. fuel injection tank
adult image
upload pic
idbeast is offline   Reply With Quote
Old 11-23-2016, 08:18 PM   #43
brownsville
brownsville's Avatar
s-10 blazer gas tank. cheap, readily available, and parts are easy to find and mine fits under my factory bed floor with the nozzle just barely below the floor
brownsville is offline   Reply With Quote
Old 11-23-2016, 08:50 PM   #44
_Ogre
_Ogre's Avatar
idbeast: if your going to stay on leaf springs, that c-notch for your filler neck will eventually break your frame
i'd start by putting back some of the meat that you cut out on the frame, no need for a 4'' c-notch
then i'd add some more structure over the filler neck to help keep the frame from flexing
i have the same no-limit tank in my 58 truk, this is how i handled the filler neck c-notch
shop air compressor timer
Old 11-24-2016, 09:54 PM   #45
idbeast
_Ogre thank you for the heads up on this!
Old 11-25-2016, 07:38 PM   #46
_Ogre
_Ogre's Avatar
if you were on air bags it wouldn't matter, leaf springs add a lot of load behind the c-notch
the x-member you removed to make room for the tank also needs to be replaced behind the tank
i use 4'' channel iron for a x-member behind the tank
Old 11-26-2016, 08:47 AM   #47
Oldtruckwelder
Oldtruckwelder's Avatar
GREAT THREAD !!
Thanks , lots of good information shared.
Reading all of this still trying to figure which way to go.
Side fill, top fill , flip down license plate...
Thanks again
JT From SC
Oldtruckwelder is offline   Reply With Quote
Old 11-26-2016, 09:07 AM   #48
Oldtruckwelder
GREAT THREAD !!
Thanks again
JT From SC
Old 12-01-2016, 12:12 AM   #49
zenchal26
zenchal26's Avatar
search my build thread
build thread zenchal26 project 57
zenchal26 is offline   Reply With Quote
Old 12-03-2016, 10:52 AM   #50
idbeast
I'm going to 4 link it and I didn't get the X-member back in it yet! But thanks for the heads up again as I understand you are looking out for me and my build!
