Old 06-13-2012, 02:02 PM   #26
losthope
losthope's Avatar
Re: Hood & fender emblems
heres ones i got 1963 c10 fender emblem and not sure on the years of the gmc but its the v6 hood emblem:
heres some measurements
1963 c10 has two mounting screws with a measurement of 2 3/8
gmc v6 hood emblem has a guide pin and one mounting screw measures 1 5/8 and a part number 2419879 stamped on it
then I also have a cowl extension from a 1962 c10 with measurements for the holes hooking the straight hood side to the holes is 2 7/16 and then 7 11/16
then for the first hole measuring up from the crown for the first hole closest to the hood is 1"
then the second hole closest to the door is 1 7/8
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 06-13-2012, 02:09 PM   #27
1963c-10
1963c-10's Avatar
Cool. Im trying to put as much info on as I can about the emblems and the measurements are great. This thread should help some people with what they are looking for. It also backs up the OEM vs. repop issue. The reissue stuff is nice, but its not quite the same. If you've got factory #'s that'll help also. There seem to be a couple of variants on the GMC v6 emblems. If anybody can help identify the differences in the years it would be great.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-13-2012, 02:32 PM   #28
losthope
losthope's Avatar
Found this thread to 1963 c10 fender emblem location in the FAQ section herers the link:
http://67-72chevytrucks.com/vboard/s...d.php?t=459944
Timmy D.
Old 06-13-2012, 02:49 PM   #29
1963c-10
1963c-10's Avatar
Ill post it here also. Fender emblem mounting location for 63 chevy
Old 06-13-2012, 02:51 PM   #30
1963c-10
1963c-10's Avatar
Also...not quite trucks, but here are the corvair greenbriar emblems. If anybody can help ID the years, it'd probably help somebody out. The one on the brown & white truck is on a 62, but Im not sure what years it'd cover.
Old 06-13-2012, 03:15 PM   #31
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
'60 - '61 GMC's had the round emblem, and '62 - '66 had the other one.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 06-13-2012, 03:18 PM   #32
1963c-10
1963c-10's Avatar
Ok, great. Thanks for the help. Were just trying to inform and Im self educating on this thread. I had an emblem question from a guy a week ago and couldnt answer it, so I figured by starting the thread that we would get to the bottom of it. Ive actually seen a couple of new emblems I hadn't seen before. I have a picture of another Viking emblem somewhere....but have close to 5000 pics archived.
Old 06-13-2012, 03:24 PM   #33
1963c-10
1963c-10's Avatar
I believe this is a 1960 Chevy Viking emblem
Have since found out that was used until at least 65 as seen in the pic
Old 06-13-2012, 03:25 PM   #34
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
It's a great idea for a thread! Thanks!
Jason
Old 06-13-2012, 05:12 PM   #35
1963c-10
1963c-10's Avatar
1965 c-60 emblems GM part # 3855098
Old 06-13-2012, 05:16 PM   #36
1963c-10
1963c-10's Avatar
Ok, GMC guys...which way or ways was correct for this emblem? I know that it was 60 & 61, but I have found them 3 different color schemes and all have the same GM part # 2392804
Old 06-13-2012, 05:28 PM   #37
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
As far as I know the '60 - '61's never came in all white.
The Chrome one should have the same color pattern as the red, white, and blue one, except that the white areas are chrome.
The Custom Cab's are the ones that came with the chrome emblems. Everything else came with the white... or so I have read. LOL
Jason
Old 06-13-2012, 06:08 PM   #38
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
here is a spartan emblem from a coe-64, but same as the 60 big truck.
also a 62 40 series
Old 06-13-2012, 06:11 PM   #39
jonzcustomshop
1961 crewcab
66 custom camper:
64 30 series
Old 06-13-2012, 06:17 PM   #40
jonzcustomshop
1961 crewcab
Originally Posted by padresag View Post
here are 3 64 GMC and 1 chevy
ron
those are canadian correct?
Old 06-13-2012, 11:12 PM   #41
piratexpress1369a
piratexpress1369a's Avatar
By rondavid at 2011-07-10
ron
the gmc 910 which truck did it come from and where on the body was it
piratexpress1369a is offline   Reply With Quote
Old 06-14-2012, 01:30 AM   #42
padresag
it came from a c910. if you take out the 9 it says c10. the 9 denotes canadian model. it was on the cowl panel. 930 is a 1ton
ron
padresag is offline   Reply With Quote
Old 06-14-2012, 01:32 AM   #43
padresag
correct.
ron
Old 06-14-2012, 10:22 AM   #44
piratexpress1369a
ron
ok thanks ,so this would also be on suburban?
Old 06-14-2012, 10:46 AM   #45
padresag
yes my panel is a K910. GMC only has that 9
ron
Old 06-15-2012, 01:10 AM   #46
piratexpress1369a
ron
do you have picture of the placement on your panel?my replacement cowling had no holes ,they came off a pickup
Old 06-15-2012, 01:32 AM   #47
padresag
http://67-72chevytrucks.com/vboard/a...1&d=1339604123
it will be centred on the panel just a bit up from that bend as in the picture
By rondavid at 2011-01-25
ron
Old 06-15-2012, 08:09 AM   #48
1963c-10
1963c-10's Avatar
This thread has turned out more informative than I thought. Keep them coming.
Old 06-15-2012, 10:01 AM   #49
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
I can post some pictures of the fender hole measurements for my '60 GMC this weekend.
Jason
Old 06-15-2012, 10:06 AM   #50
1963c-10
1963c-10's Avatar
Thatd be great.
