Old 09-20-2012, 10:42 PM   #26
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: 79 1 ton with the death wobble
King pins aren't that hard, I cut a relief just above the inner c to relieve some tension and crank them out with a 7/8 allen socket and breaker bar/cheater bar. Hardest part was torquing the new ones to spec, I broke a socket adapter to tighten it to the factory spec of 500-600ftlbs. I had both sides done in about 3 hours to include disassembly and reassembly of all front end components.
It definitely helps leaving the axle in, as I grabbed onto the bumper/fender with the cheater on my belt buckle to torque the new ones down.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-20-2012, 11:19 PM   #27
obijuan
Originally Posted by GCncsuHD View Post
I torque mine to 130ftlbs dry, 100 if you dab any anti seize on the threads.
No antisieze!!!! You want your lugs to stay tight. GM calls for 140ft/lb and dodges 9/16 take 135. So around there.
obijuan is offline   Reply With Quote
Old 09-21-2012, 12:30 AM   #28
Mr. 250r
Mr. 250r's Avatar
I would say putting fuel in a truck or changing the wheel is 'easy' and changing a kingpin more to moderate or hard depending on how bad it is stuck or what tools you have at your disposal and.... how you do it lol as far as the dodge front axles go i love dodges for the diesel i haven't had a problem with my early 04 but my cousin has a wobble on his 04.5, hopefully i never have it on that as i already have it on my suburban
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-21-2012, 07:13 AM   #29
b454rat
I don't know why everyone thinks it's hard to change the kingpin. I did at least two, both where 78/79 axles that where never changed. I never did it before for the fear it wouldn't budge, or would break or strip something, and that I couldn't change it out. I was dumbfounded when it they came out with little effort. Have a harder time getting the lower bearing plate off....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 09-21-2012, 08:20 AM   #30
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
While I agree, there are those that think it is a must to put some on, then they turn around wonder why their studs snapped off when they torque them to the factory values
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 09-21-2012, 08:35 AM   #31
OLDCHEV4X4
OLDCHEV4X4's Avatar
I lube my lugs, And I have never had one come loose. Or break off from tightening.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-21-2012, 08:56 AM   #32
GCncsuHD
GCncsuHD's Avatar
To do them properly, you should only torque them to 80% of the recommended value, since the torque spec is a dry value.
ΜΟΛΩΝ ΛΑΒΕ
Old 09-21-2012, 11:45 AM   #33
csb#356
Well I replaced the bushings and springs and I couldn't get it to do it but it did feel like it tried and that was only at 35 mph. I'm going to the alignment shop today to have that checked. Don't know what to do after that.
csb#356 is offline   Reply With Quote
Old 09-21-2012, 10:40 PM   #34
Mr. 250r
Mr. 250r's Avatar
Did you run over any good size bumps thats a place it likes to come out at so rail road tracks work as a good test
2003 1500 Silverado
Old 09-21-2012, 11:07 PM   #35
csb#356
It doesn't seem to matter what speed I'm going or how big the bumps are, it's just if i'm on the brakes. I tightened up the steering box a little, it was a bit sloppy so I think if I get a new one of those and some tie rod ends it should solve the issue. I also found that the alignment is toed out a little bit so once all that is replaced I'll get it aligned and cross my fingers that I can drive it. Lol
Old 09-23-2012, 12:41 PM   #36
b454rat
If it does with the only the brakes it sounds like the rotors are warped....
Old 09-23-2012, 01:47 PM   #37
63chevyll
gets board easy.......
63chevyll's Avatar
The dreaded death wobble.
My 85 k30 never had the DW, then After I changed everything to new parts with a lift I all of the sudden the had DW.
Only thing I didn't do was king pins.
And in the past, I just welded a old nut to the upper king pin if the Allen won't break it out
63chevyll is offline   Reply With Quote
