11-18-2012, 04:09 PM | #26 | |
Re: project 66 beater
HAHA Yea well, We all want to buy a "driver" and well, just drive it right? I'm sure the cars I've built there are owners posting the exact same stuff, I certainly hope not.
I've never been able to hack stuff together and make it last like some folks. It hasn't been as bad as it seems, just a lot of little things. I did finally get to drive it today and no shimmy good shifts and lots of power. Funny thing is that I had to go see the previous owner and he knew nothing of the frontend problems Hmmmmm.... Quote:
11-26-2012, 11:04 PM | #27 |
But Found Her 25yrs Later!
Cool!
Got your fleet bed on:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
11-27-2012, 09:46 PM | #28 |
HA HA yes I did, I was just about to add this picture.
Update, I got the tail lights all wired up using GM Weather Pack plugs. I absolutely love'em TV cable is adjusted and shifting like a dream.. Found I have a Parasitic draw coming from my alternator, That will get addressed tomorrow.. still plugging away at all the little stuff. |
11-29-2012, 05:16 PM | #29 |
Been driving around for a couple of days just shaking things down and well, it's been doing pretty darn good. No more weird electrical stuff. Runs good and doesn't get hot. No more dead battery.
I managed to hook up a filler neck that will serve its purpose until I get a floor in the bed then I will flush mount it. Ive already raised the cross seal up off the tanks. Just incase you guys were wondering.. |
11-29-2012, 08:35 PM | #30 |
With the 4-6 drop it looks like it has a little rake to it.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-29-2012, 10:30 PM | #31 |
11-30-2012, 09:30 AM | #32 |
Looks great. I'll be following this one.
12-06-2012, 06:27 PM | #33 |
After much headache and time I had all the lights working, Went down to my local station and it passed inspection with flying colors BUT when I got home, Tail lights are flickering with the ign off and lights on and with the running lights on (no headlights) the left turn indicator on the dash is lit. The shift indicator back light comes on when the brakes are applied. Grrrrr.....
I'm starting to think its all in the turn indicator switch in the column or possibly the headlight switch. I had it out cleaning contacts to get the tail lights working and got everything working but now looks like back to the drawing board. |
12-06-2012, 08:57 PM | #34 |
I had the same issues a while back, I had to replace the "high" beam switch on the floor as those wires looked like after years of getting wet they'd become toast and then the switch its self on the dash. Found a wire in the tail light that wasn't grounded very good as well. That fixed all my trucks issues, why didn't you just register the truck as an antique and skip the inspection?
12-06-2012, 08:59 PM | #35 |
Where is the tail gate?
12-06-2012, 09:12 PM | #36 | |
Since this thing will be driven a lot I didn't want to catch grief from the Local PD for driving it so much. I may retitle it later to reflect that... |
12-26-2012, 10:24 AM | #37 |
Alright, Got my lights working. Bad dash ground. All good now..
I found a set of doors from a guy and replaced my bad passenger door and rebuilt the vent windows. I couldn't get the provided rivets to work and went with a stainless pop rivet that worked perfectly to hold the rubber in place on the vent windows. Heresw a few pics. |
12-26-2012, 10:59 AM | #38 |
Vent widows rivets is a 2 person job.
here is one thread from the fact section on vent windows http://67-72chevytrucks.com/vboard/s...d.php?t=351471 here's the ones I did post 62 http://67-72chevytrucks.com/vboard/s...=502124&page=3
12-26-2012, 03:23 PM | #39 |
I agree its a two person job and I had help, The pop rivets worked just fine and i can assure you they aren't going any where...
The vent widows are installed and you can't tell the difference... |
12-28-2012, 08:59 PM | #40 |
started installing the low rent bed floor in my rig. I will take the wood back out and paint it and install the rest of the strips...
01-28-2013, 09:27 PM | #41 |
So I a bit of an update, I have been chasing a little bit of rust on my truck. The drip rails were shot so I figured I'd better figure out whats going there. The A pillars turned out to still be in good shape so I decided just to shave the drips and smooth out the pillars. They are roughed in for now...
Thanks for looking... |
01-28-2013, 09:44 PM | #42 |
I like it.
01-28-2013, 11:42 PM | #43 |
Great truck, and great progress, subscribed to follow along
Noticed that you added the custom cab sails, nice!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 Last edited by CRGRS 66; 01-28-2013 at 11:47 PM. |
09-16-2013, 07:53 PM | #44 |
09-16-2013, 07:56 PM | #45 |
09-16-2013, 07:58 PM | #46 |
09-16-2013, 10:48 PM | #47 |
moocho better
09-17-2013, 12:27 AM | #48 |
Glad to see you posting an update.
Looking good. Posted via Mobile Device
09-20-2013, 04:14 PM | #49 |
Thanks guys
09-21-2013, 02:54 PM | #50 |
I like your truck! It looks soooooooo much better than it did when you first got it. I'm telling you I'm going to have to buy one of these '60-'66. Man I like these old trucks....
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
